Core server log codes
This table lists the core log codes written by ArcGIS Server and their associated messages. Message variables, such as a folder name, server directory name, cluster name, and so on, will appear as "{0}" or "{1}" in the following log code meanings.
Code
Meaning
6500
Failed to update the log settings on machine ''{0}''. The server machine will be notified of this change when it comes back online.
6501
Failed to retrieve the information of the folder ''{0}''.
6502
Failed to get ArcGIS Server web services message version.
6503
Failed to get ArcGIS Server web services message format.
6504
Failed to retrieve the configuration of the cluster ''default''.
6505
Initialization of the site failed.
6506
Failed to disconnect the site from the configuration store.
6507
Initializing the configuration store.
6508
Initializing the server directories.
6509
Registering the server directory ''{0}''.
6510
Failed to register the server directory ''{0}''.
6511
Failed to unregister the server directory ''{0}''.
6512
Failed to return server directories.
6513
Initializing the server machine.
6514
Creating the cluster ''{0}''.
6515
Cluster ''{0}'' successfully created.
6516
Failed to create the cluster ''{0}''.
6517
Cluster ''{0}'' started successfully.
6518
Failed to start the cluster ''{0}''.
6519
Cluster ''{0}'' stopped successfully.
6520
Failed to stop the cluster ''{0}''.
6521
Protocol for the cluster ''{0}'' was edited successfully.
6522
Failed to edit the protocol for the cluster ''{0}''
6523
Cluster ''{0}'' was deleted successfully.
6524
Failed to delete the cluster ''{0}''.
6525
Failed to retrieve the configuration for the cluster ''{0}''.
6526
Failed to return all cluster configurations.
6527
Failed to remove one or machine machines from the cluster ''{0}'' .
6528
Removed server machine from the cluster ''{0}''.
6529
Added machine ''{0}'' to the cluster ''{0}'' successfully.
6530
Machines were added to the cluster successfully.
6531
Failed to add one or more machines to the cluster ''{0}''.
6532
Creating default system services .
6533
Failed to create the site.
6534
Site created successfully.
6535
Failed to delete the site.
6536
Site deleted successfully.
6537
''{0}'' is joining the site ''{1}''.
6538
Failed to join the site ''{0}''.
6539
Server machine ''{0}'' has been added to the site ''{1}'' successfully.
6540
Failed to update the configuration store.
6541
Failed to configure the server machine ''{0}''.
6542
Server machine ''{0}'' was configured successfully.
6543
Failed to register the server machine ''{0}''.
6544
Server machine ''{0}'' registered successfully.
6545
Server machine ''{0}'' was edited successfully.
6546
Failed to edit the server machine ''{0}''.
6547
Server machine ''{0}'' was unregistered successfully.
6548
Failed to unregister the server machine ''{0}''.
6549
Server machine ''{0}'' started successfully.
6550
Failed to start the server machine ''{0}''.
6552
Server machine ''{0}'' was stopped successfully .
6552
Failed to stop the server machine ''{0}''.
6553
Server object extensions in the file ''{0}'' have been registered.
6554
Failed to register server object extensions in the file ''{0}'' .
6555
Server object extensions in the file ''{0}'' have been unregistered.
6556
Failed to unregister server object extensions in the file ''{0}''.
6557
Folder ''{0}'' was created successfully.
6558
Failed to create the folder ''{0}''.
6559
Folder ''{0}'' was deleted successfully.
6560
Failed to delete the folder ''{0}''.
6561
Failed to return all folder configurations.
6562
Service ''{0}'' was created successfully.
6563
Failed to create the service ''{0}''.
6564
Service ''{0}'' was edited successfully.
6565
Failed to edit service ''{0}''.
6566
Failed to retrieve the status of the service ''{0}''.
6567
One or more services were deleted successfully.
6568
One or more services failed to delete.
6570
Failed to start one or more services.
6571
Service ''{0}'' stopped successfully.
6572
Failed to stop one or more services: {0}.
6573
Web Adaptor {0} has been registered.
6574
Web Adaptor {0} has been unregistered successfully.
6575
Server directory ''{0}'' was registered successfully.
6576
6577
Item '' {0}'' uploaded successfully.
6578
Deleted the item ''{0}'' successfully.
6579
Server directory ''{0}'' was cleaned.
6580
Failed to clean the server directory ''{0}''.
6581
Failed to validate user credentials.
6582
Failed to generate a token for the user.
6583
Security configuration was updated successfully.
6584
Failed to update the security configuration.
6585
Identity store configuration updated successfully.
6586
Failed to update the identity store configuration.
6587
Failed to return the server directory ''{0}''.
6588
Failed to return cluster configuration for the machine ''{0}''.
6589
Service ''{0}'' started successfully.
6589
Failed to return server directories of type ''{0}''.
6590
Failed to return cluster lookup information.
6591
Unable to register the data store ''{0}''.
6592
Failed to create KMZ file.
6593
Server directory with the name ''{0}'' not found.
6594
Error deleting physical path corresponding to the data item ''{0}''.
6595
Failed to return all registered extensions.
6596
Failed to retrieve extensions information.
6597
Failed to get server machine configuration.
6598
Failed to get the status of the server machine ''{0}''.
6599
Failed to get the configuration of the server machine ''{0}''.
6600
Failed to get server machine configurations.
6601
Failed to return default service type information ''{0}''.
6602
Failed to return the service configuration ''{0}''.
6603
Failed to remove cluster references from all services.
6604
Failed to return default service configuration ''{0}''.
6605
Failed to return all services configurations in the folder ''{0}''.
6606
Unable to retrieve ''Security'' resource information.
6607
Unable to retrieve ''System'' resource information.
6608
Unable to retrieve ''Machine'' resource information.
6609
Unable to retrieve ''Token'' resource information.
6610
Unable to retrieve ''Cluster'' resource information.
6610
Unable to retrieve ''Metric'' resource information.
6611
Unable to retrieve data store information.
6611
Could not remove metric configuration ''{0}''
6612
Unable to retrieve ''Service'' resource information.
6612
Metric ''{0}'' was deleted successfully.
6613
Unable to retrieve ''Upload'' resource information.
6613
Failed to delete the metric ''{0}''.
6614
Unable to retrieve ''KML Content'' resource information.
6614
Metric ''{0}'' is currently being configured by another administrative operation. Please try again later.
6615
Unable to retrieve ''Permissions'' resource information.
6615
Creating the metric ''{0}''.
6616
Failed to get the privilege for role ''{0}''.
6616
Metric ''{0}'' successfully created.
6617
Failed to compute the privilege for the user ''{0}''.
6617
Failed to create the metric ''{0}''.
6618
Failed to return security configuration.
6618
Failed to retrieve the configuration for the metric ''{0}''.
6619
Failed to return user store.
6619
A metric by name ''{0}'' does not exist.
6620
Failed to return role store.
6620
Metric ''{0}'' was edited successfully.
6621
Failed to register the Web Adaptor ''{0}''.
6621
Failed to edit the metric ''{0}''
6622
Failed to unregister the Web Adaptor ''{0}''.
6622
Failed to update the configuration for Metrics
6623
Failed to return Web Adaptor configuration ''{0}''.
6623
A metric by the name ''{0}'' already exists.
6624
Initializing security configuration.
6624
Error when gathering metric data.
6625
Failed to return all Web Adaptor configurations.
6626
Failed to upload the item ''{0}''.
6627
Item directory ''{0}'' for uploaded item was not found.
6628
Failed to delete the item ''{0}''.
6629
Failed to return item directory for item ''{0}''.
6630
Failed to return all uploaded items.
6631
Failed to return folder configuration ''{0}''.
6632
Folder ''{0}'' does not exist.
6633
Failed to edit folder ''{0}''.
6634
Failed to register extensions in ''{0}''.
6635
The extension file ''{0}'' cannot be updated because an extension file with the same name exists with different extensions in it. Update does not support registering new extensions or unregistering old ones.
6636
Failed to update extension.
6637
Unable to find uploaded item {0} information.
6638
Failed to retrieve service item information for ''{0}''.
6639
Failed to update service item information for ''{0}''.
6640
Failed to upload ''{0}'' to the service item information for ''{1}''.
6641
Failed to delete service item information for ''{0}''.
6642
Unable to create security config folder.
6643
Failed to start Token service.
6644
Failed to stop Token service.
6645
Configuring local server machine.
6646
checking for expired items in {0}
6647
Unable to remove {0} from server directory {1}.
6648
Job {0} completed and will be removed.
6649
Unexpected error while cleaning {0} server directory.
6650
Unable to get service usage timeout for {0}. Defaulting to server directory timeout.
6651
Directory cleanup removed {0} from {1}.
6652
Unable to read the service ''{0}'' from the configuration store. {1}
6653
Failed to register data source.
6654
Failed to return registered data sources.
6655
REST cache cleared on all server machines.
6656
Failed to clear REST cache on one or more server machines.
6657
Unable to access the log service.
6658
Unable to query for logs on ''{0}''.
6659
Input server directory is not registered with the server.
6660
Unable to remove {0} service subfolder from the input server directory.
6661
Unable to create {0} service subfolder in the input server directory.
6662
Invalid number of instances per process.
6663
Number of instances per process must be 1 for HIGH isolation level.
6664
Number of instances per process must be greater than ''{0}''.
6665
Number of instances per process must be less than ''{0}''.
6666
Cluster protocol applied successfully to cluster ''{0}''.
6667
Failed to apply cluster protocol to cluster ''{0}''.
6668
Failed to clean configuration store. One or more files/folders may be in use.
6669
Java debugging ports have not been specified.
6670
Invalid port range specified for debugging Java extensions.
