Backup utility
The Backup utility creates a backup of your ArcGIS Server site configuration. The backup preserves information about your services and settings. It is stored as an .agssite file. Use the Restore utility if you need to apply the backup to return your site to its original state.
See Backing up and restoring your ArcGIS Server site configuration to learn more about the backup and restore capabilities of ArcGIS Server.
Parameters
Parameter |
Details |
-u |
The name of an ArcGIS Server user who will execute the utility. The user must have the appropriate level of privileges to execute the action. If your site is configured with web-tier authentication, specify a built-in user, such as the primary site administrator account. |
-p |
The password of the user who is specified with the -u parameter. |
-s |
The URL of the site, in one of the following formats:
If your site is configured with web-tier authentication, you'll need to specify the local URL to your site. |
-f |
The path to a folder where the backup will be placed as an |
-h |
Prints help for the utility. |
--ignoressl |
An optional parameter to disable SSL certification verification. |
-a |
An optional property that specifies the location of a properties file, for instance, An optional property that specifies the location of a properties file, for instance,
Examples
The following example creates a backup in a folder named mybackups:
<ArcGIS Server installation location>/arcgis/server/tools/admin/backup -u admin -p admin -s https://gisserver.example.com:6443 -f /tmp/mybackups
The default python.exe location is installed at: C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\python.exe
<Python installation location>\python.exe "C:\Program Files\ArcGIS\Server\tools\admin\backup.py" -u admin -p admin -s https://gisserver.example.com:6443 -f "d:\mybackups"
