Work with organization audit logs
Portal for ArcGIS records user activity and any changes that occur to the system to audit logs. Audit logs are an important tool for monitoring and troubleshooting critical or breaking changes and identifying the organization members or processes that made those changes, their effects on the system, and the time those events occurred.
Audit logs can be processed by Security Information and Event Management (SIEM) tools to generate an audit trail, track trends in user activity, and monitor and address any security threats or vulnerabilities.
Audit logs capture information for the following events:
  • Accessing the organization portal site
  • Creating, deleting, updating, and disabling member accounts
  • Creating and updating user roles
  • Adding and configuring groups
  • Adding and removing members from a group
  • Sharing items
  • Changing item ownership
  • Adding, updating, moving, and deleting items
Organization audit log access
The default directory where the portal writes audit logs is <Portal for ArcGIS installation directory>/usr/arcgisportal/logs/<machine name>/audit. It is not recommended that you manually make changes to the log files in this directory through the Linux file system. If you need to move the files for backup or archival purposes, copy them to the desired location. You can change the audit log location at any time using the Portal Administrator Directory.
The default directory where the portal writes audit logs is C:\arcgisportal\logs\<machine name>\audit. You can change the audit log location at any time using the Portal Administrator Directory.
Change organization audit log settings
Audit log settings, such as log retention policy and the default directory for the logs, are inherited from portal logs. To change audit logs settings, you must change the portal log settings using the Portal Administrator Directory. For instructions, see Specify portal log settings.
Delete organization audit logs
To delete audit logs, complete the following steps:
  1. Open the Portal Administrator Directory and log in as an administrator.
    The URL is typically available at https://webadaptorhost.example.com/webadaptorname/portaladmin.
  2. Click Logs > Clean.
  3. Select the output format from the Format drop-down list.
  4. Click Clean logs.
All log files are deleted from the portal machine.
Organization audit log syntax
Portal for ArcGIS records each event in the audit log using the following JSON syntax:
    "version": "Audit record version number",
    "loggedby":"Product version",
    "timeStamp": "Epoch time value",
    "eventId": "Unique audit record identifier",
    "event": "Event Name",
    "eventLevel": "Event level",
    "status": "Success/Failure indicator",
    "statusCode": "Status code value",
    "actor": "username",
    "actorId": "user id",
    "actorRole": "User's role",
    "sourceIp": "Source IP address",
    "destinationIp": "Destination IP address",
    "destinationHost": "Destination host name",
    "resource": "Resource URI",
    "data": {
        "data_attribute1": "attribute value",
        "data_attribute2": "attribute value"
    "userAgent": "user agent information",
    "message": "Any corresponding message if applicable"
