Event triggers
When creating a webhook, you can choose to subscribe to specific event triggers tied to API operations that will invoke your webhook and deliver the event's information through the payload. The sections below lists the available event triggers and their associated URIs or change type values for organization and feature service webhooks.
Unlike organization and feature service webhooks, geoprocessing service webhooks do not have user-defined event triggers. Geoprocessing service webhooks deliver payloads once a geoprocessing job is complete. For more information on the payloads delivered for geoprocessing services, see the Payloads topic.
Organization item events
The following table lists the event triggers for your organization's items, which include web maps, web apps, layers, packages, and PDFs:
Event trigger
URI
All trigger events for all items
/items
An item is added to the portal
/items/add
Any item is deleted
/items/delete
Delete Protection is enabled for any item
/items/protect
Delete Protection is disabled for any item
/items/unprotect
Any item is updated
/items/update
Any item is moved or its ownership is changed
/items/move
Any item is published
/items/publish
Any item is shared
/items/share
Any item is unshared
/items/unshare
The ownership of any item is reassigned
/items/reassign
A comment is added to any item
/items/addComment
A comment is deleted from any item
/items/deleteComment
A comment is updated on any item
/items/updateComment
All trigger events for a specific item
/items/<itemID>
A specific item is deleted
/items/<itemID>/delete
Delete Protection is enabled for a specific item
/items/<itemID>/protect
Delete Protection is disabled for a specific item
/items/<itemID>/unprotect
A specific item's properties are updated
The item properties that can be updated vary between item types, and there are unique actions that trigger the Update operation. For example, if the item is a web map, updating the tag, configuring a pop-up, or changing the basemap are all update events that trigger the webhook.
/items/<itemID>/update
A specific item's ownership is changed or the item is moved
/items/<itemID>/move
A specific item is published
/items/<itemID>/publish
A specific item is shared
/items/<itemID>/share
A specific item is unshared
/items/<itemID>/unshare
The ownership of a specific item is reassigned
/items/<itemID>/reassign
A comment is added to a specific item
/items/<itemId>/addComment
A comment is deleted from a specific item
/items/<itemId>/deleteComment
A comment is updated on a specific item
/items/<itemId>/updateComment
Item event trigger properties
Some of the event triggers for organization items return additional properties in their payloads. The sections below outline the additional payload properties for these triggers.
Webhooks that subscribe to the /items/<itemID>/share event trigger have the sharedToGroups property included in their payload. The sharedToGroups property specifies how an item was shared. If the item was shared with a group, the properties JSON object includes the ID for each group the item was shared with. If the item was shared with the organization as a whole, the object includes Organization. If the item was shared publicly, the object includes Everyone. The example below demonstrates sharing an item to specific groups, as well as sharing an item both publicly and to specific groups.
Examples
//groupIDs
"properties": {
  "sharedToGroups": [
    "ecd6646698b24180904e4888d5eaede3",
    "2dff15c514ad4f04b291e304e24a524b"
//Everyone and groupIDs
"properties": {
  "sharedToGroups": [
    "Everyone",
    "4adc30bb03054812a846fa592de105de",
    "a4e6e37e2f7d4bb5b64d587c91d39a2c"
Ownership of any item is reassigned
Webhooks that subscribe to the /items/reassign event trigger have the reassignedTo property included in their payload. The reassignedTo property specifies the new user an item or group is reassigned to, returning the username of the new owner in the properties JSON object.
Example
"properties": {
  "reassignedTo": ["newOwner"]
Webhooks that subscribe to the /items/<itemID>/unshare event trigger have the unsharedFromGroups property included in their payload. The unsharedFromGroups property specifies how an item was unshared. If the item was unshared from a group, the properties JSON object will include the IDs for each group the item was unshared from. If the item was unshared from the organization as a whole, the object includes Organization. If the item was unshared from the public, the object includes Everyone. The example properties below demonstrate unsharing an item from the public, as well as unsharing an item from a specific group.
