Calculate field values
Field calculations allow the feature layer owner or organization administrator to alter the values of every row for a single field in the attribute table of a layer.
For example, if you have a feature layer that stores information on property sales—including the sale price and tax rate for the property location—you could add a field to the layer to store estimated property taxes. To populate the estimated_property_taxes field, define a calculation expression for the field that takes the values in the sale_price field and multiplies them by the tax_rate values.
You have two options when writing calculation expressions on fields in a feature layer:
  • ArcGIS Arcade—Arcade is ideal for calculations that require more functionality than SQL, as Arcade provides access to attribute values and feature geometry, allowing you to create expressions that include spatial operations. Additionally, if an error occurs while calculating a particular row, you can stop and troubleshoot the problem, and start the calculation again after you correct the problem.
    ArcGIS Maps SDK for JavaScript 3.44 and later will not be updated with the latest ArcGIS Arcade language features. Arcade expressions authored in JavaScript Maps SDK apps at version 3.44 or later will only support Arcade language features introduced in Arcade version 1.21 or earlier. To learn more about Arcade language support across ArcGIS products, see the Arcade version matrix.
  • SQL—Use SQL for the fastest performance with calculations that can be performed with standardized SQL (SQL-92) expressions on nonspatial attributes. You can run SQL on sync-enabled feature layers and layers configured to track feature creators and editors, whereas you cannot run Arcade expressions on such layers.
Follow these steps to calculate string, numeric, date, or GUID field values in a field from the table of a feature layer or table layer in Map Viewer.
Field calculations cannot be undone. For this reason, a good practice is to add a field, calculate values into it, and confirm the calculation is what you wanted. If it is, you can calculate the original field to equal the added field. Once you confirm the values are correct in the original field, you can delete the field you added.
GUID field values must be uppercase and enclosed in curly braces.
  1. Verify that you are signed in to your organization.
    You must be signed in as the layer or table owner or an organization administrator.
  2. In Map Viewer, open the map containing the layer, or add the layer directly.
  3. If you are working with a feature layer, on the Contents (dark) toolbar, click Layers if the Layers pane is not open. If you are working with a table layer, on the Contents (dark) toolbar, click Tables if the Tables pane is not open.
  4. In the Layers or Tables pane, click Options on the layer and click Show table to open the table.
  5. In the layer table, click Menu on the column containing the values you want to calculate, and click Calculate field.
    The calculate field window appears.
  6. Choose the language to use for the calculation, either Arcade or SQL.
  7. Optionally, click Add new to add a filter to calculate values for only a portion of the data, and click Next.
    If you do not add a filter, the calculation is run on all features. If you applied filters to the map or layers in the map before opening the calculate field window, these filters will not be recognized when calculating field values.
  8. Compose a calculation expression.
    Tip:
    For examples of common calculations that can be performed in ArcGIS Enterprise, see Example calculations.
  9. Optionally, do any of the following while composing an expression:
    • Click Test features filter to add a filter to your test features.
      This option allows you to filter your test features and does not impact what features will be calculated.
    • Click Test features to view the table of your test features.
    • Click Preview values to preview the calculated values for your test features.
    • Turn the Auto preview toggle button off to prevent the calculated values preview from automatically updating while authoring an expression. Turn the Auto preview toggle button on to allow the calculated values preview to update while authoring an expression.
    • Click Map , Table , or Map and table to navigate between views.
  10. Click Run calculation to run the expression.
The time it takes for the calculation to complete depends on the expression's complexity and the number of features in your layer.
