Band Arithmetic function
License:
Available with Image Server
The Band Arithmetic function performs an arithmetic operation on the bands of a raster layer. You can choose predefined algorithms, or you can enter your own single-line formula. The supported operators are -,+,/,*, and unary -.
Notes
When using the User Defined method to define your band arithmetic algorithm, you can enter a single-line algebraic formula to create a single-band output. The supported operators are -,+,/,*, and unary -. To identify the bands, add B or b to the beginning of the band number. For example:
When using the predefined indices, enter a space-delimited list indicating the band numbers to be used. The predefined indices are detailed below.
BAI method
The Burn Area Index (BAI) uses the reflectance values in the red and NIR portion of the spectrum to identify the areas of the terrain affected by fire.
\(BAI \space = \space 1/((0.1 \space -RED)\textasciicircum 2 \space + \space (0.06 \space - \space NIR)\textasciicircum 2)\)
Red = pixel values from the red band
NIR = pixel values from the near infrared band
Using a space-delimited list, identify the red and NIR bands in the following order: Red NIR. For example, 3 4.
Reference: Chuvieco, E., M. Pilar Martin, and A. Palacios. "Assessment of Different Spectral Indices in the Red-Near-Infrared Spectral Domain for Burned Land Discrimination." Remote Sensing of Environment 112 (2002): 2381-2396.
CIg method
The Chlorophyll Index - Green (CIg) method is a vegetation index for estimating the chlorophyll content in leaves using the ratio of reflectivity in the NIR and green bands.
\(CIg \space = \space [(NIR \space / \space Green)-1]\)
NIR = pixel values from the near-infrared band
Green = pixel values from the green band
Using a space-delimited list, you will identify the NIR and green bands in the following order: NIR Green. For example, 7 3.
Reference: Gitelson, A.A., Kaufman, Y.J., Merzlyak, M.N., 1996. "Use of a green channel in remote sensing of global vegetation from EOS-MODIS," Remote Sensing of Environment, Vol. 58, 289–298.
CIre method
The Chlorophyll Index - Red-Edge (CIre) method is a vegetation index for estimating the chlorophyll content in leaves using the ratio of reflectivity in the NIR and red-edge bands.
\(Clre \space = \space [(NIR \space / \space RedEdge)-1]\)
RedEdge = pixel values from the red-edge band
Using a space-delimited list, you will identify the NIR and red-edge bands in the following order: NIR RedEdge. For example, 7 6.
References:
- Gitelson, A.A., Merzlyak, M.N., 1994. "Quantitative estimation of chlorophyll using reflectance spectra," Journal of Photochemistry and Photobiology B 22, 247–252.
Clay Minerals method
The clay minerals ratio is a ratio of the SWIR1 and SWIR2 bands. This ratio leverages the fact that hydrous minerals such as the clays, alunite absorb radiation in the 2.0–2.3 micron portion of the spectrum. This index mitigates illumination changes due to terrain since it is a ratio.
\(Clay \space Minerals \space Ratio \space = \space SWIR1 \space / \space SWIR2\)
SWIR1 = pixel values from the short-wave infrared 1 band
SWIR2 = pixel values from the short-wave infrared 2 band
For Landsat TM and ETM+, this corresponds to bands 5 (SWIR1) and 7 (SWIR2). For Landsat 8, this corresponds to bands 6 (SWIR1) and 7 (SWIR2).
Using a space-delimited list, you will identify the SWIR2 and SWIR2 bands in the following order: SWIR1 SWIR2. For example, 6 7.
Reference: Dogan, H., 2009. "Mineral composite assessment of Kelkit River Basin in Turkey by means of remote sensing," Journal of Earth System Science, Vol. 118, 701-710.
EVI method
The Enhanced Vegetation Index (EVI) method is an optimized vegetation index that accounts for atmospheric influences and vegetation background signal. It's similar to NDVI but is less sensitive to background and atmospheric noise, and it does not become as saturated as NDVI when viewing areas with very dense green vegetation.
\(EVI \space = \space 2.5 * (NIR \space - \space Red) \space / \space (NIR \space + \space 6 * Red \space - \space 7.5 * Blue \space + \space 1)\)
Blue = pixel values from the blue band
Using a space-delimited list, you will identify the NIR, red, and blue bands in the following order: NIR Red Blue. For example, 5 4 2.