6671
The selected server directory is currently used by {0} service(s): {1}. You cannot delete this directory until these services are edited to reference a different directory or deleted.
6672
Failed to obtain asynchronous jobs manager.
6673
Failed to delete server directory ''{0}''.
6674
ArcGIS Server is using too many open file handles({0}). Unexpected errors will occur unless the ulimit({1}) is increased. You can edit /etc/security/limits.conf to set the nofile limit.
6675
ArcGIS Server is using {0} file handles out of a total limit of {1}.
6676
Failed to get metadata information of the service.
6677
Incorrect administrator account name.
6678
Incorrect secret answer.
6679
Failed to update account.
6680
Failed to return the users's password change question.
6681
Password for user {0} was successfully reset and written to System directory.
6682
Services Directory successfully enabled.
6683
Services Directory successfully disabled.
6684
Enable Services Directory failed.
6685
Disable Services Directory failed.
6686
Folder ''{0}'' is a pre-configured folder and cannot be deleted.
6687
Service ''{0}'' is required and cannot be deleted.
6688
Delete procedure is successfully launched. The service resources will be cleaned asynchronously.
6689
Service input directory ''{0}'' is in use and can not be deleted.
6690
Service input directory ''{0}'' is successfully deleted.
6691
Server directory ''{0}'' has been successfully edited.
6692
Failed to edit server directory ''{0}''.
6693
REST handler reinitialized.
6694
SOAP handler reinitialized.
6695
Failed to reinitialize REST handler.
6696
Failed to reinitialize SOAP handler.
6697
Cannot write to directory path ''{0}''. Please check that the location is valid and that the ArcGIS Server account has permissions to the location.
6698
Username cannot be null or contain empty spaces.
6699
Password cannot be null or contain empty spaces.
6700
The configuration store at ''{0}'' already contains registered server directories. Ignoring the user request to create server directories at ''{1}''.
6701
Error occurred while merging service properties.
6702
Unable to undeploy the service from ''{0}''. The server may not be running or reachable at this time.
6703
The license of ArcGIS Server at ''{0}'' does not match with the license of the site running at ''{1}''. All the machines in the site are required to have the same license.
6704
The license edition of the server does not permit running and administering the service ''{0}''.
6705
The configuration store location contains server configuration files that are being used by another site.
6706
The specified server directory location ''{0}'' is being used by another site.
6707
Token manager configuration was updated successfully.
6708
Failed to update token manager configuration.
6709
The server cache directory ''{0}'' has been edited. The contents of the old cache directory must be manually copied to the new cache directory ''{1}'' and cached services must be restarted.
6710
Machine ''{0}'' was successfully renamed to ''{1}''
6711
Failed to rename machine ''{0}''.
6712
Stores tile caches used by map, globe, and image services for rapid performance.
6713
Stores indexes of data locations used by the search service.
6714
Stores source files (such as maps and data) for services that you publish.
6715
Stores results and other information from geoprocessing services.
6716
Stores various information generated by services, such as map images.
6717
Stores files that are used internally by the GIS server.
6718
Stores items uploaded to ArcGIS Server during publishing from a remote server.
6719
Stores files used by KML network links published on ArcGIS Server.
6720
The specified configuration store location is not accessible. Ensure that the ArcGIS Server account has read and write access to the location.
6721
Service ''{0}'' is a preconfigured service and cannot be renamed.
6722
Failed to roll back server directory edits.
6723
Server machine ''{0}'' is not reachable. All machines in the site must be reachable for this operation to complete.
6724
ArcGIS Server failed to obtain a host name for ''{0}'' from a domain name server and is unable to proceed with this operation. Please contact your systems administrator to resolve this problem.
6725
Failed to remove certificate ''{0}''
6726
Successfully removed certificate
6727
Enable SSL Failed.
6728
Successfully enabled SSL.
6729
Successfully generated certificate
6730
Failed to generate certificate ''{0}''
6731
Failed to list all certificates ''{0}''
6732
Failed to list certificate ''{0}''
6733
Generate certificate signing request failed ''{0}''
6734
Successfully generated certificate signing request.
6735
Successfully exported a certificate.
6736
Exporting certificate failed.
6737
Successfully imported CA certificate.
6738
Importing CA certificate failed.
6739
Failed to roll back changes made while editing the configuration store.
6740
The machine ''{0}'' was not reachable while performing this operation. The server machine will be notified of this change when it comes back online. If ArcGIS Server is going to continue to be unavailable, remove the machine from the site.
6741
Unable to decrypt request parameters using RSA.
6743
Stores directories and files used internally by ArcGIS Server.
6744
Unable to clean all log files.
6745
Failed to create log directory at {0}. All machines in this site must have the same log directory path and the ArcGIS Server account must have permissions to the path.
6746
Unable to move log files from {0} to {1}.
6747
Machine ''{0}'' cannot access {1} data store(s) registered with the site. Please ensure that the ArcGIS Server account has read and write access to the data store(s).
6748
Failed to migrate the configuration store from ''{0}'' to ''{1}''.
6749
Error while starting AppServer. Required port '{0}' already in use.
6750
Cannot dissociate owner. Owner must unregister
6751
Thread is not the owner of the context
6752
Could not find ''{0}'' file. This file contains admin default properties.
6753
Missing key ''{0}'' in the properties file.
6754
Local server machine ''{0}'' has not been configured.
6755
Could not start application server within stipulated time.
6756
Could not stop application server within stipulated time.
6757
Could not delete service archive file ''{0}''. Undeploy failed.
6758
Failed to remove SSL configuration: ''{0}''
6759
Failed to restart tomcat. Please check the log for more details.
6760
The requested port ''{0,number,#}'' is not available/free on this machine.
6761
Cannot assign port to the application server as it exceeds the bounds.
6762
The machine does not have a valid license. Please authorize using the Software Authorization for ArcGIS Server wizard.
6763
The machine does not have a valid license. Please authorize ArcGIS Server by running the authorizeSoftware script found under ''{0}''.
6764
Machines licensed at the Workgroup level are not allowed to join another site
6765
''{0}'' is not accessible.
6766
There is no site created on ''{0}''.
6767
Unsupported configuration store type ''{0}'' for permission store.
6768
Local machine ''{0}'' is not participating in any Site. Please create a new Site or join an existing Site.
6769
Invalid path ''{0}''. Path must be a directory
6770
Configuration store directory path must be an absolute path.
6771
Unsupported configuration store type ''{0}''.
6772
The destination configuration store appears to be part of another Site.
6773
Could not update configuration store connection on one or more machines within stipulated time. Please check the log for details.
6774
6775
This operation is not supported when Admin client is directly accessing the configuration store.
6776
This operation is not supported when connection to the Admin is through an URL.
6777
The machine name ''{0}'' does not compare with its fully qualified domain name ''{1}''."
6778
Could not restart all clusters in this site within the stipulated time. Please check the log for details.
6779
Server machine ''{0}'' is participating in another cluster.
6780
Machine ''{0}'' is not a registered server machine.
6781
Server machine ''{0}'' is not reachable at this time.
6782
Server machine ''{0}'' does not belong to cluster ''{1}''.
6783
A 'System' needs to be configured for the Server.
6784
A cluster by the name ''{0}'' already exists.
6785
Server machine ''{0}'' added to the cluster is not a registered server machine.
6786
Failed to apply the clustering protocol to one or more machines.
6787
TCP cluster port number ''{0,number,#}'' is already under use.
6788
UDP multicast port number ''{0,number,#}'' is already under use.
6789
UDP multicast address ''{0}'' is already under use.
6790
The multicast address and port is currently under use.
6791
Unable to find a valid cluster protocol.
6792
A cluster by name ''{0}'' does not exist.
6793
Server machine ''{0}'' is not registered with the Site.
6794
Multicast address is not within valid range. Valid multicast addresses must be between 225.0.0.0 and 238.255.255.255.
6795
JSON object for ClusterProtocol is missing required attribute ''{0}''.
6796
UDP Multicast port should be a positive integer ''{0,number,#}''.
6797
TCP cluster port should be a positive integer ''{0,number,#}''.
6798
Cluster protocol of type ''{0}'' is not supported.
6799
No response from remote admin.
6800
Could not connect to the ArcGIS Server on machine ''{0}''.The ArcGIS Server service on that machine may not be running or the machine may not be reachable at this time.
6801
Server machine ''{0}'' returned an error. ''{1}''
6802
No write access to upload directory ''{0}''
6803
Server directory of type ''{0}'' has not been configured on the server.
6804
Items with these extensions are not supported.
6805
Unable to delete directory for data item ''{0}''
6806
Unable to delete kmz file ''{0}''
6807
Data item ''{0}'' does not exist.
6808
kmz file with name ''{0}'' already exists
6809
Input part ''{0}''inputPart + "' does not exist.
6810
Item ''{0}'' has not been registered.
6811
Could not find Rest Handler configuration parameters.
6812
Could not clear REST cache on machine : ''{0}''
6813
ServiceType can not be null.
6814
Failed to clear REST cache on one or more server machines. Please check the log for more details.
6815
Could not reinitialize Rest handler on machine ''{0}''.
6816
Server is not licensed.
6817
Failed to read server license file
6818
Querying for licenses failed
6819
Directory name can not be null.
6820
Physical path can not be null.
6821
Directory type can not be null.
6822
Server Directory Type one of the following values : ''{0}''
6823
Cleanup Mode should be one of the following values : ''{0}''
6824
Invalid maxFileAge value ''{0}''. Max File Age should be a positive integer.
6825
Unable to access the server directory ''{0}''
6826
Failed to register the server directory ''{0}''. Only one directory can be registered for the ''{1}'' type.
6827
Server directory path cannot be empty.
