Coordinate system requirements and installation
To perform geographic transformations (for example, NTv2, GEOCON, and NADCON5) and vertical transformations (for example, EGM and VERTCON) requires additional coordinate system files to properly transform and render features.
The following are the additional coordinate system files that you can use on ArcGIS Server machines:
  • ArcGIS Coordinate Systems Data—Install ArcGIS Coordinate Systems Data on all machines in stand-alone and federated ArcGIS GIS Server sites, including the hosting server site.
    When you upgrade ArcGIS Server, you must uninstall the previous version of ArcGIS Coordinate Systems Data before you install the new version of ArcGIS Coordinate System Data.
  • Third-party transformation grids—You may need to obtain transformation grids from the appropriate third-party providers and place them on machines in stand-alone and federated ArcGIS GIS Server sites. These files are not applicable on the hosting server site unless you publish services that reference registered databases to the hosting server.
The ArcGIS Coordinate Systems Data component is required if you will perform geographic or vertical transformations.
Follow the steps below to install ArcGIS Coordinate Systems Data.
The ArcGIS Coordinate Systems Data installer must be run in a graphical user interface (GUI) mode.
  1. Download the ArcGIS Coordinate Systems Data installation from My Esri.
    The download is available in the Downloads > ArcGIS Enterprise (Linux) section of My Esri. The file name is ArcGIS_Coordinate_Systems_Data_Linux_<release_part#>.tar.gz.
    The download is available in the Downloads > ArcGIS Enterprise (Windows) section of My Esri. The downloaded file name is ArcGIS_Coordinate_Systems_Data_Windows_<release_part#>.
  2. Place the downloaded file on each machine in the GIS Server sites in your ArcGIS Enterprise deployment.
    You must use the login that was used to originally install ArcGIS Server.
  3. Extract the installation file from the .tar.gz file.
  4. Run the extracted Setup file to launch the installation wizard.
    ./Setup
  5. Read the message in the Introduction pane of the ArcGIS Coordinate Systems Data Setup wizard and click Next.
  6. Place the installation file on each machine in all GIS Server sites in your deployment.
  7. Browse to the location where you placed the ArcGIS Coordinate Systems Data file, and double-click it to start the installation process.
  8. Accept the destination folder to which files are extracted and placed in a folder named CoordinateSystemsData, or click Browse to select a different destination.
    The default destination folder for the CoordinateSystemsData folder and files is <System Drive>\Users\<username>\Documents\ArcGIS <version>.
  9. Click Next.
    A message indicates when the files have been successfully extracted, and the Launch the setup program check box is checked by default.
    To install the software later, uncheck the Launch the setup program check box and click Close. When you're ready to install, browse to the CoordinateSystemsData folder in the destination you specified in the previous step, and double-click Setup.exe.
  10. Click Close.
  11. In the first window of the setup wizard, click Next.
  12. Review the license agreement and choose an option:
    • If you agree to the terms, click the option to accept the agreement and click Next.
    • If you do not agree to the terms, click Cancel to exit the installation.
  13. Specify the directory to which the coordinate systems data will be installed, or use the default installation directory. Click Next to proceed.
    By default, the files are installed to the home directory of the user running the installation.
  14. Optionally, select the grids to exclude from the installation, and click Next.
    By default, all coordinate system grids are installed.
  15. Review the installation summary.
    • If you need to change any of the installation settings, click Previous and change the settings.
    • If the installation settings are correct, click Install.
  16. When the installation process completes, click Done to close the ArcGIS Coordinate Systems Data Setup wizard.
  17. Optionally, in the Select Features window, choose the grids to exclude from the installation. Click the corresponding button in the list and choose This feature will not be available.
    If you later require a feature you excluded from the original installation, you can modify the installation.
  18. In the same window, accept the default installation folder location, or click Change to specify a different folder.
    Ensure you selected one of the features to install to enable the option to change installation folders.
  19. Click Next.
  20. Click Install.
  21. When the installation is complete, click Finish.
  22. Restart ArcGIS Server.
Install ArcGIS Coordinate Systems Data from a command window
You can use a command window to install ArcGIS Coordinate Systems Data using the CD.msi file and Microsoft Windows Installer command line parameters.
Tip:
For a list of Windows Installer parameters, type msiexec.exe /? at the command line prompt.
The default installation location is C:\Program Files (x86)\ArcGIS\CoordinateSystemsData. If you use this location, you do not have to provide a value for the INSTALLDIR Windows Installer option.
All of the coordinate system transformation sets are installed by default. To control which ones are installed, use the ADDLOCAL parameter. Set the parameter equal to the set name or a comma-separated list of multiple set names. Refer to the table below for the names of the sets and their descriptions.
In the following example, the Caribbean and South American vertical coordinate system transformation sets are installed to a folder named CoordSys on the C drive on an ArcGIS Server machine. The /qn switch indicates no user interface interaction is required to allow this command to be used in a script.
msiexec.exe /i <setup staging location>CoordinateSystemsData\SetupFiles\CSD.msi
INSTALLDIR="C:\CoordSys" ACCEPTEULA=YES ADDLOCAL=caribbean_vert,south_america_vert  /qn
Coordinate system transformation set names are case sensitive. Provide the name as shown in the tables below.
