Connect to ArcGIS Server from ArcGIS Pro
When working in ArcGIS Pro, you can connect directly to an ArcGIS Server site. This allows you to work with content and, if you have the appropriate credentials, to publish services. If the server is federated with ArcGIS Enterprise, you provide credentials to the portal's identity store; if the server is not federated, you provide credentials for the server's security store.
Connection types
You can connect to a server in ArcGIS Pro as an administrator, a publisher, or a user to accomplish tasks and work with server content.
The type of connection you can make from ArcGIS Pro to a server depends on whether the server is federated with ArcGIS Enterprise. You can only connect to a federated server from ArcGIS Pro as a user. However, you can connect to a stand-alone server from ArcGIS Pro as a user, as a publisher, or an administrator.
Learn more about connecting to GIS servers from ArcGIS Pro
Administrator connections
When you connect to an ArcGIS Server site as an administrator, you can manage the site's data stores and publish web tools and services.
When you connect, you'll be prompted for a username and password for a user who has administrative privileges to the ArcGIS Server site. This can be either the primary site administrator account that you defined when you created the ArcGIS Server site (in other words, when you first signed in to ArcGIS Server Manager) or another account that has been added to your security store and granted administrative privileges.
Publisher connections
When you connect to an ArcGIS Server site as a publisher, you can publish GIS resources, such as map documents, databases, and service definitions, to your server. You can also configure and publish draft services that reside locally on disk or in the Drafts folder of your connection to the server. You cannot edit site properties.
When you connect, you'll need to enter a username and password for a user who has been granted at least publishing privileges by an administrator.
User connections
When you connect to an ArcGIS Server site as a user, you can view and use the services published to the site. However, you cannot edit server or service properties or publish services.
