Set analysis settings
Analysis settings are additional parameters that affect the results of analysis and how the analysis is run.
Analysis settings can be updated for the web map and an individual tool or raster function.
Update the analysis settings
When you set analysis environment settings in the web map, any new tool or function that is opened will inherit the map level environment settings. Only certain environment parameters will be used by a given tool or raster function. To determine the environments that a tool will use, consult the Environments section of the tool's reference page.
Complete the following steps to update the analysis settings for a web map:
On the Settings (light) toolbar, click Analysis
.In the Analysis pane, click Analysis settings.
The analysis settings are categorized into General environments and Raster environments (available with ArcGIS Image Server).
Update the settings as necessary.
Click Save.
The analysis settings are updated. To return to the original settings, click Reset defaults.
Update the environment settings for a tool or function
You can set environments individually for any tool or function that you open in the tool or raster function pane, under the Environment settings parameter group. The environments set for a tool or function will override the same setting for the web map. These settings will only be used until the tool or function is closed and will not be saved if it is opened again. If you reopen a tool or function from History, it will repopulate with the environments that were used when it was previously run.
Environment settings ensure that aspects of the analysis, such as the output coordinate system and processing extent, are controlled for your analysis runs.
Output coordinate system
Output coordinate system specifies the coordinate system for analysis and the result layer.
Projected coordinate systems preserve some aspects of features (area, shape, distance, or direction) while distorting other aspects. It is important to choose an output coordinate system that will minimize distortion in the most important aspects of your analysis. For example, an equal distance projection will minimize distance distortion when using Summarize Nearby.
The following options are available for the Output coordinate system setting:
Same as input (default)—The result of your analysis will be in the same coordinate system as the input.
Choose coordinate system—The result of your analysis will be in the coordinate system you choose. Click the Browse coordinate systems button to choose from a list of coordinate systems.
Same as layer—The result of your analysis will be in the same coordinate system as an existing layer on the web map. Click the Layer button to choose from a list of layers.
If Same as layer is specified and the chosen layer has a coordinate system defined by a Well-Known Text (WKT) string, the coordinate system will not populate in the parameter if a tool is reopened from the History pane. You can reset Output coordinate system before running the tool.
Most web maps use Web Mercator as the default projection. The Web Mercator projection distorts distance and area calculations and is not recommended for most analysis. Try the Make a web map without Web Mercator tutorial to learn how to change the projection of a web map.
Geographic transformations
Geographic transformations specify transformation methods that can be used to project data. For tools that honor the Geographic transformations environment, you can specify a list of transformation methods from system-supplied transformations. Only the transformations appropriate to the project will be used and all the others will be ignored.
This environment currently only supports raster analysis.
Analysis processing extent
Analysis processing extent specifies the extent or boundary when nonraster analysis (including feature analysis and custom web tools) is run. All input features or cells that are completely within or that intersect the specified extent are used in the analysis. The analysis processing extent can be used to limit the analysis to a specific area. This parameter uses Full extent by default.
Tip:
If you are analyzing large datasets, you may want to update the processing extent in the analysis settings for the web map. That way, the extent will be used for all tool runs.
The following options are available:
Full extent (default)—The extent provided by the tool or raster function.
Coordinates—The extent is defined by the coordinates you provide to create a bounding rectangle. Click the Set coordinates from current display extent button to populate the coordinates based on the visible extent.
Display extent—The extent is defined by the visible extent at the time when the Run button is clicked.
Layer—The extent is defined by the spatial extent of an existing layer. Click the Layer button to choose from a list of layers.
You can turn off Use a different processing extent for raster analysis. When this option is turned off, all analysis uses the option set by the Analysis processing extent parameter.
The Processing extent parameter that appears in the Environment settings group of nonraster analysis tools inherits the option set by Analysis processing extent.
Raster analysis processing extent
Raster analysis processing extent specifies the extent or boundary when raster analysis is run. This parameter has the same options as Analysis processing extent and uses Display extent by default.
Raster analysis processing extent is only available when Use a different processing extent for raster analysis is turned on. If this option is turned off, Analysis processing extent is used for all analysis.
The Processing extent parameter that appears in the Environment settings group of a raster analysis tool or raster function inherits the option set by Raster analysis processing extent.
Snap raster
Snap raster adjusts the extent of the output raster layer so it matches the cell alignment of the specified Snap raster layer for raster analysis. Click the Layer button to choose from a list of layers.
