Set WCS properties
The Open Geospatial Consortium (OGC) Web Coverage Service (WCS) provides an open specification for sharing raster datasets on the web. If you publish a map image layer or imagery layer with WCS enabled, the WCS service is exposed as a capability of the layer. If you enable WCS on a geodata service, a corresponding WCS item is created.
A WCS service's properties are reflected in its capabilities files so that whoever consumes the service can have a better understanding of the publisher. When publishing a WCS service with system-generated capabilities files (the default), it is recommended that you populate the WCS properties. You can also set the properties using an external capabilities file. You can manage WCS properties when configuring a web layer in ArcGIS Pro, in ArcGIS Server Manager, or from the portal.
Enter WCS properties
To populate or modify WCS service properties from the portal, follow these steps:
Sign in to the organization as the item owner with publishing privileges or an administrator.
Open the item page for the layer with WCS enabled or WCS item.
Click the Settings tab.
Scroll to the WCS section and expand the Configuration heading.
Under Properties, choose Enter service properties.
Populate or modify the following properties:
Property
Name
The name of the map, image, or geodata service that was used to create the WCS service. This property is automatically populated and should not be modified.
Default version
The default WCS version that a client uses to access the service—for example, 2.0.1.
Support EO profile
Indicates whether to support Earth Observation application profile in WCS 2.0.1.
Title
A readable title to briefly identify the WCS service, for example:
Land cover change in Marion County, 1970 to 2010.
Abstract
A narrative description that provides additional information about the WCS service, for example:
WCS service maintained by Acme Corporation. Contact: webmaster@wmt.acme.com. Imagery showing land cover change in Marion County from 1970 to 2010.
Keywords
A list of keywords or keyword phrases describing the WCS service, which aid in catalog searching, for example:
land cover, change, Marion County, imagery
Fees
Text describing the fees imposed when accessing the WCS service, for example:
none
Access constraints
Text describing the restrictions and legal prerequisites for accessing and using the WCS service, for example:
For internal use only. Do not distribute.
Max image width
To prevent users from downloading large amounts of data, you can set the image size limit (in pixels) for the GetCoverage request by defining the maximum image width and maximum image height, for example:
Max image width: 256
Max image height: 256
Max image height
Provider name
The name of the WCS service provider, for example:
NASA
Provider website
A link to a site with information about the WCS service provider, for example:
https://www/noaa.gov
Responsible person
The primary contact person for the WCS service, for example:
Jon Smith
Responsible position
The position of the contact person for the WCS service, for example:
IT Analyst
Address
The address of the WCS service provider, for example:
380 New York Street
City
The city in which the WCS service provider resides, for example:
Redlands
State/Province
The administrative area in which the WCS service provider resides, for example:
California
Postal code
The postal code in which the WCS service provider resides, for example:
92373
Country
The country in which the WCS service provider resides, for example:
USA
Phone
The telephone number where the primary contact person for the WCS service can be reached, for example:
+1 909 793-2853
Fax
The fax number where the primary contact person for the WCS service can be reached, for example:
user@host.com
Email
The email address of the WCS service provider, for example:
user@host.com
Online resource
The Online Resource property lists the URL of the WCS service. It is necessary for a WCS client to communicate correctly with your WCS service. This property is automatically populated and should not be modified.
Service hours
The hours in which the primary contact is available to service requests, for example:
24/7
Contact instructions
Special instructions that should be considered before contacting the WCS service primary contact, for example:
Email John with normal requests, phone John for emergency requests.
Role
Function performed by the party responsible for the WCS service, for example:
PointofContact
The following characters cannot be included in any of the layer properties:
&,<,>,'. To learn more, see Special characters in service properties.Click Save.
The edits are applied immediately.
Configure the use of external capabilities files
To configure your WCS service to use external capabilities files, you'll need to update the service to reference the URL of your capabilities files. To do so from the portal, follow these steps:
Under Properties, choose Use external capabilities files.
In the Specify location box, specify the URL of the folder where you placed your capabilities files plus the common prefix you used for the files.
Click Save.
