Configuring an ArcGIS data license
Some Esri data products require a data license, which you typically apply using an ArcGIS Data License (.sdlic) file. A datalicinstall utility is included with ArcGIS Server to help you add an ArcGIS data license on Linux.
Adding a data license
  1. On the machine hosting ArcGIS Server, navigate to <ArcGIS Server installation directory>/arcgis/server/tools.
  2. Run ./datalicinstall <ArcGIS data license file>.
    If you already have a data license installed for a specific product and need to overwrite the license file, use the -o option when running the tool, for example, ./datalicinstall -o <ArcGIS data license file>.
Once the data license is installed, you can list the new license file name by running ./datalicinstall -l.
Removing a data license
  2. Run ./datalicinstall -u:<ArcGIS data license file>.
For more information about how to use the tool, run ./datalicinstall -h.
This topic is not relevant for ArcGIS Enterprise on Windows.
