Uninstalling ArcGIS Server silently
The following steps guide you through the ArcGIS Server silent uninstallation process on Linux. Performing a silent installation of ArcGIS Server doesn't require an X display or user interaction during the installation process.
  1. Stop ArcGIS Server by:
    • Executing the stopserver script (based on the default installation location):
      ${HOME}/arcgis/server/stopserver.sh
    OR:
    • Using the shortcut on your desktop environment: ArcGIS > Stop ArcGIS Server
  2. If ArcGIS Server is configured to be started with the operating system, follow the steps below to remove the daemon:
    1. Switch to root user.
    2. Remove the daemons by executing the commands appropriate for your operating system::
      If your operating system supports systemd, run these commands to remove links in /etc/systemd/system/multi-user.target.wants:
      systemctl disable arcgisserver.service
      rm -f /etc/systemd/system/arcgisserver.service
      If ArcGIS Server is installed on a Red Hat Linux machine that supports SysV, run these commands:
      $ chkconfig --del arcgisserver
      $ rm -f /etc/rc.d/init.d/arcgisserver
      If ArcGIS Server is installed on a SUSE Linux machine that supports SysV, run these commands:
      $ insserv -r arcgisserver
      $ rm -f /etc/init.d/arcgisserver
    3. End the root user session.
  3. Execute the uninstallation script as shown below (based on default installation location):
    ${HOME}/arcgis/server/uninstall_ArcGISServer -s
The uninstaller does not remove configuration, log, and user-created files.
This topic is not relevant for ArcGIS Enterprise on Windows.
