ArcGIS requirements for using Oracle
ArcGIS Enterprise and ArcGIS Pro support connections to Oracle databases and enterprise geodatabases in Oracle.
Tip:
See the Esri Supported Environment Policy for information about certification and support of hardware, operating systems, databases, and other 3rd-party technologies used with ArcGIS.
The information below applies to ArcGIS Enterprise 12.2 and ArcGIS Pro 3.8.
Supported database versions
The following versions of Oracle Standard 2 (SE2) and Enterprise Edition (EE) are the minimum certified and supported with ArcGIS. Newer Oracle updates on these versions, including patches, are supported.
  • Oracle 26ai 23.26.1.0.0 (Linux only)
  • Oracle 19c (64 bit) 19.3.0.0
Jump to information about Oracle Patch Support
Supported operating systems
If your database management system is installed where ArcGIS products are installed, the operating system must meet the ArcGIS product system requirements as well as the operating system requirements for your Oracle version.
If your database is not installed on the same server as an ArcGIS product, see the Oracle documentation for operating system requirements for your Oracle version.
Additional requirements for the ST_Geometry shape library
Esri supports the following operating systems when you use the ST_Geometry shape library and configure Oracle external procedure (extproc).
  • Red Hat Enterprise Linux (RHEL) Server 9
  • Oracle Linux 9
  • SUSE Linux Enterprise Server (SLES) 15
  • IBM AIX (64 bit) 7.2
  • Oracle Solaris (64 bit) 11.4
  • Windows Server 2025 Standard and Datacenter
  • Windows Server 2022 Standard and Datacenter
  • Windows Server 2019 Standard and Datacenter
Windows 11 Pro and Enterprise is supported for development environments.
When the ST_Geometry shape library is on Windows, you need the latest Microsoft Visual C++ Redistributable for Visual Studio 2015, 2017, 2019, and 2022 installed on the Oracle database machine. See the latest supported Visual C++ downloads from Microsoft support for more information.
Updates or service packs for these operating system versions are supported unless otherwise stated. The operating system version and updates must also be supported by the operating system provider.
Support for the Oracle Exadata Database Machine is based on Oracle guidance that original equipment manufacturer (OEM) software that supports both Oracle Linux and Oracle real application clusters (RAC) is compatible with Oracle Exadata.
Database requirements/limitations
Be aware of the following limitations:
  • In an Oracle multitenant architecture, you can create geodatabases in pluggable databases only.
  • Branch versioning is not supported in user-schema geodatabases.
  • The Oracle Text component must be installed. The Text component is installed by default in Oracle; however, if you did not perform a default installation, the Text component may not have been installed.
  • When you use a database connection file (.sde) to access Oracle data in ArcGIS Pro, you can only edit data that is registered with the geodatabase. To edit database data, publish an editable web feature layer that references the database data, and edit through the web feature layer.
Oracle database patch support
See Oracle Support for all Oracle patch set (and Interim Patch) documentation and installation instructions. Esri recommends making a full backup of your Oracle database prior to applying any Oracle patch sets or interim patches. If functionality that was working prior to applying the Oracle patch set or interim patch stops working, return to the previous version of Oracle. Contact Oracle support as needed.
Cloud support
See ArcGIS requirements for using databases in the cloud for information about support for database services and databases deployed in the cloud.
Software required to connect to Oracle
Your client machine (for example, the one running ArcGIS Pro or ArcGIS Server) must have the appropriate database client files installed for the RDBMS you are using. These client files are available from their respective RDBMS vendors. See Database clients for more information.
It is recommended that ArcGIS clients use the newest Oracle client supported for the Oracle database version to which you connect.
You can download a copy of the Oracle Instant Client from My Esri.
