replacesslcertificate
This utility is used with all ArcGIS Data Store types.
You can replace the ArcGIS Data Store self-signed certificate used by the web server to authenticate communication between the hosting server and the data store and between data store machines with a certificate verified and signed by a certifying authority (CA) or domain certificate. You can also replace the self-signed certificate used to communicate between machines over ports for the following data store types:
Relational store
When you update the certificate for the relational store, it also updates the certificate for the additional system stores installed for the relational store.
Graph store
Object store
This utility will eventually supercede the updatesslcertificate utility.
Running this utility restarts ArcGIS Data Store.
See Replace the ArcGIS Data Store SSL certificate for more information.
Syntax
replacesslcertificate <source certificate file name with path> <password for the source certificate file> <alias for the certificate> --option <webserver | relational | graph | object>
Examples
In the following example, the self-signed certificate used for webserver authentication is replaced with a CA-signed certificate file (mysignedcert.pfx).
./replacesslcertificate.sh /usr/files/mysignedcert.pfx "ps4mycert" "mycacert" --option webserver
replacesslcertificate C:\myfiles\mysignedcert.pfx "ps4mycert" "mycacert" --option webserver
In the next example, the self-signed certificate used for communication with the relational store over ports is replaced with a CA-signed certificate (mysecondsignedcert.pfx).
./replacesslcertificate.sh /usr/files/mysecondsignedcert.pfx "ps4mycert" "relcacert" --option relational
replacesslcertificate C:\myfiles\mysecondsignedcert.pfx "ps4mycert" "relcacert" --option relational
