Corridor function
License:
Available with Image Server
Calculates the sum of accumulative costs for two input accumulative cost rasters.
Legacy:
This function is deprecated.
The Least Cost Corridor function provides enhanced functionality or performance.
This is a global raster function.
Notes
While any two rasters can be used for the input, to obtain a meaningful result they should be unaltered accumulative cost output rasters. The order of the two inputs is irrelevant.
Parameters
Parameter name |
Description |
Distance Raster 1 (Required) |
The first input distance raster. It should be an accumulated cost distance output from Cost Distance or Path Distance. |
Distance Raster 2 (Required) |
The second input distance raster. It should be an accumulated cost distance output from Cost Distance or Path Distance. |