6828
A server directory with the name ''{0}'' is already registered with the server.
6829
A server directory with physical path ''{0}'' is already registered with the server.
6830
Only one directory can be registered for the ''{0}'' type.
6831
Could not create sub-directory under System directory ''{0}'' .
6832
No write access to the directory ''{0}''
6833
Could not validate server directory paths.
6834
Directory with this name : ''{0}'' does not exist.
6835
Invalid path ''{0}'' . Path must be a directory
6836
Server directory path must be an absolute path.
6837
''{0}}' is currently being used by the server directory type ''{1}''
6838
Server directory ''{0}'' does not exist
6839
unimplemented
6840
We detected that the configuration store location that you specified contains server configuration files that will not work in the current release of ArcGIS Server. Please provide a different location for the configuration store or delete the folder ''{0}'' and recreate the site.
6841
Error saving configuration store version to file ''{0}''
6842
Could not create directory path ''{0}''. This is required to maintain the Site configuration. Please check that the location is valid and that the ArcGIS Server account has permissions to the location.
6843
Unable to obtain a connection to the config-store.
6844
Unable to access the configuration store on ''{0}''.
6845
Unable to access directory path ''{0}'' on the shared configuration store.
6846
Cannot write to directory path ''{0}'' on the shared configuration store.
6847
Unable to validate the configuration store connection.
6848
Site stamp cannot be null in the ConfigStoreConnection.
6849
Unable to clean up configuration store directory ''{0}''.
6850
ArcGIS Server Site is currently being configured by another administrative operation. Please try again later.
6851
Server machine ''{0}'' is currently being configured by another administrative operation. Please try again later.
6852
Another administrative operation is currently accessing the store. Please try again later.
6853
Cluster ''{0}'' is currently being configured by another administrative operation. Please try again later.
6854
Service ''{0}''.''{1}'' in folder ''{2}'' is currently being configured by another administrative operation. Please try again later.
6855
AdminServiceURL property for a new server machine configuration cannot be null.
6856
Could not remove server machine ''{0}''.
6857
Could not remove cluster configuration ''{0}''
6858
Could not delete service ''{0}''.''{1}'' in folder ''{2}''
6859
Another administrative operation is currently writing the service configuration. Please try again later.
6860
Uploaded content ''{0}'' not found at ''{1}'' for the service ''{2}''
6861
Unable to get Metadata information.
6862
Metadata information is not found
6863
Invalid Folder Path.
6864
Folder path cannot contain relative path such as .. or .
6865
6866
Could not create folder ''{0}'' in the configuration store.
6867
Could not remove folder configuration.
6868
System or Input Directory can not be deleted.
6869
Could not delete server directory with name ''{0}''.
6870
Could not remove uploaded item configuration ''{0}''.
6871
Could not delete file ''{0}''.
6872
Error saving the logSettings to file
6873
Error loading the dataspace from file.
6874
Error saving the dataspace to file.
6875
Could not acquire write lock on the security configuration file.
6876
User ''{0}'' already exists.
6877
folder ''{0}'' is currently used by another administrative operation. Please try again later.
6878
The store implementation is not connected to a configuration store. Please call the 'connect' method before invoking any other method.
6879
Unable to get list of certificates.
6880
Unable to save SSL certificate.
6881
Certificate does not exist.
6882
Unable to export certificate.
6883
Unable to delete SSL certificate.
6884
6885
6886
Unable to configure SSL certificate.
6887
6888
Missing elements ''{0}'' or ''{1}''
6889
Unable to delete configuration store connection file ''{0}''
6890
Could not find connection file. ArcGIS Server Site may not have been configured.
6891
Connection file does not contain key ''{0}''
6892
JSONObject is missing required parameter: ''{0}''
6893
''{0}'' should be one of the following values : ''{1}''
6894
Machine security credentials cannot be null or empty.
6895
JSON object for ''{0}'' is missing required attribute ''{1}''
6896
Invalid item path
6897
Path and type must be specified.
6898
Cannot modify object after it has already been built.
6899
Item path not specified.
6900
Item type not specified.
6901
Invalid item type.
6902
Error converting the Dataspace to XML
6903
Data store of type ''{0}'' can not be validated.
6904
KML directory has not been configured on the server.
6905
'machines' contains no machines that belong to this site.
6906
Error consolidating logs from server machines
6907
Errorreports directory not found
6908
Cannot register a machine that belongs to another Site.
6909
Invalid port value ''{0,number,#}''. Port should be a positive integer.
6910
Server machine ''{0}'' is not a local server machine.
6911
Could not delete machine configuration file ''{0}''.
6912
Error while assigning specific port. Port already in use. Port number = ''{0,number,#}''.
6913
Port assignment failed as it exceeds the upper bound set on the machine.
6914
Could not find machine configuration file ''{0}''. Server machine may not have been configured.
6915
Another process or application is currently accessing the store. Please try again later.
6916
Incorrect machine name: ''{0}''
6917
Start time should be of the format : yyyy-mm-ddThh:mm:ss
6918
Unable to save thumbnail data from metadata to iteminfo. Thumbnail image format is not supported
6919
Unknown thumbnail file type
6920
A ''{0}'' directory has not been configured on the ArcGIS Server.
6921
AN ''{0}'' directory has not been configured on the ArcGIS Server.
6922
A configuration factory operation ''{0}'' timed out.
6923
Service Extension can not be created.
6924
Service Extension Type ''{0}'' is not registered as extension for Server Object Type ''{0}''
6925
Service Type ''{0}'' is not registered with the Server.
6926
Item ''{0}'' not found.
6927
''{0}'' does not contain any valid extensions.
6928
The server object extension could not be registered on one or more machines.
6929
Could not find an SOE configuration file.
6930
Could not find extension ''{0}'' in configuration store.
6931
An extension with name ''{0}'' is already registered for service type ''{1}''
6932
''{0}'' contains an extension with an invalid Extension Id ''{1}''. Extension Ids that start with 'esri' are reserved for internal use.
6933
Library ''{0}'' not found in ''{1}''
6934
Resource ''{0}'' not found in ''{1}''
6935
Property pages not found.
6936
Unable to find ''{0}'' for updating.
6937
The server object extension could not be unregistered from one or more machines.
6938
Could not find file ''{0}''
6939
Invalid token, ClientID does not match.
6940
Did not find any parent server object types listed in the configuration.
6941
Could not create directory ''{0}'' for service under output directory.
6942
Service can not be created
6943
Extension can not be added. Extension Type ''{0}'' is not registered with the Service type ''{1}''.
6944
Invalid number of instances per process. Must be 1 for HIGH isolation level.
6945
Invalid number of instances per process. Must be greater than 0.
6946
Invalid number of instances per process. Must be less than ''{0}''.
6947
Time must be represented in HH:MM 24 hour clock format.
6948
''{0}'' is not a valid extension type for ''{1}''.
6949
Folder ''{0}'' already exists.
6950
Number of services of type ''{0}'' reached the limit of ''{1}'' per site.
6951
Cannot rename or change the type of an existing service.
6952
Cluster ''{0}'' on which the service is to be deployed does not exist.
6953
Could not create output directory service at ''{0}''.
6954
Cannot rename - service ''{0}'' does not exist.
6955
Cannot rename - service ''{0}'' already exists.
6956
Service ''{0}'' is not deployed to any cluster.
6957
List of services to start is empty.
6958
Index Directory is not registered.
6959
Register data source is only supported on services of type search
6960
Service Properties can not be null.
6961
Get Indexing Status is only supported on search service
6962
Service ''{0}''.''{1}'' exists in folder ''{2}''.
6963
6964
A cluster configuration by name ''{0}'' does not exist.
6965
Could not undeploy services from one or more machines. ''{0}''.
6966
Service ''{0}''.''{1}'' does not exist in folder ''{2}''.
6967
Invalid token.
6968
Input Values for check expiration is incorrect.
6969
NumberFormatException in parsing token date value ''{0}''.
6970
Could not lookup attributes in domain controller configuration.
6971
Could not lookup attribute ''{0}'' in domain controller configuration.
6972
User store configuration is missing 'class' attribute.
6973
Could not find user account in the Identity Store.
6974
Failed to log in. Invalid username or password specified.
6975
One or more server machines could not be updated with new token manager configuration.
6976
Missing authentication tier in the security configuration
6977
Missing Web Adaptor shared secret in the configuration store.
6978
Missing authentication mode in the security configuration.
6979
One or more server machines could not be updated with new security configuration.
6980
One or more server machines could not be updated with new user or role store configurations.
6981
Incorrect user name or the user store is a read-only store.
6982
The user ''{0}'' is not a primary administrator or user account does not exist in the user store.
6983
A secret question has not been assigned to this account.
6984
A system directory is required to reset user passwords.
6985
Passwords can be reset only for administrators or publishers.
6986
Missing configuration property ''{0}''.
6987
Could not decrypt token. Token may not be valid.
6988
Token Expired.
6989
Expiration time is invalid.
6990
The expiration time requested is greater than maximum expiration time of ''{0}'' minutes.
6991
Client ID is required for long expiration tokens.
6992
Missing client ID.
6993
Incorrect username or old password.
6994
User ''{0}'' does not exist.
6995
Role ''{0}'' already exists.
6996
Role ''{0}'' does not exist.
6997
Role ''{0}'' could not be found.
6998
User account does not exist for ''{0}''.
6999
Answer to secret question does not match.
7000
Another process is currently updating permissions. Please try again later.
7001
At least DataItemType must be specified.
7002
Invalid ''{0}'' value. ''{0}'' should be 0 or 1.
7003
Invalid ''{0}'' value. ''{0}'' should be between ''{1}'' to ''{2}''.
