Configure sync settings
The sync method for your collaboration workspace determines when content will be sent to participating organizations. This includes new items shared with the groups participating in the distributed collaboration as well as updates to existing items. The two methods for how content can be shared are as follows:
Immediate sync
Scheduled sync
When an ArcGIS Enterprise guest organization joins a group to a collaboration workspace, immediate sync is enabled by default and scheduled syncs are configured to repeat every 24 hours. When the collaboration host is an ArcGIS Enterprise organization, the host's workspace is configured to sync content immediately by default. When the collaboration host is an ArcGIS Online organization, immediate sync is not supported. Guest organizations configure the sync settings for a workspace.
Collaboration guests with the Receive access mode will not see the immediate sync settings. Your collaboration access mode (Send, Receive, or Send and Receive) can only be set by the collaboration host.
During a sync, only new content and the deltas for existing content will be synced with other participants' groups.
Immediate sync
As an ArcGIS Enterprise participant, if your access to a collaboration workspace is Send or Send and Receive, you can choose to enable immediate syncs. When immediate sync is enabled, newly shared content or content that has been unshared from collaboration groups is updated for participants right away. Updates made to items already shared—such as changes to item details, saving a web map, saving or publishing a web app—are also sent as soon as they are saved. However, data edits (for example, adding, deleting, or updating features in a layer) are not synced immediately.
If a scheduled sync event is in progress, sync immediately events will be skipped for the same collaboration workspace and participant.
Immediate sync is not available for content shared from ArcGIS Online collaboration workspaces. The content will be synchronized at the sync schedule set for the ArcGIS Enterprise collaboration workspaces.
Scheduled sync
If you use scheduled sync, collaboration groups are compared for differences at the scheduled interval. New or updated content from groups where the participant access mode is Send or Send and Receive will be sent to those whose access mode is Receive or Send and Receive.
Sync schedules are set at the workspace level by each guest, allowing you to choose a different schedule (from 1–24 hours) for each workspace in the same collaboration. By default, the interval for scheduled sync is set to check for and send changes every 24 hours. The minimum sync interval you can set is 1 hour.
If a guest owns the source layer, edits are synchronized with participants according to the established sync schedule. If the guest is not the owner of the source layer, the established sync schedule determines when they will receive synchronized edits.
A collaboration host cannot set sync schedules.
If a scheduled sync is still in progress when the next sync is due to start, the next sync is skipped to allow the current job to finish. To modify the sync schedule, edit the collaboration workspace.
Sync behavior of feature layer edits
Feature layer edits are synced based on the configured sync settings and participant access levels.
One-way sync
One-way syncs occur when One-way copies is set as the preferred method for sharing feature layers and views to a collaboration workspace. In one-way syncs, items are shared as copies owned by the recipients. Only edits from the source organization are synced with recipients according to the sync schedules set by the recipients. Edits made by recipients are not synced back to the source and may be overwritten during subsequent syncs.
Two-way sync
Participants with the Send and Receive access mode can enable two-way sync by setting Two-way copies as their preferred method for sharing feature layers and views to a collaboration workspace. In two-way syncs, items are shared as copies owned by the recipients. Edits made by the source organization are synced with recipients, and edits made by recipients are synced back to the source according to the sync schedules set by the recipients.
Caution:
When editing feature layers with two-way sync, the following behaviors apply:
No checks are performed to detect or prevent conflicting edits.
The most recent edit overwrites earlier edits.
To minimize data conflicts, review archived versions of the feature service before making additional edits.
Edit a collaboration workspace's sync settings
Guest organizations can edit a collaboration workspace's sync settings by completing the following steps:
Guest organizations can edit sync settings only for collaboration workspaces to which they have joined a group.
Sign in to the guest organization as a member of the default administrator role or a custom role with administrative privileges to manage the organization's collaborations.
At the top of the site, click Organization and click the Settings tab.
Click Collaborations on the side of the page.
Under the Distributed section, find and select the collaboration that contains the workspace for which you want to edit sync settings. Optionally, do any of the following to help you find the collaboration:
Type search terms in the search box.
Click Status and select a sort type and direction.
The collaboration window appears.
In the Workspaces section, find the workspace for which you want to edit sync settings. Optionally, do any of the following to help you find the workspace:
Click More options
and click Edit workspace
.The Edit workspace window appears.
In the Scheduled sync settings section, configure the collaboration workspace’s sync settings:
Click the Sync start time drop-down menu and specify the time when collaboration items will be synced to other collaboration participants.
Click the Repeat every drop-down menu and select how often the sync will occur.
Optionally, turn on the Enable immediate sync toggle button to immediately sync collaboration items to other collaboration participants. Data edits (for example, adding, deleting, or updating features in a layer) will be synced on schedule.
Click Save.
