Change layer properties
Depending on the layer type defined in Layer properties , each layer has available options for data in a scene. For example, feature and scene layers can allow you to configure pop-ups or apply a filter, while some other layers have fewer options available, such as adjust the transparency or display layer in legend.
To change the layer properties, complete the following steps:
  1. Verify that you are signed in to the portal and open Scene Viewer.
  2. On the Designer toolbar, click Layer Manager to open the Layer Manager pane.
  3. On the layer for which you want to change properties, click Options and click Layer properties to open the layer properties.
    You can also click the layer name to open the layer properties when styling options aren't available.
  4. Change the layer properties described in the table below.
  5. On the Designer toolbar, click Save to save the layer properties to the scene.
  6. Click Done to return to the Layer Manager pane.
In Layer properties, you can change the following items:
Layer property
Pop-ups
Display and configure pop-ups to provide in-depth information about features when you click them.
Legend
Modify the legend by changing the visibility of layers, the symbology, and the names of the layers.
Transparency
Adjust the transparency of the layer.
Elevation
Change the elevation mode of the layer.
Visibility range
Set the visibility range for a single layer or multiple layers in a scene.
Filter
Apply a filter to display only specific information.
Spatial filters
Apply spatial filters to 3D object and point scene layers.
Mesh modifications
Modify integrated mesh scene layers in the scene.
Time
Configure time in a layer.
Refresh interval
set a refresh interval to keep the scene in sync with the latest data while the scene is open.
Custom parameters
Add custom parameters to the scene.