This index outputs values between 0 and 1.
Reference: Huete, A. et al. 2002, "Overview of the radiometric and biophysical performance of the MODIS vegetation indices." *Remote sensing of environment *, Vol. 83, 195-213.
Ferrous Minerals method
The Ferrous Minerals (FM) ratio method is a geological index for identifying rock features containing some quantity of iron-bearing minerals using the SWIR and NIR bands. FM is used in mineral composite mapping.
The ferrous minerals ratio highlights iron-bearing materials. It uses ratio between the SWIR band and the NIR band.
\(Ferrous \space Minerals \space Ratio \space = \space SWIR \space / \space NIR\)
SWIR= pixel values from the short-wave infrared band
For Landsat TM and ETM+, this corresponds to bands 5 (SWIR) and 4 (NIR). For Landsat 8, this corresponds to bands 6 (SWIR) and 5 (NIR).
Using a space-delimited list, you will identify the SWIR and NIR bands in the following order: SWIR NIR. For example, 6 5.
Reference: Segal, D. "Theoretical Basis for Differentiation of Ferric-Iron Bearing Minerals, Using Landsat MSS Data." Proceedings of Symposium for Remote Sensing of Environment, 2nd Thematic Conference on Remote Sensing for Exploratory Geology, Fort Worth, TX (1982): pp. 949-951.
GEMI method
The Global Environmental Monitoring Index (GEMI) method is a nonlinear vegetation index for global environmental monitoring from satellite imagery. It's similar to NDVI, but it's less sensitive to atmospheric effects. It is affected by bare soil; therefore, it's not recommended for use in areas of sparse or moderately dense vegetation.
\(GEMI \space = \space eta * (1-0.25 * eta)-((Red-0.125)/(1-Red))\)
where,
\(eta \space = \space (2 * (NIR ^{2} -Red ^{2} )+1.5 * NIR+0.5 * Red)/(NIR+Red+0.5)\)
Using a space-delimited list, you will identify the NIR and red bands in the following order: NIR Red. For example, 4 3.
Reference: Pinty, B. and Verstraete, M. M. 1992, "GEMI: a non-linear index to monitor global vegetation from satellites," Plant Ecology, Vol. 101, 15–20.
GNDVI method
The Green Normalized Difference Vegetation Index (GNDVI) method is a vegetation index for estimating photo synthetic activity and is a commonly used vegetation index to determine water and nitrogen uptake into the plant canopy.
\(GNDVI \space = \space (NIR-Green)/(NIR+Green)\)
Using a space-delimited list, you will identify the NIR and green bands in the following order: NIR Green. For example, 5 3.
This index outputs values between -1.0 and 1.0.
Reference: Buschmann, C., and E. Nagel. 1993. "In vivo spectroscopy and internal optics of leaves as basis for remote sensing of vegetation," International Journal of Remote Sensing, Vol. 14, 711–722.
GVI (Landsat TM) method
The Green Vegetation Index (GVI) method was originally designed from Landsat MSS imagery and has been modified for Landsat TM imagery. It's also known as the Landsat TM Tasseled Cap green vegetation index. It can be used with imagery whose bands share the same spectral characteristics.
\(GVI=-0.2848 * Band1-0.2435 * Band2-0.5436 * Band3+0.7243 * Band4+0.0840 * Band5-1.1800 * Band7\)
Using a space-delimited list, you will identify the six Landsat TM bands, ordered one through five and six. For example, 1 2 3 4 5 6. If your input contains six bands in the order expected, you don't need to enter a value in the Band Indexes text box.
This index outputs values between -1 and 1.
Reference: Todd, S. W., R. M. Hoffer, and D. G. Milchunas, 1998, "Biomass estimation on grazed and ungrazed rangelands using spectral indices," International Journal of Remote Sensing, Vol. 19, No. 3, 427–438.
Iron Oxide method
The iron oxide ratio is a ratio of the red and blue wavelengths. The presence of limonitic-bearing phyllosilicates and limonitic iron oxide alteration cause absorption in blue band and reflectance in red band. This causes areas with strong iron alteration to be bright. The nature of the ratio allows this index to mitigate illumination differences caused by terrain shadowing.
