Manage members
After you have added members to your organization, you can manage their accounts. Managing members includes modifying profiles and account settings, resetting passwords, disabling multifactor authentication, disabling member accounts, and deleting members. Managing members also includes changing their role or user type, and categorizing members by characteristics such as department or location. For information about managing member content, see Manage content.
The actions you can perform when managing members depend on your privileges in the organization.
Tip:
Use the filters and sort options to help find the members you need to manage. For example, to change the user type for members with the same user type, role, and group membership, you can filter the list to show only members that match that set of criteria. You can also filter by assigned licenses and last login date.
Modify profile
If you have the appropriate privileges, you can modify a member's profile and settings, such as their profile photo, bio, profile visibility, language, and email address.
To modify a member's profile and settings, complete the following steps:
Confirm that you are signed in to your organization and that you have privileges to update member account information.
At the top of the site, click Organization, and click the Members tab.
Search for members by name or username and apply filters to narrow the members list. Sort the list as desired, such as by name or last login date.
Click the More options button
for the member whose profile you want to modify, and click View profile.On the member's profile page, update any of the following: profile photo, member name, bio, or profile visibility.
To edit the member's settings, such as their email address, start page, language, and units, click View <member name>'s settings and modify the settings.
Change email address
You can see the email address on a member's settings page and, if necessary, you can change it. Only administrators with privileges to update member accounts can change email addresses for members. Members without this privilege cannot change their own email address.
Categorize members
As an administrator or a member with the privileges to manage member categories, you can set up hierarchical categories for organizing members in your organization according to characteristics, such as department, location, and expertise. Once categories are set up, members with the privilege to update member information can categorize members in the organization. This allows you and others in the organization to filter the members list by member category to find specific members. A member's assigned categories are displayed on their settings page and can be viewed by the member and those with the privilege to view members.
Set up categories
To configure member categories on the Members tab of the organization page, complete the following steps:
Confirm that you are signed in to your organization as a member with the privileges to manage member categories.
At the top of the site, click Organization.
Click the Members tab.
Under Categories, click Set up member categories.
Tip:
If some member categories have already been configured, click Configure categories
to add, rename, delete, or reorder categories as needed.In the text box, type a category name (using up to 100 characters), and click Save
.Optionally, click Add category
, type a name, and click Save to create a subcategory.Repeat the previous steps to create additional top-level categories and subcategories.
Do any of the following to make additional changes to the categories:
Click Edit category
, type a different name, and click Save to rename a category or subcategory.Click Delete category
next to a category or subcategory to delete it.Click Reorder
next to a category or subcategory and drag it to a new position in the hierarchy.
Close the Configure member categories window when you are finished setting up categories.
You can now assign the categories you created to members in the organization.
You can have up to three levels of categories in the hierarchy, with a maximum of 200 categories and subcategories in total. For efficiency, it is recommended that you create a comprehensive and complete category hierarchy and naming scheme before assigning categories to members.
Assign categories to members
Once member categories are configured, those with the privileges to update member information can categorize members in the organization on the Members tab of the organization page. Alternatively, you can assign member categories to one or more members during the add member workflow or configure your organization to automatically assign a set of default member categories to new members who are added to the organization.
To assign member categories on the Members tab of the organization page, complete the following steps:
Confirm that you are signed in to your organization as a member with the privilege to update member information.
Use the filters, sort options, and search capability as needed to find one or more members to categorize.
Select one or more members, and click Categorize.
Do any of the following:
Check the check boxes to select categories and subcategories to assign them in bulk to the selected members.
Selecting a subcategory automatically selects all associated categories and subcategories above it in the hierarchy.
Uncheck the check boxes to remove all selected members from a specific category or subcategory.
When deselecting categories and subcategories, the following occurs:
Deselecting a category or subcategory automatically deselects all of its associated subcategories.
Deselecting a category or subcategory when no other subcategories are selected at the same level also deselects the associated categories above it and subcategories below it.
