Open Excalibur projects
An Excalibur project can be opened from the Excalibur projects list. By default, the project opens in the canvas view. The project capabilities determine the available tools. The sections below describe the various project items you'll encounter based on the type of project you're opening and its corresponding resources.
Images and video from a web service
All Excalibur projects have an image, a set of images, an imagery layer, or a video layer from which the Excalibur project was created. The image or images may be available in the supported focus view based on the type of imagery.
Bookmarks tool
A bookmark is a navigation shortcut to a position on a map or perspective in the map to return to later. When you create a bookmark, it references the map it was created from. You can save a project bookmark through an Excalibur project in the canvas and use web map bookmarks if the web map being used in the project has bookmarks saved to it.
The Bookmarks
menu lists all the bookmarks in the associated project and in the web map being used within the project. You can click the Zoom to bookmark extent
button on a bookmark as a shortcut to navigate to a position in the project.
Create a bookmark
Create bookmarks by clicking Create Bookmark from the Bookmarks
menu located in the header of the map panel. To save a bookmark, complete the following steps:
In the project, navigate to the location or extent in the map you want to bookmark.
Provide the following:
Name—A memorable name for the bookmark
Description—A summary of the bookmark
Click Save.
The bookmark appears in the Project Bookmarks menu.
Edit a project bookmark
To edit a bookmark, complete the following steps:
In the project, click Bookmarks
.Locate the bookmark on the Project tab and click Edit Bookmark
.Edit the Name and Description of the bookmark.
Optionally, adjust the extent of the map.
Click Save to update your changes. Click Cancel to return to the Project Bookmarks menu.
Delete a project bookmark
To delete a bookmark, complete the following steps:
.Locate the bookmark on the Project tab and click Delete Bookmark
.The bookmark is removed from the project bookmarks.
Use web map bookmarks
To use a web map bookmark, the web map being used within the project must have bookmarks saved to it. Bookmarks can be saved to web maps when they are created in Map Viewer in Portal for ArcGIS, ArcGIS Online, or ArcGIS Pro. To use a web map bookmark in an Excalibur project, complete the following steps:
Ensure that the web map being used in the project has bookmarks saved to it. If needed, navigate to the project details to switch the project web map.
.Locate the web map bookmarks on the Web Map tab.
Click the Zoom to bookmark extent
button on the web map bookmark as a shortcut to navigate to the position of that bookmark in the project.
To edit or delete a web map bookmark, this must be done within the web map in Map Viewer in Portal for ArcGIS, or ArcGIS Online, or ArcGIS Pro.
View and edit project instructions
To view and edit the project instructions within an open project, complete the following steps:
Click More
in an open project.Click Instructions
.Review the project instructions, supporting project materials, and any added Workflow Manager jobs for this project.
If you are the project owner or an admin, click Edit and make any changes to the written instructions.
Click Update to save any changes.
Project web map
When an Excalibur project is created, a web map is created also and set as the project web map. Any Excalibur project can include an existing web map that contains layers to provide context for an Excalibur project.
When you open a project, the web map appears in the Map Panel. If the web map contains layers, the layers are overlaid on top of the image in both the map panel and the Focus Panel if an image service is being used as the focus layer. These layers can be turned on or off, or you can interact with them to view additional information.