7004
Invalid ''{0}'' value. ''{0}'' should be numeric.
7005
Invalid item ID ''{0}''.
7006
Item ''{0}'' has been uploaded but could not found in the data directory.
7007
Admin URL ''{0}'' is not reachable from ''{1}''. For more information, see the ArcGIS Server help topic "About adding a GIS server to a site". You can access this topic in the table of contents by navigating to Administering ArcGIS Server > Common administrative tasks > Adding a GIS Server to a site.
7008
Cannot start machine as it does not participate in any cluster.
7009
One or more server machines could not be stopped.
7010
One or more server machines could not be started.
7011
Can't register a machine to a site licensed at the workgroup level.
7012
Server machine ''{0}'' is already registered with the Site.
7013
The machine being registered does not have a valid license.
7014
Server machine ''{0}'' is not local to machine ''{1}''.
7015
Could not generate a default Admin URL. Please check if the Admin is running or provide the URL explicitly.
7016
Class ''{0}'' does not implement UserStore interface.
7017
Missing property ''{0}'' for SQL Server user store.
7018
''{0}'' store configuration is missing ''{0}'' attribute.
7019
Class ''{0}'' does not implement ''{1}'' interface.
7020
Windows users and groups are only supported on the Windows platform.
7021
7022
The configuration store is not a filesystem based store.
7023
Input argument ''{0}'' cannot be null.
7024
The 'startIndex' and 'pageSize' parameters must be non-negative.
7025
The 'startIndex' parameter cannot be greater than total results.
7026
Could not find a ''{0}'' by name ''{0}'' in the configuration store.
7027
Cannot update LDAP. This is a read-only identity store.
7028
Missing property ''{0}'' or ''{1}'' in configuration.
7029
Missing property ''{0}'' in configuration.
7030
Could not find role entry ''{0}''.
7031
Input parameter 'ldapURL' is not a valid LDAP URL.
7032
Unknown server directory type ''{0}''
7033
Cannot add service statistics as services are different.
7034
Could not load domain controller library.
7035
PSA name conflicts with an existing user in new user store.
7036
New PSA name conflicts with an existing user.
7037
Unable to get services directory info from store
7038
There are no machines in the ''{0}'' cluster. Add a machine to the cluster or reconfigure the service to use a cluster that contains a machine and then restart the service.
7039
Service ''{0}'' is not assigned to a cluster.
7040
Unable to start the service on ''{0}'', the server may not be running or reachable at this time.
7041
Service startup timeout.
7042
Failed to start one or more services. ''{0}''
7043
Missing Geronimo directory in the repository.
7044
Stopping the service ''{0}'' on machine ''{1}''.
7045
Validating licenses.
7046
Creating the configuration store at ''{0}''
7047
Site creation interrupted. Rolling back.
7048
Copying site configurations to the new configuration store.
7049
Restarting all clusters in the site.
7050
Updating the configuration store was interrupted.
7051
Updating configuration store connection on ''{0}''.
7052
Creating server directories at ''{0}''.
7053
Configuring server directories at ''{0}''.
7054
Configuring the logging framework.
7055
Creating administrator account.
7056
Configuring the default cluster.
7057
Disconnecting the site from the configuration store.
7058
Deploying default services.
7059
Starting GIS services.
7060
Configuring server permissions.
7061
Creating and initializing the configuration store.
7062
Generating default SSL certificate.
7063
Configuring the GIS server machine.
7064
Checking and validating server licenses.
7065
Registering server extensions.
7066
Validating machine ''{0}''.
7067
Machine ''{0}'' does not exist.
7068
'localhost' is not acceptable as a valid machine name.
7069
Machine ''{0}'' is still reachable.
7070
Host ''{0}'' not reachable.
7071
Deploying services on machine ''{0}''.
7072
Starting server on machine ''{0}''.
7073
SecurityConfig is null , Unable to get an instance of security config.
7074
Redeploying webapps ''{0}''.
7075
Error in Start_TokenService ''{0}''.
7076
Error in Stop_TokenService ''{0}''.
7077
Invalid or null URL or ContextName or action.
7078
JSON object for Service is null.
7079
''{0}'' is not a valid server object type name registered with the server.
7080
Unknown capability ''{0}''. Only ''{1}'' are supported.
7081
Minimum instances per node should greater than or equal to 0.
7082
Maximum Instances per node should be greater than 0.
7083
Minimum instances per node should not be greater than maximum instances.
7084
Maximum wait time should be greater than 0.
7085
Maximum startup time should be greater than 0.
7086
Maximum idle time should be greater than 0.
7087
Maximum usage time should be greater than 0.
7088
Load Balancing should be one of the following values : ''{0}''
7089
Isolation level should be one of the following values : HIGH or LOW.
7090
Instances per container should be greater than 0.
7091
Configured state should be one of the following values : STARTED or STOPPED.
7092
Recycle interval should be a positive integer.
7093
Keep alive interval should be an integer.
7094
Saving edits to the configuration store.
7095
The service editing operation was interrupted.
7096
Starting the service ''{0}'' on machine ''{1}''.
7097
Site creation rollback failed.
7098
Failed to update KeyStore password.
7099
Successfully updated KeyStore password.
7100
Successfully copied SSL configuration.
7101
Failed to copy SSL configuration files.
7102
Failed to delete files and folders from the deploy directory of the application server.
7103
Failed to delete files and folders from the services repository of the application server.
7104
Polling of web server has failed after stipulated amount of time.
7105
Invalid primary site administrator credentials.
7106
The upload operation failed because it exceeded the maximum size of the uploaded item configured for the service.
7107
Interrupted while updating log configuration on remote hosts.EXCEEDED_UPLOAD_SIZE=The upload operation failed because it exceeded the maximum size of the uploaded item configured for the service.
7108
Unable to get the number of error reports on ''{0}''. ArcGIS Server on that machine may not be running or the machine is not reachable at this time.
7109
Security Config is currently being configured by another process. Please try again later.
7111
The primary site administrator account has been disabled.
7112
The primary site administrator account cannot be disabled as it is the only account with the administrator privilege. You will need to configure at least one additional administrator account to disable the primary site administrator account.
7113
The application server configuration was found to be corrupted. Beginning repair.
7114
The application server configuration was successfully repaired.
7115
Could not re-start GIS services on the server. Please re-start the services manually.
7116
Join site rollback failed.
7117
Validating configuration store connection.
7118
Validating existing SSL configuration.
7119
Service ''{0}'' cannot be started.
7120
''{0}'' is not a valid admin URL.
7121
Could not configure the identity store as one or more of the supplied parameters is incorrect. Verify that you can connect to the identity store outside of ArcGIS Server using the same parameters.
7122
The user ''{0}'' exceeded the maximum number of failed login attempts allowed by ArcGIS Server and has been locked out of the system.
7123
The primary site administrator ''{0}'' exceeded the maximum number of failed login attempts allowed by ArcGIS Server and has been locked out of the system.
7124
Failed to log in. The user ''{0}'' exceeded the maximum number of failed login attempts allowed by ArcGIS Server and has been locked out of the system.
7125
Failed to log in. The primary site administrator ''{0}'' exceeded the maximum number of failed login attempts allowed by ArcGIS Server and has been locked out of the system.
7126
7127
Unable to connect to the identity store using SSL. ArcGIS Server will revert to using a non-SSL connection to the identity store and credentials will be sent in clear text. In order to use SSL, verify that your identity store has SSL enabled.
7128
The server was unable to access the SSL store. Creating a new SSL store.
7129
Failed to create the SSL store.
7130
Enabled HTTP on server as both HTTP and HTTPS cannot be disabled. If you intend to change these settings, please refer to the Server Help.
7131
Active Directory details/statistics: {0}
7132
One or more properties required for Portal federation are missing. Please check the properties and try again.
7133
Cannot replace - service ''{0}'' does not exist.
7134
Service ''{0}'' is a preconfigured service and cannot be replaced.
7135
Cannot replace - configurations have different services: ''{0}'', ''{1}''.
7136
Cannot replace - output configuration already exists: {0}.
7137
Cannot replace - unsupported service type: {0}.
7139
Invalid file path ''{0}''.
7140
Failed to make a copy of the configuration store and server directories in the current site before starting the import operation. This operation cannot proceed.
7141
The site was rolled back and its configuration were moved to ''{0}'' and server directories were copied to ''{1}''. You will need to edit the locations of the configuration store and server directories in order to add more machines to this site. Please check the logs for additional information for why a rollback was required.
7142
Failed to copy artifacts contained in the ArcGIS Site bundle into location ''{0}''.
7143
Incoming site configurations copied to location: ''{0}''.
7144
The configurations of the site that is being restored were copied to ''{0}'' because there were problems deleting the old site configurations at location ''{1}''. The site restoration was successful and the site is functional. Use Manager to edit the configuration store and server directories, if required.
7145
The configurations of the site that is being restored were copied to ''{0}''. Since this location is local to machine ''{1}'', you must move the configuration store to a network share to register new machines to the site.
7146
Failed to copy server directory data to location: ''{0}''.
7147
Server directory data successfully copied to location : ''{0}''.
7148
Failed to copy server directory data of type ''{0}'' to location ''{1}'' and as a consequence import operation cannot proceed. Please ensure ArcGIS Server has write access to ''{2}'' before trying this operation again.
7149
Configuration store of live site was backed up to location: ''{0}''.
7150
Server directories of the live site were backed up to location: ''{0}''.
7151
Failed to backup the configuration store of the live site to location : ''{0}''. Import operation cannot proceed.
7152
Failed to backup the server directory data of the live site to location : ''{0}''. Import operation cannot proceed.
