Use the Analysis Layers page
page in ArcGIS Excalibur to determine the web services that are available to you in your content and your organization's content that you can use in the application. The Analysis Layers view displays information about each available web service and can be connected directly to the Search and Discover page or canvas.
Filter by layer title
The Analysis Layers page can be filtered by the layer title.
Enter the name of a layer in the input text box.
Delete the text to clear the text box.
Sort by field
The web services can be sorted in ascending or descending order by fields such as date created, date modified, owner, or title to help identify layers.
Choose a field from the Sort
menu.Options are
Created,Last Modified,Item Owner,Item Type, andItem Title.Last Modifiedis the default field.The Analysis Layers list is dynamically sorted based on the chosen field.
Click Ascending or Descending in the Sort menu to switch between ascending and descending order.
Descending order is the default sort direction.
Filter by layer type
The Analysis Layers page can be filtered by layer type.
Click Filter
and select the specific layer types you want to view.As filters are applied, the layer list populates with layer types that are selected in the filter.
Click the same layer type again in the filter drop-down menu to remove it.
Refresh list
Click Refresh
to reload the Analysis Layers page. This displays the services that are available to you from your content or your organization's content.
Layer information
Each layer card displays the following information in the Analysis Layers list item details:
Name
Layer type
Owner
Last updated
When information on a layer's item details page is edited, the changes are reflected on the layer card the next time the list is refreshed.
Search and Discover
When you click Search
on any ArcGIS imagery layer or ArcGIS video layer, the Search and Discover page appears, where you can search for, discover, and queue images or videos for further use. The search map will be zoomed to the extent of the service where you can define filters such as the area you want to search.
If the service is a non-query-enabled service, you cannot search against that service in Search and Discover.
Learn more about the Search and Discover page
View in the Canvas
When you click View
, the canvas opens and you can focus on and work with specific images or videos using the display, comparison, and analysis tools. When clicking View
on an image service, the Map Panel view in the canvas zooms to the extent of the web service and the Image Metadata Table is populated with corresponding images. When clicking View
on a video service, the Map Panel view in the canvas zooms to the extent of the video and the Focus Panel view has the video loaded and ready to play.
View Layer Details
For more information about a specific layer, click a layer in the Analysis Layers list. Layer Information opens displaying additional details for the selected layer. You can view your layer in the canvas by clicking View in Canvas
or click the drop-down arrow and select More Details
to view the Layer Details page for this layer. The Layer Details page provides information and management options for analysis layers in ArcGIS Excalibur. Depending on the layer type, you can view layer metadata, update item information, access service endpoints, and manage layer-specific settings.
Delete an item
You can delete an item from the Analysis Layers page if you are the owner of a layer or an administrator. To delete an item from the Analysis Layers page, complete the following instructions:
From the Analysis Layers page, navigate to an item you own.
Click the layer you want to delete to display the Layer information panel.
Click the drop-down arrow and then click Delete Layer
.Additionally, click Cancel to go back to the Analysis Layers page.
Click Delete.