\(Iron \space Oxide \space Ratio \space = \space Red \space / \space Blue\)
For Landsat TM and ETM+, this corresponds to bands 3 (red) and 1 (blue). For Landsat 8, this corresponds to bands 4 (red) and 2 (blue).
Using a space-delimited list, you will identify the red and blue bands in the following order: Red Blue. For example, 4 2.
MNDWI method
The Modified Normalized Difference Water Index (MNDWI) uses green and SWIR bands for the enhancement of open water features. It also diminishes built-up area features that are often correlated with open water in other indices.
\(MNDWI \space = \space (Green \space - \space SWIR) \space / \space (Green \space + \space SWIR)\)
SWIR = pixel values from the short-wave infrared band
Using a space-delimited list, identify the green and SWIR bands in the following order: Green SWIR. For example, 3 7.
Reference: Xu, H. "Modification of Normalised Difference Water Index (NDWI) to Enhance Open Water Features in Remotely Sensed Imagery." International Journal of Remote Sensing 27, No. 14 (2006): 3025-3033.
Modified SAVI method
The Modified Soil Adjusted Vegetation Index (MSAVI2) method minimizes the effect of bare soil on the SAVI.
\(MSAVI2 \space = \space (1/2) * (2(NIR+1)-sqrt((2 * NIR+1) ^{2} -8(NIR-Red)))\)
Reference: Qi, J. et al., 1994, "A modified soil vegetation adjusted index," Remote Sensing of Environment, Vol. 48, No. 2, 119–126.
MTVI2 method
The Modified Triangular Vegetation Index (MTVI2) method is a vegetation index for detecting leaf chlorophyll content at the canopy scale while being relatively insensitive to leaf area index. It uses reflectance in the green, red, and NIR bands.
\(MTVI2 \space = \space [1.5(1.2(NIR-Green)-2.5(Red-Green))√((2NIR+1)²-(6NIR-5√(Red))-0.5)]\)
Using a space-delimited list, you will identify the NIR, red, and green bands in the following order: NIR Red Green. For example, 7 5 3.
Reference: Haboudane, D., Miller, J.R., Tremblay, N., Zarco-Tejada, P.J., Dextraze, L., 2002. "Integrated narrow-band vegetation indices for prediction of crop chlorophyll content for application to precision agriculture," Remote Sensing of Environment, Vol. 81, 416–426.
NBR method
The Normalized Burn Ratio Index (NBRI) uses the NIR and SWIR bands to emphasize burned areas, while mitigating illumination and atmospheric effects. Your images should be corrected to reflectance values before using this index; see the Apparent Reflectance function for more details.
\(NBR \space = \space (NIR \space - \space SWIR) \space / \space (NIR+ \space SWIR)\)
Using a space-delimited list, identify the NIR and SWIR bands in the following order: NIR SWIR. For example, 4 7.
Reference: Key, C. and N. Benson, N. "Landscape Assessment: Remote Sensing of Severity, the Normalized Burn Ratio; and Ground Measure of Severity, the Composite Burn Index." FIREMON: Fire Effects Monitoring and Inventory System, RMRS-GTR, Ogden, UT: USDA Forest Service, Rocky Mountain Research Station (2005).
NDBI method
The Normalized Difference Built-up Index (NDBI) uses the NIR and SWIR bands to emphasize man-made built-up areas. It is ratio based to mitigate the effects of terrain illumination differences as well as atmospheric effects.
\(NDBI \space = \space (SWIR \space - \space NIR) \space / \space (SWIR \space + \space NIR)\)
Using a space-delimited list, identify the SWIR and NIR bands in the following order: SWIR NIR. For example, 7 4.
Reference: Zha, Y., J. Gao, and S. Ni. "Use of Normalized Difference Built-Up Index in Automatically Mapping Urban Areas from TM Imagery." International Journal of Remote Sensing 24, no. 3 (2003): 583-594.
