Configure the organization to geocode addresses
In ArcGIS Enterprise, you can use a locator to turn addresses or place-names into points on the map.
Add geocode services in ArcGIS Enterprise
To turn addresses into points on the map in your organization, you must add a geocode service to your organization and configure it as a utility service. You can configure and use the ArcGIS World Geocoding Service, but this requires ArcGIS Online credits to do batch geocoding. Alternatively, you can publish your own locator as a geocode service to ArcGIS Enterprise and use it.
See Configure utility services for more information about setting a locator in your organization to enable geocoding. For information about configuring the service, see the next sections.
Configure ArcGIS World Geocoding Service for ArcGIS Enterprise
To configure ArcGIS World Geocoding Service for ArcGIS Enterprise, complete the following steps:
  1. Sign in to your organization as an administrator.
  2. Go to the Organization tab, click Settings, and click ArcGIS Online.
  3. Check the Geocode check box and provide your ArcGIS Online username and password.
    Any time ArcGIS World Geocoding Service is used for batch geocoding in this organization, credits are deducted from the account of the ArcGIS Online user you specify on this dialog box.
  4. Click Configure.
The ArcGIS World Geocoding Service must be configured to allow users to create locator views. If ArcGIS World Geocoding Service is deleted, locator views no longer function. If you configured ArcGIS World Geocoding Service before upgrading to ArcGIS Enterprise 10.6, you must disable and re-enable the utility service to support locator views. To configure your own locator in ArcGIS Enterpriseinstead of using a locator view, see the section below.
Configure your own locator for ArcGIS Enterprise
To configure your own locator for ArcGIS Enterprise, complete the following steps:
  1. Create a locator in ArcGIS Pro using your data.
  2. Share a locator from ArcGIS Pro and configure the properties of the locator service in ArcGIS Pro.
  3. Configure the shared locator for your organization. Go to Organization > Settings > Utility Services.
