View existing Excalibur projects
An Excalibur project is a dynamic way to organize and reference resources that are required to complete a task in a single location. As an authorized user in your organization, you can discover the Excalibur projects that are available to you using the Excalibur projects list page. This page displays information about each available Excalibur project, such as name, description, and project creator. Each project can be opened directly from the view.
Access the Excalibur projects list
You can access the Excalibur projects list from two locations in ArcGIS Excalibur:
On the ArcGIS Excalibur home page, click Review and Work On: Excalibur Projects.
From anywhere in the application, click the Excalibur Projects
button in the side menu.
Filter by project name
The available Excalibur projects can be filtered by the project name.
Type the name of an Excalibur project in the input text box and click Enter to search.
Delete the text to clear the name filter.
Sort by fields
The Excalibur projects list can be sorted by key fields in ascending or descending order.
Choose a key field in the Sort menu.
Date Created
Last Modified
Title
Owner
The default sort field is Last Modified.
The Excalibur projects list is dynamically sorted based on the field selected.
Click Ascending/Descending in the Sort menu to switch between ascending and descending order.
Descending order is the default sort direction.
Filter by project type
The Excalibur projects list can be filtered by the projects you own, projects shared with your organization or groups, and projects that are shared with everyone.
Click My Organization.
Select My Projects.
As the filter is applied, the projects list updates dynamically.
Refresh the Excalibur projects list
Click the Refresh
button to refresh the Excalibur projects list to display the projects that are available to you in your content or your organization's content.
Open an Excalibur project
To open an Excalibur project, click the Open Project
button on an Excalibur project card. The project opens in the canvas view with specific tools based on the project capabilities. To learn more about working with an Excalibur project, see Open an Excalibur project. Alternatively, click View Details
to configure the project capabilities before opening the project in canvas view.
Excalibur projects created before ArcGIS Excalibur 4.0 must be upgraded for users to access them. When the project owner or an administrator opens the project it will be automatically upgraded and can be accessed by users for collaboration based on its sharing properties.
Delete an Excalibur project
To delete an Excalibur project, click the Delete
button. A dialog box prompts you to confirm your choice. Optionally, you can choose to delete additional items related to the Excalibur project.
Alternatively, you can also delete a project from the Project Details page.
You may only delete projects you own unless your account has administrator privileges.
