Present scenes
In presentation mode, the scene content is emphasized with minimal user interface (UI) elements displayed. You can explore the content by clicking through the slides.
Switch the layout to presentation mode
Click Present at the top of Scene Viewer to switch to presentation mode. To return to the full Scene Viewer UI, click Exit presentation .
Press F11 (or Command+Ctrl+F) to enter and exit full-screen mode.
When you author a scene, you can use the Add description and Presentation style options to set how the slide description and title display in presentation mode.
View slides
On desktops and tablets, once you set presentation mode for a scene that contains slides, you can hover over Slides at the bottom of the scene to see a thumbnail of the slide or click it to go to that slide.
In the Slide list menu , you can view a list of the slides with thumbnails and select a slide. Click Exit slide list to close the slide list.
To move through slides using the keyboard of a remote device, press < or >, PgUp, or PgDn.
When there are many slides, the Slides buttons appear smaller to indicate that there are more slides before or after that point. When you've reached the last slide, click Restart to return to the first slide.
Additional information
On mobile devices, tap Menu to get more information such as details about the scene, help documentation, or ArcGIS Online.
For embedded scenes, click Information to learn more.
