Round Up function
License:
Available with Image Server
Returns the next higher integer, as a floating-point value, for each pixel in a raster.
Notes
The input values can be positive or negative.
The input Raster can be an integer or a floating point. The output of this tool is always a floating point, regardless of the input type.
If the input number has any values to the right of the decimal point, the output will be assigned the next higher integer value but will be represented as a floating-point number with no decimal portion. The following are examples:
Input Output
5.3 6.0
4.9 5.0
3.0 3.0
6.5 7.0
-0.2 0.0
-2.8 -2.0
If the input is a multiband raster, the output will be a multiband raster. The function will perform the operation on each band in the input.
If the input is a multidimensional raster, all slices from all variables will be processed, and the output will be a multidimensional raster.
Parameters
Parameter name |
Description |
Raster |
The input values to be rounded up. |
Extent Type |
Choose which extent should be used in the output raster:
Cellsize Type |
Choose which cell size to use in the output raster. If all the input cell sizes are the same, all the options will yield the same results.
