Explore building scene layers
The Building explorer tool allows you to explore building scene layers that contain the fine details of structures, including building walls, bridge abutments, lighting fixtures, and mechanical systems. Building scene layers contain complex digital models in multiple layers that you can explore with the Building explorer tool . Often, they contain an overview layer that serves as an exterior shell and helps you view the model as a single feature.
The building scene layers are organized under the Disciplines & Categories heading. Discipline layers are group layers that organize the building scene layer content into either architectural, structural, mechanical, electrical, or infrastructure groups when they are available. These group layers contain a number of Category layers, such as walls, windows, furniture, piers, or lighting fixtures. The Building explorer tool appears at the bottom of the Scene Viewer tools when building scene layers are present.
Display a building scene layer
To explore building scene layers, do the following:
  1. Click the Building explorer tool .
  2. Select the building scene layer that you want to explore from the drop-down menu.
  3. Click the Show full model toggle button to turn on and off the ability to explore the layers in the tool and scene.
    When the Show full model toggle button is turned on, the building scene layer opens in the scene and the layers are available for viewing in the tool.
    For each building scene layer in the drop-down menu, you can set whether to allow showing the full model.
  4. Click a building scene layer element, such as a door or wall, to display a pop-up about the feature.
  5. Check the layer and sublayer check boxes to show and hide features in the scene.
You can explore only one building scene layer at a time using the Building explorer tool .
Isolate a level
You can isolate a level of a building scene layer using the Level picker in the Building explorer tool. When you choose a level, the levels below it become semitransparent for added visual context.
Choose a construction phase
When construction phases are available in the building scene layer, under the Construction phases option, you can choose a numbered phase to display. The building scene layer includes information indicating the phase during which the components were created, and optionally, when they were removed.
Click a construction phase to display all the components created during or before the phase. Components that are removed do not display.
Apply a filter
When predefined filters are present, the Building explorer tool displays the Filter button . This button indicates that predefined filters were previously configured in the scene, such as from ArcGIS Pro 2.4 or later.
To filter a building scene layer, do the following:
  1. Click the Filter button .
  2. Select a predefined filter.
    • The scene displays the components configured in the predefined filter.
    • The layer settings under the Disciplines & Categories heading no longer appear.
  3. Click the Filter button again and select No predefined filter to remove the filter and display the Disciplines & Categories layer settings.
Caution:
The Building explorer tool layer settings under Disciplines & Categories override the predefined filters. To ensure that the predefined filters display, verify that the corresponding layers are checked under Disciplines & Categories.
Search for features
You can search for an individual building scene layer feature and view a pop-up about that feature.