NDMI method
The Normalized Difference Moisture Index (NDMI) is sensitive to the moisture levels in vegetation. It is used to monitor droughts as well as monitor fuel levels in fire-prone areas. It uses NIR and SWIR bands to create a ratio designed to mitigate illumination and atmospheric effects.
\(NDMI \space = \space (NIR \space - \space SWIR1)/(NIR \space + \space SWIR1)\)
Using a space-delimited list, identify the SWIR and NIR bands in the following order: NIR SWIR1. For example, 4 7.
References:
Wilson, E.H. and Sader, S.A., 2002, "Detection of forest harvest type using multiple dates of Landsat TM imagery." Remote Sensing of Environment, 80 , pp. 385-396.
Skakun, R.S., Wulder, M.A. and Franklin, .S.E. (2003). "Sensitivity of the thematic mapper enhanced wetness difference index to detect mountain pine beetle red-attack damage." Remote Sensing of Environment, Vol. 86, Pp. 433-443.
NDSI method
The Normalized Difference Snow Index (NDSI) is designed to use MODIS (band 4 and band 6) and Landsat TM (band 2 and band 5) for identification of snow cover while ignoring cloud cover. Since it is ratio based, it also mitigates atmospheric effects.
\(NDSI \space = \space (Green \space - \space SWIR) \space / \space (Green \space + \space SWIR)\)
SWIR = pixel values from the shortwave infrared band
Reference: Riggs, G., D. Hall, and V. Salomonson. "A Snow Index for the Landsat Thematic Mapper and Moderate Resolution Imaging Spectrometer." Geoscience and Remote Sensing Symposium, IGARSS '94, Volume 4: Surface and Atmospheric Remote Sensing: Technologies, Data Analysis, and Interpretation (1994), pp. 1942-1944.
NDVI method
The Normalized Difference Vegetation Index (NDVI) method is a standardized index allowing you to generate an image displaying greenness (relative biomass). This index takes advantage of the contrast of the characteristics of two bands from a multispectral raster dataset—the chlorophyll pigment absorptions in the red band and the high reflectivity of plant materials in the NIR band.
The documented and default NDVI equation is as follows:
\(NDVI \space = \space ((NIR \space - \space Red)/(NIR \space + \space Red))\)
Reference: Rouse, J.W., R.H. Haas, J.A. Schell, and D.W. Deering, 1973, "Monitoring vegetation systems in the Great Plains with ERTS," Third ERTS Symposium, NASA SP-351 I:309–317.
NDVIre method
The Red-Edge NDVI (NDVIre) method is a vegetation index for estimating vegetation health using the red-edge band. It is especially useful for estimating crop health in the mid to late stages of growth, when the chlorophyll concentration is relatively higher. Also, NDVIre can be used to map the within-field variability of nitrogen foliage to understand the fertilizer requirements of crops.
The NDVIre index is calculated using the NIR and red-edge bands.
\(NDVIre \space = \space (NIR \space - \space RedEdge)/(NIR \space + \space RedEdge)\)
Reference: Gitelson, A.A., Merzlyak, M.N., 1994. "Quantitative estimation of chlorophyll using reflectance spectra," Journal of Photochemistry and Photobiology B 22, 247–252.
NDWI method
The Normalized Difference Water Index (NDWI) method is an index for delineating and monitoring content changes in surface water. It is computed with the NIR and green bands.
\(NDWI \space = \space (Green \space - \space NIR) \space / \space (Green \space + \space NIR)\)
Reference: McFeeters, S., 1996. "The Use of Normalized Difference Water Index (NDWI) in the Delineation of Open Water Features." International Journal of Remote Sensing, 17, 1425-1432.
PVI method
The Perpendicular Vegetation Index (PVI) method is similar to a difference vegetation index; however, it is sensitive to atmospheric variations. When using this method to compare images, it should only be used on images that have been atmospherically corrected.
\(PVI \space = \space (NIR \space - \space a * Red \space - \space b) \space / \space (sqrt(1 \space + \space a ^{2} ))\)
a = slope of the soil line
b = gradient of the soil line
Using a space-delimited list, you will identify the NIR and red bands and enter the a and b values in the following order: NIR Red a b. For example, 4 3 0.3 0.5.