Examples
//Everyone
"properties": {
  "unsharedFromGroups": ["Everyone"]
//groupID
"properties": {
Ownership of a specific item is reassigned
Webhooks that subscribe to the /items/<itemID>/reassign event trigger have the reassignedTo property included in their payload. The reassignedTo property specifies the new user an item or group is assigned to, returning the username of the new owner in the properties JSON object.
Example
"properties": {
Organization group events
The following table lists the event triggers for your organization's groups:
Event trigger
URI
All trigger events for all groups
/groups
A group is added
/groups/add
Any group is updated
/groups/update
Any group is deleted
/groups/delete
Delete Protection is enabled for any group
/groups/protect
Delete Protection is disabled for any group
/groups/unprotect
A user is invited to any group
/groups/invite
A user is added to any group
/groups/addUsers
A user is removed from any group
/groups/removeUsers
A user's role is updated in any group
/groups/updateUsers
The ownership for any group is reassigned
/groups/reassign
An item is shared to any group
/groups/itemShare
An item is unshared from any group
/groups/itemUnshare
A user submits a request to join any group
/groups/requestJoin
All trigger events for a specific group
/groups/<groupID>
A specific group is updated
Any general changes made to the group settings constitute an update. For example, changing a group's access will trigger an update event.
/groups/<groupID>/update
A specific group is deleted
/groups/<groupID>/delete
Delete Protection is enabled for a specific group
/groups/<groupID>/protect
Delete Protection is disabled for a specific group
/groups/<groupID>/unprotect
A user is invited to a specific group
/groups/<groupID>/invite
A user is added to a specific group
/groups/<groupID>/addUsers
A user is removed from a specific group
/groups/<groupID>/removeUsers
A user's role is updated in a specific group
/groups/<groupID>/updateUsers
The ownership for a specific group is reassigned
/groups/<groupID>/reassign
An item is shared to a group
/groups/<groupID>/itemShare
An item is unshared from a specific group
/groups/<groupID>/itemUnshare
A user requests to join a specific group
/groups/<groupId>/requestJoin
Group event trigger properties
Some of the event triggers for organization groups return additional properties in the payload. The sections below outline the additional payload properties for these triggers.
Webhooks that subscribe to the /groups/<groupID>/invite event trigger have the invitedUserNames property included in their payload. The invitedUserNames property specifies the usernames of users invited to a group, returning a list of usernames in the properties JSON object.
Example
"properties": {
  "invitedUserNames": [
    "u1TestUser",
    "u2TestUser"
Webhooks that subscribe to the /groups/<groupID>/addUsers event trigger have the addedUserNames property included in their payload. The addedUserNames property specifies the usernames of users who have been added to a group, returning a list of usernames in the properties JSON object.
Example
"properties": {
  "addedUserNames": [
    "u1TestUser",
    "u2TestUser"
Webhooks that subscribe to the /groups/<groupID>/removeUsers have the removeUserNames property included in their payload. The removeUserNames property specifies the usernames of users removed from a group, returning a list of usernames in the properties JSON object.
Example
"properties": {
  "removedUserNames": [
    "u1TestUser",
    "u2TestUser"
Webhooks that subscribe to the /groups/<groupID>/updateUsers have the updateUserNames property included in their payload. The updateUserNames property specifies the usernames of users whose group roles have been updated, returning a list of usernames in the properties JSON object.
Example
"properties": {
  "updatedUserNames": [
    "u1TestUser",
    "u2TestUser"
Webhooks that subscribe to the /groups/<groupID>/itemShare have the sharedItems property included in their payload. The sharedItems property specifies the itemID and item type of the item shared to a group, returning this information in the properties JSON object.
Example
"properties": {
  "sharedItems": [
      "itemId": "6cd80cb32d4a4b4d858a020e57fba7b1",
      "itemType": "Map Package"
Webhooks that subscribe to the /groups/<groupID>/itemUnshare have the unsharedItems property included in their payload. The unsharedItems property specifies the itemID and item type of the item unshared from a group, returning this information in the properties JSON object.
