Bookmark places
Bookmarks provide shortcuts to places on a map. As a map author, you create them based on the current location, scale, and rotation of the map. When others click a bookmark, the map zooms to that location.
Tip:
You can use keyboard shortcuts to quickly complete common workflows in Map Viewer. To view the full list of keyboard shortcuts in Map Viewer, press Alt+? on Microsoft Windows or Option+? on Mac.
Create a bookmark
To create a bookmark, complete the following steps:
  1. Verify that you are signed in and, if you want to save your changes, that you have privileges to create content.
  2. In Map Viewer, open the map.
  3. In the map, navigate to the location and scale where you want to create the bookmark.
  4. On the Contents (dark) toolbar, click Bookmarks , and click Add bookmark.
  5. Provide a title for the bookmark, and click Add.
    The bookmark is added to the list of bookmarks.
Go to an existing bookmark
To zoom the map to an existing bookmark, complete the following steps:
  1. In Map Viewer, open the map.
  2. On the Contents (dark) toolbar, click Bookmarks to open the Bookmarks pane.
  3. Click the name of the bookmark you want to zoom to.
    The map zooms to the bookmark.
Update a bookmark
To update or delete an existing bookmark, complete the following steps:
  3. Optionally, update a bookmark in the following ways:
    • Drag the Reorder handles of a bookmark to reorder the list.
    • Click Edit next to a bookmark to rename it, provide a new name, and click Save.
    • Click Edit next to the bookmark you want to delete, and click Delete.
Edit a bookmark thumbnail
You can choose whether the thumbnail of a bookmark displays the map extent or an image. To edit the bookmark thumbnail, complete the following steps:
  3. Click Edit next to the bookmark with the thumbnail you want to edit.
  4. Edit the thumbnail in any of the following ways:
    • Select Screenshot to use a screenshot for the thumbnail, navigate to the map extent for the thumbnail, and click Update .
    • Select URL to use an image for the thumbnail, and provide the URL of the image.
    • Select None to remove the thumbnail.
  5. Click Save to save the thumbnail.