Reference: Richardson, A. J. and C. L. Wiegand, 1977, "Distinguishing vegetation from soil background information," Photogrammetric Engineering and Remote Sensing, 43, 1541–1552.
RTVIcore method
The Red-Edge Triangulated Vegetation Index (RTVICore) method is a vegetation index for estimating leaf area index and biomass. This index uses reflectance in the NIR, red-edge, and green spectral bands.
\(RTVICore \space = \space [100(NIR-RedEdge)-10(NIR-Green)]\)
Using a space-delimited list, you will identify the NIR, red-edge, and green bands in the following order: NIR RedEdge Green. For example, 7 6 3.
Reference: Haboudane, D., Miller, J.R., Pattey, E., Zarco-Tejada, P.J., Strachan, I.B., 2004. "Hyperspectral vegetation indices and novel algorithms for predicting green LAI of crop canopies: modeling and validation in the context of precision agriculture," Remote Sensing of Environment, Vol. 90, 337–352.
SAVI method
The Soil-Adjusted Vegetation Index (SAVI) method is a vegetation index that attempts to minimize soil brightness influences using a soil-brightness correction factor. This is often used in arid regions where vegetative cover is low, and it outputs values between -1.0 and 1.0.
\(SAVI \space = \space ((NIR \space - \space Red) \space / \space (NIR \space + \space Red \space + \space L)) \space x \space (1 \space + \space L)\)
Red = pixel values from the near red band
L = amount of green vegetation cover
Using a space-delimited list, you will identify the NIR and red bands and enter the L value in the following order: NIR Red L. For example, 4 3 0.5.
Reference: Huete, A. R., 1988, "A soil-adjusted vegetation index (SAVI)," Remote Sensing of Environment, Vol 25, 295–309.
SR method
The Simple Ratio (SR) method is a common vegetation index for estimating the amount of vegetation. It is the ratio of light scattered in the NIR and absorbed in red bands, which reduces the effects of atmosphere and topography.
Values are high for vegetation with a large leaf area index, or high canopy closure, and low for soil, water, and nonvegetated features. The range of values is from 0 to approximately 30, where healthy vegetation generally falls between values of 2 to 8.
\(SR \space = \space NIR \space / \space Red\)
Reference: Birth, G.S., and G.R. McVey, 1968. "Measuring color of growing turf with a reflectance spectrophotometer," Agronomy Journal Vol. 60, 640-649.
SRre method
The Red-Edge Simple Ratio (SRre) method is a vegetation index for estimating the amount of healthy and stressed vegetation. It is the ratio of light scattered in the NIR and red-edge bands, which reduces the effects of atmosphere and topography.
Values are high for vegetation with high canopy closure and healthy vegetation, lower for high canopy closure and stressed vegetation, and low for soil, water, and nonvegetated features. The range of values is from 0 to approximately 30, where healthy vegetation generally falls between values of 1 to 10.
\(SRre \space = \space NIR \space / \space RedEdge\)
Reference: Anatoly A. Gitelson, Yoram J. Kaufman, Robert Stark, and Don Rundquist, 2002, "Novel algorithms for remote estimation of vegetation fraction," Remote Sensing of Environment, Vol. 80, 76–87.
Sultan's Formula method
The Sultan's process takes a six-band 8-bit image and uses the Sultan's Formula method to produce a three-band 8-bit image. The resulting image highlights rock formations called ophiolites on coastlines. This formula was designed based on the TM or ETM bands of a Landsat 5 or 7 scene. The equations applied to create each output band are as follows:
Using a space-delimited list, you will identify the indexes of the five bands required. For example, 1 3 4 5 6. If your input contains six bands in the order expected, you do not need to enter a value in the Band Indexes text box.
Reference: Sultan, M., Arvidson, R.E, Sturchio, N.C. & Guiness, E.A. 1987, "Lithologic mapping in Arid Regions with Landsat thematic mapper data: Meatig Dome, Egypt," Geological Society of America Bulletin99: 748-762
Transformed SAVI method
The Transformed Soil Adjusted Vegetation Index (TSAVI) method is a vegetation index that minimizes soil brightness influences by assuming the soil line has an arbitrary slope and intercept.
