Grayscale function
License:
Available with Image Server
Converts a multiband image into a single-band grayscale image. Specified weights are applied to each of the input bands, and normalization is applied to the output image as shown in the following example:
Specify weights:
\(Output\_temp \space = \space Band1 * Weight1+Band2 * Weight2+Band3 * Weight3+...\)
Apply normalization:
\(Output \space = \space Output\_temp/(Sum \space of \space all \space Weights)\)
The weights are often applied because some bands have variable importance depending on the application. For example, the blue band often contains more noise than other bands.
Notes
The input for this process can be any number of bands, bit depths, or pixel types. The output is one band with the same bit depth and pixel type as the input.
This function can be used with mosaic datasets.
Parameters
Parameter |
Description |
Raster |
The input raster. |
Conversion Parameters |
The weights for each of the bands comprising the input raster. |
