changeloglocation
This ArcGIS Data Store utility is used with all ArcGIS Data Store types.
The default error log file location for ArcGIS Data Store is <ArcGIS Data Store directory>\arcgisdatastore\logs. To use a different file directory, run the changeloglocation utility and specify the new directory path.
The ArcGIS Data Store account must have privileges to write to the directory you specify.
Syntax
changeloglocation <directory path>
Example
In this example, log files will be created in the local directory, ../datastorefiles/logs.
./changeloglocation.sh '../datastorefiles/logs'
In this example, log files will be created in the local directory, d:\datastorefiles\logs.
changeloglocation 'd:\datastorefiles\logs'