Geographic transformation files
Name
australia_nz_geo
Grid files for Australia and New Zealand transformations
europe_geo
Grid files required for European transformations
north_america_geo
Grid files required for North American transformations
pacific_geo
Grid files required for Pacific region transformations, including Japan and United States territories
south_america_geo
Grid files required for South American transformations
Vertical coordinate system files
Name
africa_vert
Grid files required for African vertical transformations
australia_nz_vert
Grid files for Australia and New Zealand vertical transformations
caribbean_vert
Grid files required for Caribbean region vertical transformations
europe_vert
Grid files required for European vertical transformations
north_america_vert
Grid files required for North American vertical transformations
pacific_vert
Grid files required for Pacific region vertical transformations, including Japan
south_america_vert
Grid files required for South American vertical transformations
world_vert
Contains the EGM84 and 2.5' x 2.5' EGM2008 world geoid files.
world1x1_vert
Contains the EGM2008 1' x 1' world geoid model file.
Uninstall ArcGIS Coordinate Systems Data
Follow these steps to uninstall ArcGIS Coordinate Systems Data:
  1. Sign in to each machine where ArcGIS Coordinate Systems Data is installed.
  2. Change directories to the ArcGIS Coordinate Systems Data installation directory.
    If you used the default location, this is the /arcgis/coordinatesystemsdata directory in your home directory.
  3. Run ./uninstall_CoordinateSystemsData to launch the Uninstall ArcGIS Coordinate Systems Data wizard.
  4. Click Uninstall on the Uninstall ArcGIS Coordinate Systems Data wizard.
  5. When the uninstallation process completes, click Done to close the Uninstall ArcGIS Coordinate Systems Data wizard.
Modify or remove ArcGIS Coordinate Systems Data
If you require additional coordinate system grids that you did not install initially, you can modify the ArcGIS Coordinate Systems Data installation to install those missing files.
Uninstall ArcGIS Coordinate Systems Data before you install a newer version of ArcGIS Coordinate Systems Data or if you no longer need any of the coordinate systems it provides.
Follow these steps to modify the ArcGIS Coordinate Systems Data installation:
  1. Sign in to the machine as a Windows administrator and open the list of installed software.
    There are multiple ways to access the list of software installed on Microsoft Windows machines, and how you access the list varies by Windows version. If you are unsure how to access the software list, consult the Microsoft documentation for the version of Windows that you are using.
  2. Select ArcGIS Coordinate Systems Data from the software list.
    • To uninstall all components, click Uninstall. When prompted to confirm that you want to uninstall, click Yes.
    • To alter what features are installed, click Modify or Change to access the setup wizard, and proceed with the remaining steps.
  3. Ensure Modify is selected and click Next.
  4. Choose which set of coordinate systems data to add or remove from this machine:
    • To install all coordinate system data, click the drop-down menu next to Coordinate Systems Data and choose This feature, and all subfeatures, will be installed on local hard drive.
    • To install an individual coordinate systems dataset, click the drop-down menu next to the dataset and click This feature will be installed on local hard drive.
    • To remove an individual coordinate systems dataset, click the drop-down menu next to the dataset and click This feature will not be available.
  5. Click Next.
  6. Click Install.
  7. Restart ArcGIS Server.
Add third-party transformation grids
For some grid-based geographic and vertical transformations, ArcGIS Server includes their definitions but does not distribute the grid files due to license restrictions. You must obtain these grid files directly from their third-party provider or government agency. In some cases, you may need to purchase the grid files from their provider.
  • All third-party files must have an existing transformation definition in the ArcGIS software.
  • File names must be unique and must match the grid names as defined in geographic and vertical transformation definitions. Ensure the transformation grid files that you add do not have the same name as other third-party transformation grid files you've added or files installed with ArcGIS Coordinate Systems Data, unless your intent is to overwrite the existing files.
Once you obtain the grid files you require and you have installed ArcGIS Coordinate Systems Data on each machine in the ArcGIS Server site, create subfolders in the pedata directory on each machine in the site.
Sort files into folders by transformation type, region, country, and transformation method name. For example, an NTv2 file should be added in a .../pedata/geographic/<your_region>/<your_country>/ntv2 subfolder and a geoid model can be added to a .../pedata/vertical/<your_region>/<your_country>/geoid subfolder. For detailed instructions, contact your local distributor.
Once you obtain the grid files you require and you have installed ArcGIS Coordinate Systems Data on each machine in the ArcGIS Server site, create subfolders in the pedata folder in the installation location on each machine in the site.
Sort files into folders by transformation type, region, country, and transformation method name. For example, an NTv2 file should be added into a ...\pedata\geographic\<your_region>\<your_country>\ntv2 subfolder and a geoid model can be added to a ...\pedata\vertical\<your_region>\<your_country>\geoid subfolder. For detailed instructions, contact your local distributor.
After you place the files on the machines in the ArcGIS Server site, restart ArcGIS Server.
