User settings
User-defined settings provide flexible and relevant experiences based on project needs. User settings are stored and saved in an account. This allows access to the ArcGIS Excalibur application on machines in different locations while maintaining a customized experience when signed in with the same account.
User settings are defined and set in the My Settings section of ArcGIS Excalibur and scale across numerous aspects of the application. Certain settings allow customization of the Search and Discover and Canvas experience by choosing a default basemap and initial extent. Other settings allow changes to the app theme based on the lighting environment where the application is being used. Click My Settings
on the side navigation bar to access the user settings.
In My Settings, click Clear Saved Settings at any time to return the user settings to the application defaults.
App theme
Change the app theme when the application is opened. The default app theme is dark mode.
Dark Mode works well when viewing imagery or video in dark or dimly lit operating environments.
Light Mode works well when viewing imagery or video in brighter and well-lit environments.
Click Update Settings to save the changes.
Alternatively, the app theme can be changed by clicking Toggle Theme
on the side pane.
Start page
Choose the active view when the application opens.
Connect View
—The default view of the application is useful if day-to-day tasks vary between search and discovery, ad-hoc analysis, and preplanned imagery or video tasks.Projects View
—Lists the Excalibur projects available.Search and Discover View
—Provides interactive tools to search and discover imagery and video based on defined location and search filters.Analysis Layers View
—Provides a quick way to directly connect to an available web service for search and discovery or for working with imagery and video services.
Once a start page is chosen, click Update Settings to save changes.
Map settings
The map settings tab controls the default starting extent when searching for imagery or video in the Search and Discover view, and to choose the background map when searching for imagery or video in the Search and Discover view, or working with imagery or video in the canvas view. To set a basemap and extent preference, complete the following steps:
Click Basemaps
and choose a background map.Choose a default extent by doing one of these:
Pan and zoom to the desired map extent.
Use Zoom In
or Zoom Out
to choose an extent.Use Draw Extent
to draw an area on the map.
Click Clear Drawn Extent
to erase the extent and start over.Click Update Settings to save the chosen extent.
The default basemap and extent of ArcGIS Excalibur are based on the organization's default basemap and extent.