7153
The incoming site bundle is invalid. ''{0}''.
7154
Failed to change configuration store connection to location: ''{0}''.
7155
Identity store validation failed. Unable to connect to the user store. Please refer to the logs for more details. Please update user/role store settings using Manager (Security tab) for the site to correctly function.
7156
Identity store validation failed. Unable to connect to the role store. Please refer to the logs for more details. Please update user/role store settings using Manager (Security tab) for the site to correctly function.
7157
Security configuration validation is complete.
7158
Data store validation is complete.
7159
Failed to clear REST/SOAP cache. You can clear the REST cache manually through the /admin/system/handlers/rest/cache resource or by restarting ArcGIS Server.
7160
Failed to start cluster ''{0}''.
7161
Successfully cleared REST and SOAP cache.
7162
The machine ''{0}'' was not accessible during the import operation. For this reason, this machine is no longer part of the ArcGIS Server site. You may need to manually add this machine to the site.
7163
Failed to create service ''{0}''.
7164
Failed to create service ''{0}''. Putting it in the configuration store and continuing.
7165
The Primary site administrator account (PSA) was enabled during the import operation to simplify the process of fixing up the site after the import operation completes. The PSA can be disabled using the ArcGIS Server site administrator APIs.
7166
Failed to import log configuration.
7167
Failure while unstamping server dirs.
7168
Failed to unregister extension.
7169
Unable to stop clusters. Import operation cannot proceed.
7170
''{0}'' was unregistered but isn't accessible. It may not get registered back into the site during the import operation.
7171
Unable to register machine ''{0}''. Removing it from configuration store and proceeding.
7172
Service ''{0}'' cannot be started because it belongs to cluster ''{1}'' that has no machines assigned to it.
7173
Failed to start service ''{0}''.
7174
Please refer to the logs to get additional details about any failure reported during the import process.
7175
This version of ArcGIS Server does not support a configuration store hosted on Amazon storage.
7176
Failed to delete the live store. Attempt number : ''{0}''.
7177
Validation complete and importing the site form location : ''{0}''.
7178
Import operation does not support creating a restore point on Linux and importing it on Windows.
7179
Import operation does not support creating a restore point on Windows and importing it on Linux.
7180
The security configuration of the site was changed from HTTP to HTTPS and the server is restarting. The site should become available shortly.
7181
The security configuration of the site was changed from HTTPS to HTTP and the server is restarting. The site should become available shortly.
7182
Configuration options pertaining to HTTPS were changed during the import operation and the Server is restarting. The site should become available shortly.
7183
The web adaptor configuration for this site was changed during the import operation. If you had web adaptors registered with the site prior to running the import operation, you must register them once again.
7184
7185
Failed to synchronize machine ''{0}'' with the site. {1}. You can attempt the synchronization again by using the synchronize Administrative REST API on the server machine resource.
7186
Failed to delete the service ''{0}''.
7187
Failed to clean up the live configurations store. Possible lock held on file ''{0}''.
7188
Failed to clean up the live configurations store at attempt ''{0}''.
7189
ArcGIS Server does not seem to have write access to location: ''{0}''.
7190
Invalid path specified. ''{0}''. You must specify an absolute path to a directory where the site configuration must be exported.
7191
Export operation started.
7192
Export operation completed. Site configurations were exported to ''{0}''.
7193
Import operation started.
7194
Import operation completed.
7196
Export operation failed.
7197
Import site failed with the following error.
7198
Cannot export the site while it is being created.
7199
Create a temporary configuration store at location ''{0}''.
7200
Copied site configurations to the configuration store at ''{0}''.
7201
Copied input data to location ''{0}''.
7202
Deleting temp dirs at location ''{0}''.
7203
Failed to start machine ''{0}''.
7204
Failed to stop machine ''{0}''.
7205
The authentication for the site was changed to WEB TIER and security on the Web Adaptor must be configured.
7206
You must enable SSL/HTTPs on the web adaptors.
7207
Import operation completed in ''{0}''.
7208
Failed to update identity store configuration ''{0}''.
7209
Import operation cannot proceed due to a validation error. No write access to server directory in the incoming site configuration. Please ensure ArcGIS Server has write access to the following directories ''{0}''.
7210
7211
Data item validation failed on machine ''{0}''. Validation message is ''{1}''. Log into Manager and modify settings for this datastore on the Site -> Data Store page.
7212
Validation failed for datastore ''{0}'' associated with path ''{1}''. ''{2}''.
7213
Validation of datastore item ''{0}'' succeeded.
7214
Import operation is about to complete. The following steps have been completed successfully ''{0}''. The pending steps are ''{1}''.
7215
Import site operation message. ''{0}''.
7216
Import operation failed. During an attempt to rollback the site to its original state, the security configuration of the site had to be changed to use the BUILTIN store. You must configure the security for the site if necessary.
7217
Import operation failed and an attempt to rollback the site to its original state also failed. The site may be functional but it is recommended that you unregister all machines in the site and create a new site based off the configuration store that was backed up at ''{0}'' and the server directories backed up at ''{1}''.
7218
Unable to query for logs on DataStore machine ''{0}''.
7219
Failed to update the log settings on DataStore machine ''{0}''.
7220
Failed to clean up the live configuration store at location ''{0}''.
7221
Failed to copy contents from incoming store ''{0}'' to live store ''{1}''.
7222
Creating services during import completed in ''{0}''.
7223
Zip file Validation during import completed in ''{0}''.
7224
Incoming site Validation during import completed in ''{0}''.
7225
Path Validation in incoming site during import completed in ''{0}''.
7226
Unzip contents during import completed in ''{0}''.
7227
Backup live site during import completed in ''{0}''.
7228
Stop clusters during import completed in ''{0}''.
7229
Unregister machines during import completed in ''{0}''.
7230
Delete services during import completed in ''{0}''.
7231
Unregister extensions during import completed in ''{0}''.
7232
Remove services from configuration store during import completed in ''{0}''.
7233
Copy data for incoming services during import completed in ''{0}''.
7234
Sync localhost for incoming services during import completed in ''{0}''.
7235
Start services during import completed in ''{0}''.
7236
After import, the authentication for the site has been modified. You may need to reconfigure security on your Web Adaptor.
7237
Unregister relational datastore types during import completed in ''{0}''.
7241
Server license check was successful.
7242
Configuration store initialization was successful.
7243
Security configuration was successful.
7244
Server directories were successfully created and initialized.
7245
Server machine was successfully configured.
7246
Configuration store connection file was written to disk.
7247
Server machine ''{0}'' was added to cluster ''{0}''.
7248
System services were deployed successfully.
7249
Default permissions on folders and GIS services were configured successfully.
7250
Server object extensions were registered successfully.
7251
Log configuration was successful.
7252
Creating a new site.
7254
The server was unable to create a GIS service. Please check the logs to determine the cause of the failure.
7255
Connection to callback URL ''{0}'' was successful.
7256
Joining site ''{0}''.
7257
Configuration store connection was successful.
7258
The server machine ''{0}'' was unable to connect to the following machines and ports ''{1}''. Please make sure that the server processes on these machines are up and running or check the firewall settings between the machines.
7259
Checking port accessibility on server machines in the site.
7260
Unable to test port accessibility on server machines in the site. Please make sure that the server processes on these machines are up and running or check the firewall settings between the machines.
7261
Port accessibility diagnostics test succeeded.
7262
The server was unable to acquire an exclusive lock in the file system. Please make sure that the server has write access to the configuration store and server directories.
7263
Successfully appended current domain prefix for Active Directory roles.
7264
Appending current domain prefix for Active Directory roles failed.
7265
Successfully appended current domain prefix for Active Directory users.
7266
Appending current domain prefix for Active Directory users failed.
7267
Failed to get roles with ''{0}'' privilege.
7268
7269
''{0}'' license expired on ''{1}''. Please contact Esri Customer Support to obtain a new license. To reauthorize your server, launch the Software Authorization tool and then restart ArcGIS Server.
7270
Unable to connect to the identity store using the supplied parameters. Verify that you can connect to the identity store outside of ArcGIS Server using the same parameters.
7271
Expired role privileges from previous security role store deleted successfully.
7272
Failed to delete expired role privileges from previous security role store. Please review current role privileges and confirm they are correct.
7273
Expired role service permissions from previous security role store deleted successfully.
7274
Failed to delete expired role service permissions from previous security role store. Please review current role service permissions and confirm they are correct.
7275
Expired role members from previous built-in security role store deleted successfully.
7276
Failed to delete expired role members from previous built-in security role store. Please review current role members and confirm that they are correct.
7277
Identity store configuration refreshed successfully.
7278
Failed to refresh the identity store configuration.
7279
A root or intermediate certificate cannot be used as a Web Server''s SSL certificate.
7280
Cannot update security configuration to federate with Portal as server is not registered with Portal.
7281
Failed to connect to Portal server. Please check if the Portal server is running and try again.
7282
Failed to get account ID from Portal. Please make sure that the token used to make the request is a valid Portal token.
7283
The server is configured to use web adaptor authentication. Only the primary site administrator is allowed direct access to server.
7284
This operation can only be performed by Portal administrators.
7285
This server has not been federated with Portal and therefore you cannot use federate/unfederate operations.
7286
A valid token from Portal and its referer is required to perform this operation.
7287
Failed to rename service ''{0}''.
7288
Could not connect to the identity store as one or more of the connection parameters is incorrect. Verify that you can connect to the identity store outside of ArcGIS Server using the same parameters.
7289
Starting upgrade of existing ArcGIS Server site.
7290
The configuration store has not been migrated to version ''{0}''. Beginning migration...
7291
Migration to configuration store version ''{0}'' is complete.
