Add a layer from URL
You can add a layer to a scene from a URL pointing to an ArcGIS service or a 3DTiles tileset.json.
To add a layer from a URL, complete the following steps:
Click Add Layers
on the Designer toolbar.Click Add layer from URL
to open the Enter Layer URL pane.Provide the URL of the layer in the Layer URL text box.
Provide a name for the layer in the Layer name text box.
Optionally, do the following to append custom parameters to requests made to the layer:
Under Custom parameters, click Configure custom parameters to open the Custom request parameters pane.
Click Add parameter.
Provide the name of the parameter you want to append in the Parameter text box.
Provide the parameter value in the Value text box.
Repeat these steps for each parameter you want to append.
Click Done to apply the changes and return to the Enter Layer URL pane.
The specified custom parameters are automatically applied to all requests made to the layer.
Click Add to add the layer to the scene.
The following limitations apply when adding a layer from a URL:
You can only add 3D tile service URLs that end with
tileset.json.Scene Viewer does not support Google global mesh layers.
