Mask function
License:
Available with Image Server
Using the Mask function, specify one or more NoData values, or a range of valid pixel values, to be removed from an output raster.
Notes
The table below offers an example using NoData Interpretation.
Example of pixel value inputs and output
Band 1
Band 2
Band 3
RGB
NoData
All
NoData
NoData
NoData
All
NoData
NoData
Any
NoData
NoData
NoData
NoData
Any
NoData
Parameters
Parameter name
Raster
The input raster.
This refers to how NoData Values will impact the output image.
You can select from the following two options:
  • Match Any—If the NoData value you specify occurs for a pixel in a specified band, that pixel in the output image will be NoData. This is the default.
  • Match All—The NoData values you specify for each band must occur in the same pixel for the output image to contain the NoData pixel.
NoData Values
The NoData values can be specified for each band. You can specify more than one value by entering a space-delimited list.
Included Ranges
The included ranges can be specified for each band by specifying a minimum and maximum value; any values outside the range will be returned as NoData. A pixel is included if the pixel's value falls within any of the ranges specified. Therefore, if band 1 has a range of 5–10 and band 2 has a range of 15–20, and the pixel value for band 1 is 8, this pixel will not be masked.
