Log codes
Log code number ranges are associated with certain types of messages.
  • Codes between 6,500 and 9,999 are logged by the core framework of ArcGIS Server.
  • Codes between 10,000 and 100,000 pertain to services.
  • Codes above 100,000 are core ArcObjects component-related messages that may also be used in other ArcGIS products.
Some codes apply to messages of different levels. For example, a message with a certain code may be a severe error for one event, while it may be a warning for another event.
The following table provides a more detailed breakdown of the code ranges and their content:
Log code range
Message content
6500–9999 and 112000–112999
Core ArcGIS Server framework
10000–10999
Map services
11000–11999
Mobile data services (deprecated at 10.5)
12000–12999
KML services
13000–13999
Network analysis services
14000–14999
WFS services created from map services
15000–15999
WCS services created from map services
16000–16999
WMS services created from map services
17000–19999
Feature services
20000–20999
Geoprocessing services
21000–21999
Synchronous geoprocessing services
30000–30999
Globe services (deprecated at 10.5)
60000–60999
Geometry services
70000–70999
Geocode services
80000–80999
Image services
81000–81999
WCS services created from image services
82000–82999
WMS services created from image services
90000–90999
Geodata services
91000–91999
WCS services created from geodata services
92000–92999
WFS services created from geodata services
100000–100999
System
101000–101999
Geometry
102000–102999
Geodatabase
103000–103999
Carto
104000–104999
Display
105000–105999
Output
106000–106999
Geoprocessing
107000–107999
Globe
108000–108999
3D
109000–109999
Network Analyst
110000–110999
ArcGIS Data Store
111000–111999
ArcGIS Insights server component
120000–169999
Geodatabase
