Use search and discover
Using the search functionality, you can perform an interactive search and selection of available imagery and video from a web service. You can also set search settings, preview imagery, view image metadata, and queue images and videos for further use.
Access Search and Discover
You can access Search and Discover from the following in ArcGIS Excalibur:
  • On the ArcGIS Excalibur home page, click Find Through: Search and Discover.
  • From anywhere in the application, click Search in the side menu.
Once the Search and Discover page is open, connect to an active layer to begin your search experience.
Select an active layer
You must set an active layer before performing a search. The list of available layers is in the Collections panel at the top of the search map. You can filter content type by selecting Imagery Collections or Video Collections.
To select an active layer, complete the following steps:
  1. Click Imagery Collections, Video Collections, or use the Collections option at the top of the page to open the Browse Collections panel.
    The Browse Collections panel opens to the Layers tab by default. If you select Imagery Collections, only imagery layers will appear. If you select Video Collections, only video layers will appear.
  2. Click the Saved tab to view saved search layers or the Add from Web tab to connect to a layer via URL.
    The Layers tab displays all available layers within your organization that you can use for search and discovery.
  3. Search for a specific layer to use in Browse Collections.
  4. Click the Connect button to run a search on the layer.
The search completes and the map zooms to the extent of the results, the footprints appear on the map, and results are listed in the Results Table. You can use the widgets on the side of the map to do the following:
  • Toggle Search Layer —turn on or off the source layer imagery and see a preview of the imagery over the map. By default, images are toggled off, but you can toggle them on at any time. This option is only available when connected to an imagery layer.
  • Toggle Footprints —turn on footprints to make the outline of images and videos on the Results tab visible on the search map. By default, footprints are toggled on (visible), but you can toggle them off at any time.
  • Change the basemap—change the basemap using Basemaps widget.
  • Find a location—Search for a specific address or location using the Find a location widget.
  • Zoom in and Zoom out—zoom in and out to change the extent of the map.
  • Use the default map view—return to the default map extent using the Default Map View widget.
    The default basemap and map extent can be set in My Settings.
You can change the connected active layer at any time by following steps 1-4 again. Any existing results and filters will be reset when a new layer has been selected. You can also save the current connected layer so it will appear on the Saved tab in the Browse Collections panel by clicking the star next to the service name at the top of the page.
Run a site level search on video
If your environment is federated with an ArcGIS Video Server and has a spatiotemportal big data store configured, you can perform a single search across all indexed video layers in that data store rather than searching each video layer individually. This provides a centralized way to discover video content across your organization, saving time and ensuring relevant footage is not overlooked.
This capability is especially useful in environments with many video feeds, collections, or archived recordings distributed across multiple layers. By searching across all available video content from one location, you can quickly identify datasets that contain coverage for a specific area and time period, streamlining workflows for analysis, investigation, and situational awareness.
To run a site level search, do the following:
  1. Enable a Video Search Store in the configuration settings.
  2. In the Search and Discover page, click Video Collections.
The search runs automatically against all video layers available in the configured spatiotemportal big data store and the results appear in the Search Results panel. You can narrow down these results to a specific area of interest by defining the map extent, using the draw tools on the map to define an area, or by specifying a name or date range filter. Additionally you can view the details of these results for more interactions.
Search by map extent
You can search on the active layer using your current map extent.
  1. Pan and zoom to an area of interest in the map.
  2. Click Search area at the top of the map.
When complete the map zooms to the extent of the search results, footprints appear on the map, and results are listed in the Results Table.
Search by area of interest geometry
Search within an area of interest by drawing an area on the map. Learn how to apply an area of interest filter.
Search by saved search query
Repeat the same search against the same layer on a regular basis by saving search queries against your filters and active layer. You can click the save query to search and discovery new or changed content at any time.
To create a saved search query, complete the following steps:
  1. Apply the filters you want your layer to search against.
  2. Click Save .
    The Create New Query dialog box appears.
  3. Provide information about your query:
    • Name (required)
    • Description
  4. Click Save to save your query.
Your query saves and appears in the My Saved Queries list.
My Saved Queries
The My Saved Queries list contains all the saved queries on layers you previously had saved queries. Clicking Queries opens a list that shows all the queries you saved across multiple layers.
Use a query to search for imagery or video
To use the My Saved Queries list to search for imagery or video, complete the following steps:
  1. Click Queries .
    The My Saved Queries list opens to the saved queries.
  2. Locate the query you want to search against and click then Run Query to run the search.
    Results appear in the Results list and in the map.
Running a saved query on a different layer will clear the current  Results, change the map extent, and update the active layer to the layer defined in the query.
Edit a saved query
You can edit a query if you want to change the saved query Name or Description. To edit your saved query, complete the following steps:
  1. Click Queries .
    My Saved Queries opens to the saved queries.
  2. Locate the query you want to edit and click then View Details.
    The query details appear.
  3. Click Edit and change the Name or Description.
  4. Click Save to save your changes.
Delete a saved query
You can delete a query if it is no longer applicable. To delete your saved query, complete the following steps:
  1. Click Queries.
  2. Locate the query you want to delete and click then Delete Query to delete the query.
    A message appears confirming the deletion.
You can delete all saved queries by clicking the Delete All button in the corner of the My Saved Queries list.