Click Assign Category on the member card and select one or more categories to categorize an individual member.
You can assign up to 20 categories to each member. You can also use the Filter categories text box to narrow the options.
Click the remove button next to the category on a member card to remove a category assignment for an individual member.
Click Done when you are finished assigning categories.
The members are organized into the categories you specified. Members can view their assigned categories on their settings page. Administrators and members with the privilege to view members can also view a member's assigned categories on the member's settings page and can use the Categories filter on the Members tab to find specific members.
Change user types
User types determine which privileges and apps are available to members. Once assigned, user types can be changed by those with the appropriate privileges.
User types may be reassigned no more than once in any thirty (30) day period, except in the event of the assigned individual’s permanent role change, extended leave, or departure from the Customer’s organization.
To change user types, complete the following steps:
Verify that you are signed in to your organization and have administrative privileges to change member roles, manage licenses, and update member account information.
Do one of the following:
To change the user type of one member, click the More options button
for the member, and click Manage user type.To change the user type of multiple members at once, check the check box next to the name of each member, and above the list of members, click Manage user types.
Tip:
You can select up to 100 members at a time. The selected set is maintained while you search and filter all the members in your organization, even across multiple pages. If necessary, click the members selected drop-down menu to review and revise the selection once you've modified the initial search or filter.
In the window that appears, select a user type, select a role (if necessary), and click Save.
The user type can be changed to one with fewer capabilities if the member satisfies the corresponding requirements. For example, you can change a member from Creator to Viewer as long as the following conditions are met:
The member does not own content or groups.
The member does not have add-on licenses assigned that are incompatible with the new user type.
The member does not belong to shared update groups.
If the conditions above are not met, the administrator must reassign that member's content and groups, revoke the add-on licenses, and remove the member from these groups before changing their user type.
Change member roles
A role defines the set of privileges assigned to a member. Once assigned, roles can be changed by administrators and those with privileges to change member roles. When you assign a role, it must be compatible with the member's assigned user type.
To change a member's role, complete the following steps:
Verify that you are signed in to your organization and that you have privileges to change member roles.
Changing a member's assigned role to or from the default Administrator role requires signing in as a default Administrator role.
To change the role of one member, click the member's current role and choose a new role in the window that appears
Click Save.
To change the role of multiple members at once, do the following:
Check the check box next to the name of each member whose role you want to change.
Tip:
Above the list of members, click Manage user types.
In the window that appears, search for the role you want (if needed) and select it.
Only the roles that are compatible with all the user types assigned to the selected members are shown.
Click Save.
Transfer member
Organization administrators can transfer a member's user type, role, content, groups, add-on licenses, settings, and member categories to another existing member.
To transfer a member, complete the following steps:
Verify that you are signed in to your organization.
You must sign in as a member of the default administrator role or a custom administrative role that has privileges to manage members, content, and groups.
for the member you want to transfer.Click Transfer member.
The Transfer member window appears.
On the New member tab, select Keep account or Delete account.
Optionally, select Change user type and role after transfer.
Use the Transfer to search to find and select the member you want to transfer to.
The current user type and role and the new user type and role of the member you are transferring to appears.
Click Next.
The Content and groups tab appears.
Select one of the following target folder options:
Maintain folder structure—Transferred items will be stored in folders that have the same names as the original item owner's folders. If duplicate folder names are detected, the original owner's content will be put into the new owner's existing folder with the same name. The original owner's root folder will not be maintained, and the content in their root folder will be transferred to the new owner's root folder. If the original owner has an empty folder, it will not be maintained for the new owner.
Select one folder for all content—Transferred items are all stored in a single folder. Select or create a folder, or keep the default folder.
If the original owner has content shared with a group of which the new owner is not a member, the content will be unshared from the group.
Optionally, do any of the following:
Under Content to transfer, click View all to review the member's content.
