updatebackupretaindays
This ArcGIS Data Store utility is used with the relational store.
ArcGIS Data Store retains relational store backup files for seven days by default. You can change how often backup files are purged from the backup directory by running the updatebackupretaindays utility.
The updatebackupretaindays utility can be run on the primary relational store machine only.
Syntax
updatebackupretaindays <number of days>
Example
In the following example, backup file retention time is changed to 10 days:
./updatebackupretaindays.sh 10
updatebackupretaindays 10
