Interpolate Irregular Data function
License:
Available with Image Server
Point clouds, LiDAR and other datasets store their geolocation as irregularly spaced arrays of point data. The Interpolate Irregular Data function converts irregularly gridded point feature class data into a raster dataset with square pixels.
Notes
You can change the interpolation method and output cell size used in the Interpolate Irregular Data raster function.
Parameters
Parameter name
Input Samples
Value Field
The name of the field that contains the value of the points to be interpolated.
Cellsize
The cell size for the output raster layer. This can be different from the input raster, though the extent of the raster dataset will remain the same.
Interpolation Method
The resampling method to use for interpolation:
  • Nearest Neighbor—Calculates pixel value using the nearest pixel. If no source pixel exists, no new pixel can be created in the output. This is the default.
  • Linear Tinning—Uses a triangular irregular network from the center points of each cell in the irregular raster to interpolate a surface that is then converted to a regular raster.
  • Natural Neighbor—Finds the closest subset of input samples to a query point and applies weights to them based on proportionate areas to interpolate a value.
  • Inverse Distance Weighted—Determines cell values using a linearly weighted combination of a set of sample points or cells. The weight is a function of the inverse of the distance from the known points or cells.
Search Radius
The number of pixels to be included for resampling. The default value is 3 pixels.