Under Groups to transfer, click View all to review the member's groups.
Click Next.
The Additional settings tab appears.
Reset password
Organization members who have privileges to update member account information can reset passwords for members. The system provides a temporary password that you must share with the member so they can sign in. After the member successfully signs in with the temporary password, they are prompted to change their password. If the member is currently signed in when you reset their password, they are immediately signed out.
You cannot reset passwords for organization-specific (SAML and OpenID Connect) logins.
Verify that you are signed in to your organization and that you have privileges to update member account information.
for the member whose password you want to reset, and click Reset password.Depending on how your organization is configured, one of the following happens:
You are given a password in the Password Reset window and need to inform the member of their new, temporary password.
If email settings are configured for your organization, the member is sent an email with their new, temporary password.
When the member signs in using the temporary password, they are immediately prompted to change their password.
Disable multifactor authentication
Administrators can disable multifactor authentication on a member's account. This is a privilege reserved for the Administrator role. This option only appears when the organization is configured for multifactor authentication and the member has enabled it through their profile page.
To disable multifactor authentication, complete the following steps:
Verify that you are signed in as an administrator of your organization.
for the member for whom you want to disable multifactor authentication, and click Disable multifactor.
The member receives an email notification that multifactor authentication has been disabled on their account.
Disable member accounts
If you are an administrator of your organization or you have the appropriate privileges, you can disable member accounts in your organization.
Disabling a member account prevents the member from consuming organizational resources. This can be useful while you transfer their items to a different member. Members whose accounts have been disabled cannot sign in to the organization, consume organizational resources, create content, or administer the site. They are still members and count toward the number of users in your organization.
If the member owns content or groups, you must transfer their content and groups to a different member when you delete the member account.
To disable individual member accounts or disable them for a selected set of members (up to 100 at a time), complete the following steps:
Verify that you are signed in to your organization and that you have privileges to disable member accounts.
Check the check box next to the name of each member whose account you want to disable, and above the list of members, click the More menu, and select Disable member account (or Disable member accounts if multiple members are selected).
Tip:
To enable one or more disabled member accounts, select the member or members, and above the list of members, click the More menu, and select Enable member accounts.
Delete members
If you are an administrator of your organization or you have the appropriate administrative privileges, you can delete members when you want to remove the account from your organization. You can also delete members in bulk using a command line utility. Only members with the default Administrator role can delete other administrators.
If you are deleting a single member who owns content and groups, you must either transfer their content and groups to a different member or delete their content and groups. If you are deleting members in bulk, you can either transfer or delete their content. You cannot transfer groups when deleting members in bulk; their groups will be deleted. If the member has licenses assigned, the licenses are automatically revoked when you delete the member. For some Esri products, such as ArcGIS Pro and ArcGIS Drone2Map, licenses must be checked in by the member before you can revoke them.
If a member is deleted directly from the identity store, the member is retained in the portal. You must delete the member manually from the portal.
Member accounts that exist in the portal's built-in identity store are permanently deleted and cannot be recovered. Organization-specific accounts (SAML and OpenID Connect) are unregistered from the portal and retained in the identity store. If necessary, you can recover the organization-specific account by adding it back to the portal.
Tip:
To quickly assess which users in your organization are members of the portal, you can use the ListUsers command line utility to generate a text file that lists all the members in the portal. Use this utility to assess which users in your organization can be removed from the portal. The output text file can also be used as input to the DeleteUsers command line utility described below. For complete instructions, see Listing members.
To delete members, complete the following steps:
Verify that you are signed in to your organization and that you have privileges to delete members.
Ensure that the licenses of add-on applications, such as ArcGIS Pro, that are assigned to the member have been checked in.