Cell size
Cell size specifies the cell size or resolution that is used to create the output raster layer in raster analysis. If no cell size is selected, the default output resolution is determined by the coarsest of the input raster datasets, unless determined by the tool. Additionally, the following options are available:
Maximum of inputs—The cell size is defined by the largest cell size of all input layers.
Minimum of inputs—The cell size is defined by the smallest cell size of all input layers.
As specified—The cell size is defined using a custom number value. This value will not be reprojected if the output is in a spatial reference that is different from the input data.
From layer—The cell size is defined by the cell size of an existing layer. Click the Layer button to choose from a list of layers.
Mask
Mask specifies a raster layer or feature layer that is used to define your area of interest for raster analysis. Only those cells that fall within the analysis mask are considered in the analysis operation. Click the Layer button to choose from a list of layers.
If the analysis mask is a raster, all cells that have a value will define the mask. Cells in a mask raster that are NoData are considered to be outside the mask and will be NoData in the analysis result layer.
If the analysis mask is a feature layer, it will be internally converted to a raster when the analysis is run. For this reason, ensure that Cell size and Snap raster are set appropriately for your analysis.
Resampling method
Resampling method specifies how to interpolate pixel values when transforming your raster dataset. This environment is used for raster analysis when the input and output do not line up, when the pixel size changes, when the data is shifted, or a combination of these situations. The following options are available:
Nearest neighbor—Used primarily for discrete data, such as a land-use classification, since it does not create new pixel values. This method is also appropriate for continuous data when you want to preserve the original reflectance values in imagery for accurate multispectral analysis. It is the most efficient in terms of processing time but may introduce small positional errors in the output image. The output image may be offset by up to half a pixel, which may cause the image to have discontinuities and a jagged appearance.
Bilinear interpolation—This method is most appropriate for continuous data. It performs a bilinear interpolation and determines the new value of a cell based on a weighted distance average of the four nearest input cell centers. It creates an output image that is smoother in appearance than Nearest neighborhood but alters the reflectance values, which results in blurring or loss of image resolution.
Cubic convolution—Suitable for continuous data. This method performs a cubic convolution and determines the new value of a cell based on fitting a smooth curve through the 16 nearest input cell centers. The result is geometrically less distorted than the raster achieved with Nearest neighbor and sharper than Bilinear interpolation. In some cases, it can result in output pixel values outside the range of input cell values. If this is unacceptable, use the Bilinear interpolation method instead. Cubic convolution is computationally intensive and takes longer to process.
Recycle interval of processing workers
Recycle interval of processing workers specifies how many image sections will be processed before restarting worker processes to prevent potential failures in long-running processes. The default is 0.
Parallel processing factor
Specify the number of raster processing service instances that can be used for processing your data.
If the tool doesn't honor the Processor type environment, or if the Processor type environment is set to CPU, the Parallel processing factor environment controls raster processing (CPU) service instances. If the Processor type environment is set to GPU, the Parallel processing factor environment controls the number of raster processing GPU instances.
By setting the Parallel processing factor environment, you can request the number of parallel workers that the raster analytics image server uses to process one raster analysis task. However, if the total number of parallel processes exceeds the maximum number of raster processing (CPU or GPU) service instances, the additional parallel processes will be queued.
Empty string—The tool will use 80 percent of the maximum number of raster processing service instances. This is the default.
Whole number—The operation will be spread across the specified number of raster processing service instances. Accepted values include
0and positive integers.Percentage—The operation will be spread across the specified percentage of available raster processing service instances. Percentages must include a percent sign (%) following the percentage value (for example,
50%).
Number of retries on failures
Number of retries on failures specifies how many times the same worker process will be attempted when there is a failure during the processing of a particular job. The default is 0.
Processor type
Specify the processor type used to run the analysis.
Automatic—The tool defines the processor type with no restrictions. This is the default.
CPU—Processing will use the CPU. CPU processing can be parallelized across multiple cores and instances, as handled by the Parallel processing factor setting.
GPU—Processing will use the GPU. GPUs are effective at graphics and image processing, where their highly parallel structure makes them efficient in processing large blocks of data in a repetitive manner. The raster analysis tools that honor this environment can distribute its job across GPU instances at multiple raster analysis server machines, as handled by the Parallel processing factor setting.
Limitations
Subtype group layers and subtype sublayers are not supported as inputs in analysis settings.