7292
Creating web adaptor configuration introduced at {0}.
7293
Existing config-store version earlier or equal to 10.1.SP1. Updating domain prefix for WINDOWS users and roles.
7294
Done updating domain prefix for WINDOWS users and roles.
7295
Validating key store
7296
Configuring application server.
7297
No site present to upgrade.
7298
Failed to complete the upgrade.
7298
Updating the autodeployed services.
7300
Synchronizing with the site for upgrade.
7301
The operation cannot proceed because ArcGIS Server is not supported on machines that include an underscore (_) in the machine name or whose hostname is a reserved word.
7302
Server certificates were not found for machine ''{0}'' when enabling HTTPS. Creating default SelfSignedCertificate for machine before enabling HTTPS.
7303
The ArcGIS Server machine ''{0}'' has been assigned a server certificate ''{1}'' that was not found. Using the default SelfSignedCertificate instead. To correct this, import certificate and re-configure ArcGIS Server machine to use that certificate.
7304
Failed to store data item ''{0}''.
7305
Could not find parent data store item.
7306
Failed to find data store item with path ''{0}''.
7307
Failed to encrypt the data store connection string or the request may have timed out. Please check the logs for more information.
7308
Failed to start the data store machine ''{0}''. ''{1}''
7309
Failed to stop the data store machine ''{0}''. ''{1}''
7310
Failed to configure the data store machine ''{0}'' as primary. ''{1}''
7311
Cannot remove datastore machine that is marked as primary.
7312
Failed to validate the data store machine ''{0}''. ''{1}''
7313
The HA connection string in the data store ''{0}'' does not contain the field DSID.
7314
Failed to update the data store connection information on machine ''{0}''.''{1}''
7315
Failed to update the data store with updated list of server machines. {0}
7316
Importing GIS services as items within portal.
7317
Failed to import GIS services as items within portal. ''{0}''
7318
Removing items from portal corresponding to GIS services on this server.
7319
Migrated file ''{0}'' to ''{1}'' successfully.
7320
Migrating ''{0}'' file failed.
7321
The site is configured to use the 'HTTP Only' protocol for communication. For improved security, it is recommended that the protocol be changed to 'HTTPS Only' or 'HTTP and HTTPS'. See the help topic 'Best practices for configuring a secure environment' for more details.
7321
Stopping the service ''{0}''.
7322
Could not connect to primary LDAP server or any failover LDAP servers. Verify that you can connect to the identity store outside of ArcGIS Server using the same parameters.
7322
Starting the service ''{0}''.
7323
Trying to connect to ldap server {0}.
7323
Failed to create 'errorreports' folder under ''{0}''.
7324
Successfully connected to ldap server {0}.
7324
Failed to update portal with item information for service ''{0}''.
7325
Failed to gracefully stop machine ''{0}'' within stipulated time. Force stopping the ArcSOC processes and app server.
7325
ArcGIS Server was previously configured with ArcGIS Data Store. To use the data store again, reconfigure it with your site using the ArcGIS Data Store Configuration wizard or 'configuredatastore' utility.
7326
Permissions refreshed successfully.
7327
Failed to refresh permissions.
7328
One or more server machines could not be refreshed with current permissions.
7329
Web server SSL Certificate with name ''{0}'' not found. Please check if the certificate exists in the SSLCertificates resource.
7330
The primary site administrator account has been enabled.
7331
A request was made for service ''{0}'' but it did not have adequate credentials.
7333
The site mode has been updated to READ-ONLY. Administrative and publishing operations will not be allowed.
7334
The site is in READ-ONLY mode. Change site mode to EDITABLE before applying any administrative or publishing changes.
7335
Failed to copy configurations locally in machine ''{0}''. The machine will retry to synchronize with the site again. {1}
7336
The machine ''{0}'' failed to copy the configurations locally. {1}.
7337
The machine ''{0}'' failed to remove the local configurations. {1}.
7338
The site mode has been updated to EDITABLE. Administrative and publishing operations will be permitted on the site.
7340
Failed to remove local configurations in machine ''{0}''. The machine will retry to synchronize with the site again. {1}
7341
Appending EOF to {0} to .etag files in configuration store.
7342
Creating security.etag in configuration store.
7343
Failed to use local input directory for ''{0}''.
7344
Site readonly, configuration changes not allowed. {0}
7345
Configuration store error. {0}
7347
No changes to site mode. Current site mode is {0}.
7348
Saving site mode to the configuration store.
7349
Site mode saved to the configuration store.
7350
Notifying peer server machines to copy configurations locally.
7351
Copying the configuration store to machine ''{0}''.
7352
Completed copying the configuration store to machine ''{0}''.
7353
Copying the input directory to machine ''{0}''.
7354
Completed copying the input directory to machine ''{0}''.
7355
Machine(s) {0} do not have enough space to copy server configurations locally.
7356
Checking each machine for sufficient disk space to copy configurations locally.
7357
Verified all reachable machines have sufficient disk space to copy configurations locally.
7358
Failed to compute free space available in machine ''{0}''. {1}
7359
Failed to update site mode to {0}. {1}
7360
Notifying peer server machines to remove local configurations.
7361
Restarted all clusters in the site.
7362
Site mode updated to {0} with errors. {1}
7363
Service ''{0}'' could not be started or updated because ''{1}'' is being added to a list of server object interceptors, but is not a valid interceptor. Verify that ''{1}'' is a service object interceptor and try again.
7365
7366
Copying the server directories structure to machine ''{0}''.
7367
Completed copying the server directories structure to machine ''{0}''.
7368
Failed to recover the configuration store.
7369
Recover configuration store begins.
7370
Recovery of configuration store completed.
7371
Failed to recover the server directories.
7372
Recover server directories begins.
7373
Recovery of server directories completed.
7374
Machine ''{0}'' does not have enough space to copy server configurations locally.
7375
Failed to load cluster information. Will continue as a single, non-clustered instance.
7376
Invalid configuration retrieved from ZooKeeper Cluster. {0}
7377
Failed to update zookeeper.properties.
7378
Could not update Synchronization service cluster to include {0}. Max retry attempts exceeded.
7379
The data store manifest failed to validate. {0}
7380
The data store could not be unregistered because it is being referenced in GIS services.
7381
The data store could not be unregistered because it does not exist.
7382
The data store could not be unregistered because a 'force' parameter was not provided with value 'true'.
7383
Service ''{0}'' could not be started or updated because the ''{1}'' extension is disabled but is being added to the list of server object interceptors.
7384
Error encountered while changing the server role. {0}
7385
The server was unable to create administrative and publishing items in portal. As a result only portal administrators and publishers can administer and publish to this server. {0}
7386
Failed to delete item ''{0}'' from portal.
7387
Could not deploy services from one or more machines. ''{0}''.
7388
Failed to determine the role of the server after upgrade. {0}
7389
Stopping all clusters in the site.
7390
Stopped all clusters in the site.
7391
Starting all clusters in the site.
7392
Started all clusters in the site.
7393
Site mode update to {0} with errors, configurations not copied to machines locally. {1}
7394
Invalid range specified for {0}. Accepts a value between 1 to 80.
7395
Downgrading this instance to single node cluster although multiple machines are configured for cluster. Recommend shutting down all other instances except the one referenced in zookeeper-dynamic.properties file and then adding the rest back one at a time to rebuild cluster.
7396
License for previous version is present.
7397
There is no {0} data store registered with the site.
7398
Failed to the old certificates into the JRE cacerts keystore.
7399
Failed to replace service ''{0}'' for ''{1}''.
7400
Invalid path specified. ''{0}''. You must specify an absolute path to a directory where the services must be exported.
7401
Export services operation started.
7402
Export services operation completed. Services were exported to ''{0}''.
7403
Import services operation started.
7404
Import services operation is about to complete. The following steps have been completed successfully ''{0}''. The pending steps are ''{1}''.
7405
Import services operation completed.
7406
Cannot export the services while the site is being created.
7407
7408
Copied services to the configuration store at ''{0}''.
7409
7410
7411
Configuration options pertaining to HTTPS were changed during the import services operation and the Server is restarting. The site should become available shortly.
7412
Import services operation completed in ''{0}''.
7413
7414
Export services operation failed.
7415
Failed to update the data store connections file. {0}
7416
Using a backup data store connections file from the configuration store.
7417
Publishing of Geoprocessing services is restricted to administrators only.
7418
Publishing custom extensions is restricted to administrators only.
7419
The extensions are not currently supported on this service configuration.
7420
Failed to register extension.
7421
Failed to retrieve service lifecycle information for ''{0}''.
7422
Failed to update service lifecycle information for ''{0}''.
7423
Server license version does not match effective current version.
7424
This folder contains catalog services for registered data stores.
7425
GeoAnalytics service may not be running. Please configure the server with the GeoAnalytics role and try again. {0}
7426
Generating manifest for data store {0}.
7427
Failed to get DataStore trusted machines list.
7428
Failed to save DataStore trusted machines list.
7429
Failed to get server privileges from owning portal. Server privileges will not be honored. {0}.
7430
Restarting Compute Platform. The restart process will take {0} minutes to complete.
7431
Compute Platform has restarted. Please verify its status using health check.
7501
WARNING: Could not connect to Log service. Writing log message to console.
7501
Initializing config-store connection.
7502
Missing server object type configuration file ''{0}''
7502
Config-store connection initialization complete.
7503
Missing 'Name' attribute of the server object type
7503
Site creation in progress.
7504
Folder ''{0}'' is currently in use.
7504
Server machine ''{0}'' has been added to the site successfully.
7505
Expiration time cannot be negative.
7505
Failed to join the site.
7506
A path with new name ''{0}'' exists and could not be deleted.
