Convert Cache Storage Format utility
The Convert Cache Storage Format utility allows you to change the storage format of a map cache from the command line. If the cache was originally stored in the exploded format, it is converted to the compact format. If the cache was originally stored in the compact format, it is converted to the exploded format.
See Edit service caching properties in ArcGIS Server Manager.
Parameters
Parameter
Details
-u
The name of an ArcGIS Server user who will execute the utility. The user must have the appropriate level of privileges to execute the action. If your site is configured with web-tier authentication, specify a built-in user, such as the primary site administrator account.
-p
The password of the user who is specified with the -u parameter.
-s
The URL of the site, in one of the following formats:
  • https://gisserver.example.com:6443
  • https://webadaptorhost.example.com/webadaptorname
If your site is configured with web-tier authentication, you'll need to specify the local URL to your site.
-n
The name of the service whose cache format you want to convert. This is provided using the syntax <Service name>:<Service type>.
-i
The number of instances of the ArcGIS Server CachingTools service to use for the job. See Caching tools and server resources for caching.
-h
Prints help for the utility.
--ignoressl
An optional parameter to disable SSL certification verification.
Example
The following example converts the storage format of a map service named SanDiego.
Legacy:
If you implemented logic that automates the execution of these utilities, you need to update your scripts to remove the Python dependencies. The following are examples:
  • <ArcGIS Server installation location>/arcgis/server/tools/python
  • The .py extension when referring to the name of the command line utility
See the following example for correct usage:
<ArcGIS Server installation location>/arcgis/server/tools/admin/convertcachestorageformat -u admin -p admin -s http://gisserver.example.com:6080 -n SanDiego:MapServer -i 2
<Python installation location>\python.exe "C:\Program Files\ArcGIS\Server\tools\admin\convertcachestorageformat.py" -u admin -p admin -s http://gisserver.example.com:6080 -n SanDiego:MapServer -i 2
