Utility Network services
The utility network is accessed through a combination of services to support utility network workflows. Several service types are used in addition to extending the feature service to support the utility network. These extension services are enabled on the map service by the capabilities that the service will support.
A utility network is accessed through services using a combination of capabilities:
License:
The active portal account must be licensed with the ArcGIS Advanced Editing user type extension to use the create, publish, and edit a utility network in an enterprise geodatabase. Query and trace operations do not require the user type extension.
When publishing utility network services, some prerequisites must be met. These include ensuring the data is accessed using the database and portal utility network owner accounts and the ArcGIS Enterprise member accounts are licensed using the ArcGIS Advanced Editing user type extension. There are also some differences in the behavior of utility network services, whether consumed in ArcGIS Pro or as a web map.
For more information, see ArcGIS Advanced Editing user type extension.
