Calculator function
License:
Available with Image Server
Map Algebra is a way to perform spatial analysis by creating expressions using algebraic operators. With the Calculator function, you can create and run expressions and incorporate them into raster function templates.
Notes
This function provides access to all existing math functions so you can make calls to them when building your expressions. To assist you, autocomplete is built in to provide access to the operators as well as the math functions.
The available operators are listed in the table below.
Arithmetic Operations
Operation
Symbol
Plus
Divide
Modulo
Times
Power
Minus
Boolean Operations
Operation
Symbol
Boolean And
Boolean Or
Relational Operations
Operation
Symbol
Equal to
Greater than
Greater than or Equal to
Less than
Less than or Equal to
Not Equal to
Trigonometric Operations
Operation
Symbol
ACos
ACos(a)
ACosH
ACosH(a)
ASin
ASin(a)
ASinH
ASinH(a)
ATan
ATan(a)
ATan2
ATan2(a)
ATanH
ATanH
Cos
Cos(a)
CosH
CosH(a)
Sin
Sin(a)
SinH
SinH(a)
Tan
Tan(a)
TanH
TanH(a)
Additional Operations
Operation
Symbol
Con
Con(a,b,c)
Is Null
IsNull(a)
Minimum of two rasters on a per-pixel basis
min(a,b)
Maximum of two rasters on a per-pixel basis
max(a,b)
Set Null
SetNull(a,b)
Parameters
Parameter name
Raster Variables
The user-defined variable name and the input raster.
Expression
Build an algebraic expression to perform spatial analysis on the input raster.
Cellsize Type
Choose which cell size to use in the output raster. If all the input cell sizes are the same, all the options will yield the same results.
  • First Of—Use the first cell size of the input rasters.
  • Min Of—Use the smallest cell size of all the input rasters.
  • Max Of—Use the largest cell size of all the input rasters. This is the default.
  • Mean Of—Use the mean cell size of all the input rasters.
  • Last Of—Use the last cell size of the input rasters.
Extent Type
Choose which extent should be used in the output raster:
  • First Of—Use the extent of the first input raster to determine the processing extent.
  • Intersection Of—Use the extent of the overlapping pixels to determine the processing extent. This is the default.
  • Union Of—Use the extent of all the rasters to determine the processing extent.
  • Last Of—Use the extent of the last input raster to determine the processing extent.
Examples of expressions
Expressions can be a simple one line of code, or it can be a several lines of code.
Simple Conditional Statement
Find elevation values above 4,000 feet. Give these areas a value of 1 and all other areas a value of 0.
Nested Conditional Statement
Find areas where slope is below 10 degrees and NDVI is above 0.5. Give these areas a value of 1. For all other areas, assign a value of 2 if slope is above 10 degrees and elevation is over 2,500 feet. All other areas are assigned a value of 3.
