Use an S3 bucket for the object store
If you upgrade an ArcGIS Enterprise deployment in AWS that does not include an object store, create a folder in an Amazon Simple Storage Service (S3) bucket and register it as the ArcGIS Enterprise hosting server's object store so organization members can publish hosted 3D layers.
Tip:
New ArcGIS Enterprise deployments you create using any of the following can include an S3 bucket registered as the object store:
The ArcGIS Enterprise Cloud Builder for Amazon Web Services app and command line interface
The AWS CloudFormation template provided by Esri to create a single-machine ArcGIS Enterprise deployment
The AWS CloudFormation template provided by Esri to create a highly available ArcGIS Enterprise deployment
Prerequisites
You need the following to register an S3 bucket to use as the hosting server's object store:
An Amazon Web Services account that has access to Amazon Simple Storage Service (S3)
ArcGIS Enterprise does not support Amazon S3 directory buckets.
An Access Key and Secret Key for your AWS account or a predefined IAM role
If you add the object store to an ArcGIS Enterprise deployment that you upgraded from 11.3 or 11.1 using an AWS CloudFormation template provided by Esri, you may need to update your existing IAM role.
An empty folder in an S3 bucket in the same region as the rest of the ArcGIS Enterprise deployment
Register the S3 bucket
You can register the folder in a bucket from the ArcGIS Server Administrator Directory, as described below, or using ArcGIS API for Python.
Follow the steps below to use the ArcGIS Server Administrator Directory for the hosting server site to register the S3 bucket with the hosting server to act as the ArcGIS Enterprise object store.
Sign in to the ArcGIS Server Administrator Directory for the hosting server.
You must sign in as the primary site administrator of the hosting server site, or use OAuth credentials to log in using ArcGIS Enterprise.
Go to data > registerItem.
The Register Data Item page appears.
Based on the type of authentication you use to access the folder in the bucket, copy the appropriate JSON from the Object store example section of Register Data Item in the ArcGIS REST API help. Paste it into the Item field. Replace the information in angle brackets (<>) with the appropriate information for your deployment.
The namespace used for the bucket must be unique for this ArcGIS Server site.
Click Register Item.