Example
"properties": {
  "unsharedItems": [
      "itemId": "7dd95fadaec84859ab8ed1059e675e0c",
      "itemType": "Image"
Organization user events
The following table lists the event triggers for your organization's users:
Event trigger
URI
All trigger events for all users in the portal
/users
A user is added to the organization
/users/add
Any user has signed in to the portal
/users/signin
Any user has signed out of the portal
/users/signout
Any user is deleted
/users/delete
Any user's profile is updated
An update event is triggered any time a change is made to the user's profile. However, changes made to a user's role, user type, or license are not considered an update to the user's profile.
/users/update
Any user's account is disabled
/users/disable
Any user's account is enabled
/users/enable
Any user is assigned a new role
/users/updateUserRole
Any user is assigned a new user type
/users/updateUserLicenseType
A list of user accounts are enabled
/users/bulkEnable
A list of user accounts are disabled
/users/bulkDisable
All trigger events associated with a specific user
/users/<username>
A specified user has signed into the portal
/users/<username>/signIn
A specified user has signed out of the portal
/users/<username>/signOut
A specific user is deleted
/users/<username>/delete
A specific user's profile is updated
/users/<username>/update
A specific user's account is disabled
/users/<username>/disable
A specific user's account is enabled
/users/<username>/enable
A specific user is assigned a new role
/users/<username>/updateUserRole
A specific user is assigned a new user type
/users/<username>/updateUserLicenseType
User event trigger properties
Some of the event triggers for organization users return additional properties in the payload. The sections below outline the additional payload properties for these triggers.
Webhooks that subscribe to the /users/<username>/updateUserRole have the userRoleUpdatedTo property included in their payload. The userRoleUpdatedTo property specifies the new role the user is assigned, returning the new role in the properties JSON object.
"properties": {
  "userRoleUpdatedTo": ["New role"]
Webhooks that subscribe to the /users/<username>/updateUserLicenseType have the userLicenseTypeUpdatedTo property included in their payload. The userLicenseTypeUpdatedTo property specifies the new user type that a user is assigned, returning the new user type in the properties JSON object.
"properties": {
  "userLicenseTypeUpdatedTo": ["Editor"]
Organization role events
The following table lists the event triggers for your organization's user roles:
Event trigger
URI
All trigger events for all roles in the portal
/roles
A new role is created
/roles/add
An existing role is updated
An update event is trigged any time a change is made to your organization's roles.
/roles/update
An existing role is deleted
/roles/delete
Role event trigger properties
Some of the event triggers for organization roles return additional properties in the payload. The section below outlines the additional payload properties for these triggers.
Webhooks that subscribe to the /roles/add event trigger have the name property included in their payload. The name property specifies the name of the role that was created, returning the role's name in the properties JSON object.
Example
"properties": {
  "name": ["New role"]
Feature service events
The following table lists the event triggers for feature service webhooks:
Event trigger
Value
Any event is triggered
A new feature is created
FeaturesCreated
A feature is updated
FeaturesUpdated
A feature is deleted
FeaturesDeleted
A feature is edited (for example, insertion, update, or deletion)
Attachment edits may not cause the FeaturesEdited event trigger to fire. To include attachments edits, add the AttachmentsCreated, AttachmentsUpdated and AttachmentsDeleted changeTypes when creating or modifying the webhook (e.g. set changeType to "FeaturesEdited,AttachmentsCreated" for new attachments).
FeaturesEdited
A new attachment is added to a feature
AttachmentsCreated
A feature attachment is updated
AttachmentsUpdated
A feature attachment is deleted
AttachmentsDeleted
A feature layer's schema is changed
LayerSchemaChanged
A feature layer definition is changed
LayerDefinitionChanged
A feature service definition is changed
FeatureServiceDefinitionChanged
The post operation is performed on the feature service.
To schedule a webhook using this event trigger, the feature service must have the Version Management capability enabled. For more information, see the Create webhooks documentation.
FeaturesPosted