When you delete the member, these application licenses will be automatically revoked. If they are still checked out, you can't delete the member.
for the member you want to remove from the organization, and click Delete member. To delete multiple members, check the check box next to each username you want to delete, click the More drop-down menu, and click Delete members.If the member owns content or groups, either transfer ownership of their items and groups to another member or delete them by doing one of the following:
To transfer ownership of their items and groups, select Transfer content and groups, click Next, and search for and select the member you want to transfer ownership to. The new owner must have privileges to own content and groups. Optionally, choose Maintain folder structure to store the transferred items in folders with the same names as the original item owner's folder, or choose Select one folder for all content to store them in a new or existing folder.
To transfer ownership of items when deleting members in bulk, select Transfer content, click Next, and search for and select the member you want to transfer ownership to. The new owner must have privileges to own content and groups. Choose Create a folder for each previous owner to store the transferred items in separate folders named for each current item owner and provide or accept the default prefix for each folder name, or choose Select one folder for all content to store them in a new or existing folder.
Groups will be deleted when deleting members in bulk.
When you transfer the ownership of an item shared with one or more groups, the new owner must be a member of all groups with which the item is shared. In addition, the Who can contribute content? setting of each group must allow the new owner to share items with the group. For example, if the item is shared with a group that only allows the group owner or group managers to contribute content, the new owner of the item must be that group's owner or manager.
Tip:
Changing layer ownership changes ownership of the file from which the layer was created. When you change the owner of a hosted feature layer, ownership changes for its dependent hosted layers as well.
Changing the owner of a layer does not change the owner of the maps and scenes in which the layer is used. Similarly, changing the owner of maps and scenes does not change the ownership of the layers inside them, nor does it change the owner of the apps in which the maps and scenes are used.
To delete their items and groups, click Delete content and groups, and click Next.
To delete items and groups when deleting members in bulk, click Delete content, and click Next.
When finished, click Delete member.
Only administrators can delete other administrators.
The members are deleted from the organization and their groups and content are either transferred to the specified member or deleted.
Delete members in bulk using the command line utility
Deleting members using the command line utility is appropriate if you need to remove a large number of members at once from your portal. You can do this periodically to keep the total membership count under control. You can also do this if you recently upgraded your portal and must reduce the number of named users to the maximum allowed by your authorization file. For more information about this scenario, see Enforcement of named user licensing.
You'll use the DeleteUsers command line utility that was installed with the software to remove members from the portal in bulk. The tool is in the <Portal for ArcGIS installation location>/tools/accountmanagement directory. The tool uses a text file as input and must be run on the machine where the portal is installed.
You'll use the DeleteUsers command line utility that was installed with the software to remove members from the portal in bulk. The tool is in the <Portal for ArcGIS installation location>\tools\accountmanagement directory. The tool uses a text file as input and must be run on the machine where the portal is installed.
The utility can only be executed by a built-in administrator account; you cannot use an organization-specific administrator account. The built-in account you use can be the initial administrator account you set up when you configured the portal or another built-in account that has been assigned the default administrator role. If you deleted the initial administrator account and do not have any other built-in administrator accounts available, you must create one to execute the utility. For instructions, see the Built-in portal accounts section of Add members to your portal.
To delete members in bulk using the command line utility, complete the following steps:
Create a text file that contains the usernames of members you want to delete from your portal, and list each member's username on a separate line.
The following is an example:
sarah robert james qingNote:
You must specify the username of the member. Do not use the full name of the member; the tool will ignore all entries that use the full name of the member. Usernames that you type in the text file must be in the same case as they are stored in the portal. You can run the
ListUserscommand line utility or review the Members tab on the Organization page in your portal to see the case of the usernames.Save the text file.
Run the
DeleteUserscommand line tool by specifying the text file as the tool's input, for example,./DeleteUsers.sh --file /data/scripts/memberstodelete.txt.Run the
DeleteUserscommand line tool by specifying the text file as the tool's input, for example,DeleteUsers --file c:\scripts\memberstodelete.txt.Tip:
Be sure to use the correct case for command line options and file names.