7506
Cluster ''{0}'' - Machine ''{1}'' is currently being configured by another administrative operation. Please try again later.
7507
Could not find old path ''{0}''.
7507
Cluster ''{0}'' resource is currently being configured by another administrative operation. Please try again later.
7508
File already exists. File = ''{0}''.
7508
Cluster ''{0}'' not found. Machine ''{1}'' cannot be added to cluster.
7509
Source path ''{0}'' does not exist.
7509
''{0}'' is joining the site using configuration store details.
7510
Destination path ''{0}'' already exists.
7510
Time elapsed in ''{0}'' module is ''{1}''.
7511
Could not create destination directory ''{0}''.
7511
Time elapsed in join site workflow is ''{0}''.
7512
Could not create temp directory:''{0}''
7512
Time elapsed in create site workflow is ''{0}''.
7513
Could not delete temp file: ''{0}''
7513
Successfully backed up input directory and other server directories structure for service ''{0}'' to configuration store.
7514
7514
Failed to backed up input directory and other server directories structure for service ''{0}'' to configuration store. Retrying.
7515
Could not get ArcGIS home directory. Check if environment variable ''{0}'' is set.
7515
Successfully backed up input directory and other server directories structure for service ''{0}'' to configuration store after retries.
7516
Unable to start RMI registry on the specified port ''{0,number,#}''.
7516
Failed to backed up input directory and other server directories structure for service ''{0}'' to configuration store after multiple retries. Start and stop the service to trigger backup manually.
7517
Unable to stop RMID on the specified port ''{0,number,#}''.
7517
Successfully removed backup of input directory and other server directories structure for service ''{0}'' from configuration store.
7518
Unable to decrypt. ''{0}''
7518
Failed to remove backup of input directory and other server directories structure for service ''{0}'' from configuration store. Retrying.
7519
Illegal fully qualified service name format in name ''{0}''.
7519
Successfully removed backup of input directory and other server directories structure for service ''{0}'' from configuration store after retries.
7520
Service name is invalid. {0}
7520
Failed to remove backup of input directory and other server directories structure for service ''{0}'' from configuration store after multiple retries.
7521
Folder name is invalid. {0}
7521
Starting to back up input directory and other server directories structure for service ''{0}'' to configuration store.
7522
The name is empty.
7522
Starting to remove backup of input directory and other server directories structure for service ''{0}'' from configuration store.
7523
The name contains illegal character ''{0}''.
7523
Successfully backed up kmz ''{0}'' to configuration store.
7524
Could not find file ''{0}''.
7524
Failed to backed up kmz ''{0}'' to configuration store. Retrying.
7525
Invalid URL.
7525
Successfully backed up kmz ''{0}'' to configuration store after retries.
7526
Failed to connect to JMX server.
7526
Failed to backed up kmz ''{0}'' to configuration store after multiple retries.
7527
Failed to acquire the lock ''{0}''. Conflicting lock info ''{1}''.
7527
Successfully removed backup of kmz ''{0}'' from configuration store.
7528
Failed to acquire the lock ''{0}'' within the stipulated max wait time of ''{1}'' ms.
7528
Failed to remove backup of kmz ''{0}'' from configuration store. Retrying.
7529
Could not find a service with the name ''{0}'' in the configured clusters. Service may be stopped or ArcGIS Server may not be running.
7529
Successfully removed backup of kmz ''{0}'' from configuration store after retries.
7530
Could not find a service with the JNDI name ''{0}'' in the configured clusters. Service may be stopped or ArcGIS Server may not be running.
7530
Failed to remove backup of kmz ''{0}'' from configuration store after multiple retries.
7531
The range for {0} is invalid.
7531
Recovering server directories by using the backup in configuration store.
7532
Unable to rename old path ''{0}'' to new path ''{1}''.
7532
Recovering server directories by using local backup.
7533
Error: Object store not found.
7533
Ports diagnostics test is skipped when joining site with single clustered mode and using the join-site command line tool.
7534
Invalid ''{0}'' or ''{1}''.
7534
User store configuration is set to SQL_SERVER. However, support for the SQL_SERVER option was deprecated at ArcGIS Server 10.4. Update your user store to a supported security configuration.
7535
{0} does not exist. Please create and retry.
7535
Role store configuration is set to SQL_SERVER. However, support for the SQL_SERVER option was deprecated at ArcGIS Server 10.4. Update your role store to a supported security configuration.
7536
Required parameter ''{0}'' is missing.
7536
The site machine needs to be upgraded.
7537
Does not have the required read and write permissions to file/directory.
7537
Upgrade step 1 of 2 :
7538
Connection string specifies an invalid URI.
7538
Upgrade step 2 of 2 :
7539
Upgrade in progress.
7540
The {0} service is no longer supported.
7541
Globe services are no longer supported.
7542
Service ''{0}'' cannot be started since it does not have a valid license.
7543
Failed to clean up old configuration store at ''{0}''.
7544
Successfully updated the configuration store.
7545
Failed to share utility services (Printing, Geocoding) to the organization.
7546
Failed to unshare utility services (Printing, Geocoding) from the organization.
7547
Utility services (Printing, Geocoding) shared to the organization.
7548
Utility services (Printing, Geocoding) unshared to the organization.
7549
Acquired ''{0}'' workflow lock.
7549
Processing request took longer than the usage timeout for service ''{0}''.
7550
Released ''{0}'' workflow lock.
7550
Creating instances of service ''{0}''.
7551
Instance of the service ''{0}'' crashed.
7552
Could not find ''{0}'' service configuration.
7553
The containing process for ''{0}'' job ''{1}'' has crashed.
7554
Failed to update the geoprocessing job ''{0}'' id(''{1}'').
7555
Failed to load service configuration of the service ''{0}''.
7556
Could not connect to the queue ''{0}''.
7557
Internal Server Error: Unexpected message received.
7558
{0} failed to process request.
7559
Failed to create instance of service ''{0}''.
7560
'IsolationLevel' property is missing in the service ''{0}''.
7561
Missing required property ''{0}'' in the service ''{1}''.
7562
Failed to handle check and repair connections request.
7563
Service instance activation failed in ''{0}''.
7564
Unable to configure recycling on the service ''{0}''.
7565
Recycling is configured for service {0}. Recycling will start at {1} and repeat every {2} {3}.
7566
Creating instance of service ''{0}''.
7567
Instance of service ''{0}'' has been successfully created.
7568
Existing processes for running this service configuration are full. Creating the service instance in a new process.
7569
Service containing process crashed for ''{0}''.
7570
Failed to construct instance of service ''{0}''.
7571
Recycling of service {0} begins. Number of instances to be recycled: {1}.
7572
Service keep alive mechanism has detected that the connections to the data are stale in the instance of the service ''{0}''. Recreating the service instance.
7573
Could not connect to queue connection factory ''{0}''.
7574
Unsupported queue type ''{0}''.
7575
Attribute object must implement Serializable.
7576
Request cannot be null. It must be a non-null String to a byte[].
7577
Unknown server directory type ''{0}''.
7578
Could not service request.
7579
EJBBase class must be initialized before calling this method.
7580
Server directory type ''{0}'' has not been configured. It is required to store ''{1}'' information.
7581
Response type is not supported.
7582
Starting scanner thread.
7583
Scanner did not find a executor with any capacity to execute jobs.
7584
Scanner found that executors have ''{0}'' capacity to execute jobs. Scanning for jobs.
7585
Scanner is sorting the jobs in the submitted folder.
7586
Scanner did not find any jobs available for execution.
7587
Scanner found a job file ''{0}''. Testing if the job can be locked for execution.
7588
Scanner found a job file ''{0}'' but it was already locked by another process.
7589
Executor is idle and waiting for a job from the scanner.
7590
Executor is ready to execute job ''{0}''.
7591
Executor has successfully executed the job ''{0}''.
7592
Setting executor capacity to ''{0}''.
7593
Scanner thread is being stopped for service ''{0}''.
7594
Executor thread is being stopped.
7595
Please see if an error report was generated in ''{0}''. To send an error report to Esri, compose an e-mail to ArcGISErrorReport@esri.com and attach the error report file.
7596
Instance of service ''{0}'' started with errors.
7597
Executing geoprocessing job ''{0}''.
7598
Could not initialize service ''{0}''.
7599
Server object CLSID ''{0}'' is undefined.
7600
Request type is not supported.
7601
Failed to clean all services.
7602
Could not find service. Service may be stopped or it may not be configured.
7603
Invalid value specified for {0} property.
7604
The requested service type is not supported with your current ArcGIS Server license. Contact your ArcGIS Server site administrator.
7605
The requested service type is not supported with your current privilege.
7607
Setting the synchronization flag on the machine ''{0}''. {1}
7608
Resetting the synchronization flag on the machine ''{0}''. {1}
7609
Server machine ''{0}'' has successfully synchronized with the site.
7610
The server machine ''{0}'' is synchronizing with the site. This will take a few minutes and during this operation all administrative operations will be blocked.
7611
Failed to get the application server for the site.
7612
Failed to configure application server for the site.
7613
Registration of database ''{0}'' is incomplete. Failed to get connection string from System/{1} GP service.
7614
Registration of database ''{0}'' is incomplete. Failed to update the data store connections file. Using ArcGIS Server Administrator Directory check if System/{1} GP service is started and re-register the database.
7700
ArcGIS Server cannot connect to Active Directory LDAP server at {0} (error: {1}). Adding it to the list of bad LDAP urls, and will not be connected to for next 24 hours. Current list of bad LDAP urls are {2}.
7700
Failed to start web server.
7701
Could not connect to the ArcGIS component at URL ''{0}''. The ArcGIS component on that machine may not be running or the machine may not be reachable at this time.