\(TSAVI \space = \space (s \space * \space (NIR \space - \space s \space * \space Red \space - \space a)) \space / \space (a \space * \space NIR \space + \space Red \space - \space a \space * \space s \space + \space X \space * \space (1 \space + \space s ^{2} ))\)
s = the soil line slope
a = the soil line intercept
X = an adjustment factor that is set to minimize soil noise
Using a space-delimited list, you will identify the NIR and red bands and enter the s, a, and X values in the following order: NIR Red s a X. For example, 3 1 0.33 0.50 1.50.
Reference: Baret, F. and G. Guyot, 1991, "Potentials and limits of vegetation indices for LAI and APAR assessment," Remote Sensing of Environment, Vol. 35, 161–173.
VARI method
The Visible Atmospherically Resistant Index (VARI) is designed to emphasize vegetation in the visible portion of the spectrum, while mitigating illumination differences and atmospheric effects. It is ideal for RGB or color images; it utilizes all three color bands.
\(VARI \space = \space (Green \space - \space Red)/ \space (Green \space + \space Red \space - \space Blue)\)
Red= pixel values from the red band
Using a space-delimited list, you will identify the red, green, and blue bands in the following order: Red Green Blue. For example, 3 2 1.
Reference: Gitelson, A., et al. "Vegetation and Soil Lines in Visible Spectral Space: A Concept and Technique for Remote Estimation of Vegetation Fraction." International Journal of Remote Sensing 23 (2002): 2537−2562.
WNDWI method
The Weighted Normalized Difference Water Index (WNDWI) method is a water index developed to reduce errors typically encountered in other water indices, including water turbidity, small water bodies, or shadow in remote sensing scenes.
\(WNDWI \space = \space [Green \space – \space α \space * \space NIR \space – \space (1 \space – \space α) \space * \space SWIR \space ] \space / \space [Green \space + \space α \space * \space NIR \space + \space (1 \space – \space α) \space * \space SWIR]\)
α = a weighted coefficient ranging from 0 to 1. The default value is 0.5.
Using a space-delimited list, you will identify the green, NIR and SWIR bands and the α coefficient in the following order: Green NIR SWIR α. For example, 2 5 6 0.5.
Reference: Qiandong Guo, Ruiliang Pu, Jialin Li & Jun Cheng, 2017, "A weighted normalized difference water index for water extraction using Landsat imagery," International Journal of Remote Sensing, Vol. 38, 5430-5445.
Parameters
Parameter |
Description |
Raster |
The input raster. |
Method |
The type of band arithmetic algorithm to be deployed. You can define a custom algorithm, or choose a predefined index. User Defined—Define a custom band arithmetic expression. BAI—Burn Area Index Clg—Chlorophyll Index - Green Clre—Chlorophyll Index - Red Edge Clay Minerals—Clay Minerals Ratio EVI—Enhanced Vegetation Index Ferrous Minerals—Ferrous Minerals Ratio GEMI—Global Environmental Monitoring Index GNDVI—Green Normalized Difference Vegetation Index GVI (Landsat TM)—Green Vegetation Index Landsat TM Iron Oxide—Iron Oxide Ratio MNDWI—Modified Normalized Difference Water Index MTVI2—Modified Triangular Vegetation Index Modified SAVI—Modified Soil Adjusted Vegetation Index NBR—Normalized Burn Ratio NDBI—Normalized Difference Built-up Index NDSI—Normalized Difference Snow Index NDVI—Normalized Difference Vegetation Index NDVIre—Red-Edge Normalized Difference Vegetation Index NDWI—Normalized Difference Water Index PVI—Perpendicular Vegetation Index RTVICore—Red Edge Triangulated Vegetation Index SAVI—Soil Adjusted Vegetation Index SR—Simple Ratio SRre—Simple Ratio Sultan's Formula—Sultan's Formula Transformed SAVI—Transformed Soil Adjusted Vegetation Index VARI—Visible Atmospherically Resistant Index WNDWI—Weighted Normalized Difference Water Index |
Band Indexes |
Define the band arithmetic formula if you chose User Defined for the Method parameter. If you chose a predefined index for the Method parameter, define the proper bands of the input raster dataset that correspond to the index. |
