Restrict TLS protocols and cipher suites
As an ArcGIS Server administrator, you can specify the Transport Layer Security (TLS) protocols and encryption algorithms ArcGIS Server uses to secure communication. Your organization may be required to use specific TLS protocols and encryption algorithms, or the web server on which you deploy ArcGIS Server may only allow certain protocols and algorithms. Specifying that ArcGIS Server use the certified protocols and algorithms ensures that your site remains in compliance with your organization's security policies.
Following the POODLE vulnerability exposed in 2014, ArcGIS Server dropped support for Secure Sockets Layer (SSL) protocols at 10.3 and later, but you will still see SSL used in the software to refer to TLS protocols.
TLS protocols
By default, ArcGIS Server only uses the TLSv1.3 and TLSv1.2 protocols. You can also enable TLSv1 and TLSv1.1 protocols using the steps below.
Default encryption algorithms
ArcGIS Server is configured by default to use the following encryption algorithms in the order listed below:
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,
TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256,
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,
TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,
TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256,
TLS_AES_128_GCM_SHA256,
TLS_AES_256_GCM_SHA384,
TLS_CHACHA20_POLY1305_SHA256
The default cipher suite list includes only modern, secure cipher suites and is regularly updated to reflect current security best practices.
If you upgraded from an earlier release, your existing configuration may still include legacy cipher suites (for example, CBC-mode or RSA key exchange suites) that are no longer part of the default configuration and are not recommended for new deployments. To improve security and align with best practices, it is recommended that you update your cipher suite configuration to use the default list above.
While it is recommended to use the updated default cipher suite list for improved security, legacy encryption algorithms remain available and can be reenabled if compatibility with older clients is necessary. For details, see Cipher suites reference below.
Complete the following steps to specify the TLS protocols and encryption algorithms your site will use.
  1. Open the ArcGIS Server Administrator Directory and sign in as an administrator of your site.
    The URL is in the format https://gisserver.example.com:6443/arcgis/admin.
  2. Click Security > Config > Update.
  3. In the SSL Protocols text box, specify the protocols to be used. If specifying multiple protocols, separate each protocol with a comma, for example, TLSv1.2, TLSv1.1.
    Ensure that the web server hosting your Web Adaptor can fully communicate over the protocols you are enabling.
  4. In the Cipher Suites text box, specify the cipher suites to be used in IANA format. Separate each algorithm with a comma, for example, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, TLS_RSA_WITH_AES_128_CBC_SHA.
  5. Click Update.
    An error is returned if an invalid protocol or cipher suite is specified.
ArcGIS Server supports the following algorithms:
Cipher ID
Name (IANA format)
Name (OpenSSL format)
Key exchange
Authentication algorithm
Encryption algorithm
Bits
Hashing algorithm
0xC030
ECDHE-RSA-AES256-GCM-SHA384
ECDH
RSA
AES_256_GCM
256
SHA384
0xC028
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
ECDHE-RSA-AES256-SHA384
ECDH
RSA
AES_256_CBC
256
SHA384
0xC014
ECDH
RSA
AES_256_CBC
256
SHA
0x009F
TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
DH
RSA
AES_256_GCM
256
SHA384
0x006B
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
DHE-RSA-AES256-SHA256
DH
RSA
AES_256_CBC
256
SHA256
0x0039
DHE-RSA-AES256-SHA
DH
RSA
AES_256_CBC
256
SHA
0x009D
TLS_RSA_WITH_AES_256_GCM_SHA384
AES256-GCM-SHA384
RSA
RSA
AES_256_GCM
256
SHA384
0x003D
TLS_RSA_WITH_AES_256_CBC_SHA256
AES256-SHA256
RSA
RSA
AES_256_CBC
256
SHA256
0x0035
AES256-SHA
RSA
RSA
AES_256_CBC
256
SHA
0xC02F
ECDHE-RSA-AES128-GCM-SHA256
ECDH
RSA
AES_128_GCM
128
SHA256
0xC027
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
ECDHE-RSA-AES128-SHA256
ECDH
RSA
AES_128_CBC
128
SHA256
0xC013
ECDH
RSA
AES_128_CBC
128
SHA
0x009E
TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
DH
RSA
AES_128_GCM
128
SHA256
0x0067
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
DH
RSA
AES_128_CBC
128
SHA256
0x0033
DHE-RSA-AES128-SHA
DH
RSA
AES_128_CBC
128
SHA
0x009C
TLS_RSA_WITH_AES_128_GCM_SHA256
AES128-GCM-SHA256
RSA
RSA
AES_128_GCM
128
SHA256
0x003C
TLS_RSA_WITH_AES_128_CBC_SHA256
AES128-SHA256
RSA
RSA
AES_128_CBC
128
SHA256
0x002F
AES128-SHA
RSA
RSA
AES_128_CBC
128
SHA
0xC012
TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA
ECDHE-RSA-DES-CBC3-SHA
ECDH
RSA
3DES_EDE_CBC
168
SHA
0x0016
SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA
EDH-RSA-DES-CBC3-SHA
DH
RSA
3DES_EDE_CBC
168
SHA
0x000A
SSL_RSA_WITH_3DES_EDE_CBC_SHA
DES-CBC3-SHA
RSA
RSA
3DES_EDE_CBC
168
SHA
0xC02C
ECDHE-ECDSA-AES256-GCM-SHA384
ECDH
ECDSA
AES_256_GCM
256
SHA384
0xC024
TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
ECDHE-ECDSA-AES256-SHA384
ECDH
ECDSA
AES_256_CBC
256
SHA384
0xC00A
ECDH
ECDSA
AES_256_CBC
256
SHA
0xC02B
ECDHE-ECDSA-AES128-GCM-SHA256
ECDH
ECDSA
AES_128_GCM
128
SHA256
0xC023
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
ECDHE-ECDSA-AES128-SHA256
ECDH
ECDSA
AES_128_CBC
128
SHA256
0xC009
ECDH
ECDSA
AES_128_CBC
128
SHA
0xC008
TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA
ECDHE-ECDSA-DES-CBC3-SHA
ECDH
ECDSA
3DES_EDE_CBC
168
SHA
0xCCA8
ECDHE-RSA-CHACHA20-POLY1305
ECDH
RSA
CHACHA20 POLY1305
256
SHA256
0xCCA9
ECDHE-ECDSA-CHACHA20-POLY1305
ECDH
ECDSA
CHACHA20 POLY1305
256
SHA256
0x1301
TLS_AES_128_GCM_SHA256 (TLSv1.3 only)
AES_128_GCM
128
SHA256
0x1302
TLS_AES_256_GCM_SHA384 (TLSv1.3 only)
AES_256_GCM
256
SHA384
0x1303
TLS_CHACHA20_POLY1305_SHA256 (TLSv1.3 only)
CHACHA20 POLY1305
256
SHA256
Terminology
The following terms are used in the table above:
  • ECDH—Elliptic-Curve Diffie-Hellman
  • DH—Diffie-Hellman
  • RSA—Rivest, Shamir, Adleman
  • ECDSA— Elliptic Curve Digital Signature Algorithm
  • AES—Advanced Encryption Standard
  • GCM—Galois/Counter Mode, a mode of operation for cryptographic block ciphers
  • CBC—Cipher Block Chaining
  • 3DES—Triple Data Encryption Algorithm
  • SHA—Secure Hashing Algorithm
  • CHACHA20—ChaCha stream cipher
  • POLY1305—Poly1305 authenticator