7701
Failed to start app server.
7702
Importing Utilities folder GIS services as items within portal.
7702
Web server started successfully.
7703
Failed to import Utilities folder GIS services as items within portal. ''{0}''
7703
App server started successfully.
7704
Could not register one or more service items. ''{0}''.
7704
Failed to stop web server.
7705
Unable to encrypt proxy password.
7705
Failed to stop app server.
7706
Unable to decrypt proxy password.
7706
Web server stopped successfully.
7707
Maintenance flag set for server machine ''{0}''.
7707
App server stopped successfully.
7708
Maintenance flag removed for server machine ''{0}''.
7708
Could not stop server processes gracefully. Now terminating the processes.
7709
One or more server machine have failed to synchronize with the site. {0}
7709
The {0} was found to be stopped when it should have been started. Restarting it.
7710
ArcGIS Server is using too many open file handles({0}). Unexpected errors will occur unless the ulimit({1}) is increased. You can edit /etc/security/limits.conf to set the nofile limit.
7711
ArcGIS Server is using {0} file handles out of a total limit of {1}.
7712
An error was encountered while synchronizing with the configuration store.
7713
Web server port ''{0,number,#}'' is in use.
7714
Could not load ArcGIS Server configuration file.
7715
Failed to start ArcGIS Server. One of the observers failed to start.
7716
Could not start RMI connector. An instance of NodeAgent may be running or the JMX-RMI port is in use by another process.
7717
JMX-RMI port may not have been configured.
7718
Class ''{0}'' does not implement NodeAgentObserver interface.
7719
Class ''{0}'' does not implement NodeAgentPlugin interface.
7720
NodeAgent plugin ''{0}'' does not extend NodeAgentPeriodicTask.
7721
Attempted to stop the app server, but this is unnecessary since no server machine is configured.
7722
ArcGIS Server has detected that the server machine name ''{0}'' has been changed to ''{1}''. ArcGIS Server will be updated automatically to use the new host name. If you have enabled SSL and your certificate was using the previous machine name, you must generate a new SSL certificate and configure your ArcGIS Server site to use it. If you had configured the ArcGIS Web Adaptor to use your previous machine name, you will need to reconfigure it with a new URL that uses the updated machine name.
7723
Machine ''{0}'' was forcibly disconnected from the site. Now disconnecting completely...
7724
7725
Verify machine registration observer:
7726
The ArcGIS Server machine ''{0}'' is running out of disk space on ''{1}''. Increase disk space on this machine to prevent ArcGIS Server from going into a bad state.
7727
The ArcGIS Server machine ''{0}'' is critically running out of disk space on ''{1}''. It is essential to increase disk space on this machine to prevent ArcGIS Server from going into a bad state.
7900
Invalid data source type ''{0}''.
7901
Unable to find the data source ''{0}''.
7902
Invalid parameter ''{0}'' is passed in the request.
7903
Error registering data source ''{0}''.
7904
Error unregistering data source ''{0}''.
7905
Missing required parameter ''{0}''.
7906
Error validating item ''{0}''.
7907
Unsupported response format.
7908
Authorization failed. This user account does not have the required privileges to access this application/operation.
7909
Unable to get public keys.
7910
Missing ''{0}'' in the admin web application.
7911
Could not find resource or operation ''{0}'' on the system.
7912
Null cluster info.
7913
Item not found.
7914
Unable to decrypt request parameters.
7915
KML document with name : ''{0}'' already exists.
7916
Certificate not found.
7920
Tomcat controller cannot be initialized.
7921
Can not delete default certificate.
7922
Unable to find root ca certificate.
7923
Server machine info missing.
7924
Invalid credentials.
7925
7926
Invalid {0} value.
7927
{0} value ''{1}'' is invalid. {0} should be a positive integer.
7928
Invalid value of 'configuredState' attribute. Should be STARTED or STOPPED.
7929
Server error. Service configuration ''{0}.{1}'' was not found.
7930
This operation must be a multipart request.
7931
Folder input value can not be empty.
7933
Folder info missing.
7934
Service info missing.
7935
7936
Client ID type is invalid.
7937
7938
Could not clear REST cache on one or more machines.
7939
''{0}'' property is not a valid number.
7940
Missing ''partNumber'' property for uploading the part.
7941
No file is associated with the upload request.
7942
Unable to locate file {0}.
7943
The long duration timeout cannot be lesser than the short duration timeout.
7944
{0} can not be null.
7945
{0} must be one of the following values : {1}
7946
Missing required attribute ''{0}''.
7947
Use JSON in parameter {0}.
7948
Error while processing request. Internal error. {0} response not set.
7949
Error while processing request. Internal error. {0} object not set.
7950
User name already exists.
7951
Requested resource or operation ''{0}'' is not available.
7952
Log directory ''{0}'' is invalid. Check that the directory exists and that the ArcGIS Server user account can write to the location.
7953
User does not exist.
7954
User(s) do not exist.
7955
Invalid redirect parameter.
7956
Service started with errors
7957
Service failed to start
7958
Possible cross site request forgery attack detected.
7959
Best Guess Remote IP: ''{0}'' Headers: ''{1}''
7960
Logging of IP information is disabled.
7961
The request cannot be fulfilled.
7962
Failed to import the certificate. Please verify that the certificate is valid and does not contain spaces in the file name.
7963
Server machine name should not be localhost. Please enter a proper hostname.
7964
The operation succeeded. However, the directory path ''{0}'' is now being shared with another site. You must exercise caution when writing to or deleting contents from this location.
7965
Null metric info.
7966
Aggregation interval cannot be less than 30 minutes.
7967
You do not have adequate privileges to access the resource ''{0}''.
7970
Cannot create a new cluster in the optimized cluster mode.
7971
Cannot enable optimized cluster mode when there is more than one cluster in the site.
7972
In order to delete this cluster you must first disable the optimized cluster mode
7973
Required parameter ''singleClusterMode'' not found in json.
7974
Incorrect value for the parameter ''singleClusterMode'' in the json. The value should be true or false.
7975
Error: To enable this property, only one cluster can be configured in your site. Multiple clusters cannot exist.
7976
Failed to generate a token for the user. Expiration time exceeds maximum token length.
7977
Error: Invalid manifest file.
7978
7979
Server machine(s) {0} not reachable during validation of data item ''{1}''. The ArcGIS Server service on those machines may not be running or the machine(s) may not be reachable at this time.
8500
Security credentials not provided.
8501
Unable to decrypt user credentials from Web Adaptor.
8502
Unable to get roles for the user ''{0}''.
8503
{0} authentication failed: Request from this IP address is not allowed.
8504
{0} authentication failed: Username is missing.
8505
{0} authentication failed: User or role is missing.
8506
Unable to add user roles to cookie.
8507
Unable to get user roles from cookie.
8508
Unable to get an instance of security configuration.
8509
Unable to initialize security manager.
8510
ServletRequest or ServletResponse is null.
8511
8512
Security is not configured to {0}.
8513
Unable to get an instance of TokenHandler configuration.
8514
Unable to instantiate TokenHandler.
8515
Unable to get public key from Site Manager.
8516
Could not authenticate user {0} IdentityStores cannot be initialized.
8517
Error: Could not authenticate user.
8518
You cannot obtain a token at this time because ArcGIS Server is currently configured for web tier authentication, not token authentication.
8519
You need a token to access this secured resource. If you are accessing the Services Directory and getting this message, it is likely that the Services Directory is not supported for this secured resource.
8520
Error in initializing role store.
8521
HTTP Referer: {0}
8522
HTTP Referer: Not Available
9000
Internal Server Error.
9001
Response already committed. Cannot forward to error page.
9002
This exception was thrown after the response was committed.
9003
Unable to process request.
9004
Layer does not exist.
9005
Unable to decode from {0} from {1} to {2}.
9006
Error creating JSONObject for the response.
9007
Error creating JSONObject for the response properties {0}.
9008
Error creating a JSONObject for the schema response.
9009
Error connecting Admin Client to the remote admin: {0}.
9010
Error Initializing Admin Client.
9011
Application initialized.
9012
No upload directories have been configured. All files will be uploaded to the system temp directory.
9013
Error configuring server directories.
9014
Error getting list of folder names.
9015
Error getting list of services.
9016
Error getting service.
9017
ArcGIS Server Site is not configured. Check with your ArcGIS Server administrator for resolution; an ArcGIS Server site is created or machines are added to an existing site using ArcGIS Server Manager.
9018
Unable to get the JNDI Name for {0} ({1})
9019
Tile for level {0}, row {1}, col {2} is not accessible.
9020
Attempting to generate tile on demand for level {0}, row {1} and col {2}.
9021
Failure to generate tiles on demand for level {0}, row {1} and col {2}.
9022
Error getting value for param: {0}
9023
Error getting information about folder {0}
9025
Error initializing Web Security Manager
9026
ArcGIS Server Site is not initialized.
9027
Error getting license information for server.
9028
Error getting directories security property.
9029
Request user: {0}, Service: {1}
9030
Error getting services directories property.
9031
Error handling service request :
9032
Failed to add attachment. File size limit of {0} MB exceeded for feature service ''{1}''.
9033
Unable to process request. No instances for ''{0}'' were available for {1} seconds. Wait timeout exceeded.
9034
Server is configured to use local cache directory, local cache directory not found. Please check if ''{0}'' exists.
9035
Server is configured to use a cloudStore, cloudStore not found. Please check if ''{0}'' exists.
9036
Server is configured to use a cloudStore, cloudStore property ''{0}'' not found.
112008
Service {0} is unavailable.
112009
Failed to read thumbnail data for the service "{0}".
219999
No code given.
