Find addresses and location coordinates
You can find the address or place name and geographic coordinates of any point on a map using the What's here? tool and Location tool. The What's here? tool converts a map location into a readable address or place name (geosearch) along with providing its geographic coordinates, and the Location tool can be used to search for or convert between specific coordinates. For more information, see Geocoding and geosearch in ArcGIS Enterprise.
Map Viewer displays geographic coordinates in several common formats. You can change the location units used to display the coordinates, capture a point to see its exact coordinates, input coordinates and go to that location on the map, and format how each location unit displays. You can also display coordinates using various units by adding multiple conversions.
You can display coordinates in any of the following notations:
  • Longitude and Latitude (XY)
  • Decimal Degrees (DD)
  • Degrees Minutes Seconds (DMS)
  • Degrees Decimal Minutes (DDM)
  • Military Grid Reference System (MGRS)
  • Universal Transverse Mercator (UTM)
  • US National Grid (USNG)
  • BASEMAP—Display x,y coordinates in the coordinate system and units used by the current basemap.
Find a location's address
To find a location's address or place name on the map, complete the following steps:
  1. In Map Viewer, open the map you want to view.
  2. Move the pointer to a location on the map. Right-click on the point, then click What's here?.
    The What's here? pop-up appears on the map.
    By default, ArcGIS Enterprise is configured to use the ArcGIS World Geocoding Service as a locator. If you have added locators and enabled them to allow reverse geocoding, click Show more results to view reverse geocode results for additional locators.
  3. In the What's here? pop-up, do any of the following:
    • Click Zoom to to zoom to the location on the map.
    • Click Get directions to add the location as the route origin when getting directions.
    • Click Add to new sketch to add the location to a new sketch layer.
Find a location's coordinates
To find a location's coordinates on the map, complete the following steps:
  2. On the Settings (light) toolbar, click Map tools and choose Location .
    Tip:
    Alternatively, press Alt+Shift+F to open the Location window. To view the full list of keyboard shortcuts in Map Viewer, press Alt+? on Microsoft Windows or Option+? on Mac.
  3. Move the pointer to a location on the map and view the coordinates in the Location window.
  4. Click Expand to reveal additional location options.
  5. Optionally, click the Add conversion drop-down menu and choose additional coordinate systems to display the location.
    Tip:
    Click the box displaying the coordinate system in the Location window to quickly convert the location to another coordinate system.
  6. Optionally, do any of the following:
    • Click Remove conversion next to the coordinate system you want to remove if you have multiple coordinate system conversions and want to remove one or more from the list.
    • Click Input coordinate , choose a coordinate system, and provide the coordinates.
    • Click Capture to capture a location and switch to capture mode. When in capture mode, you can click anywhere on the map to capture the coordinates of that location.
    • Click Format settings to format how the coordinates appear. From the drop-down menu, choose the coordinate system, and change the formatting in the field below it. Click Reset to default to reset the formatting.
