Apply search filters
The search filters help you refine your results when searching for imagery or video. These search filters are based on your active search service as the metadata within this service defines which filters are available for use. If the active service contains the correct supported metadata, you can run a search based on the following filters: Name, Date Range, Cloud Cover (imagery only), Predicted NIIRS (imagery only), and Obliquity (imagery only). Additionally, you can run a search based the map extent or a defined area of interest using the draw tools on the map. If the metadata for these filters does not exist in your active search service, these filters will not display in the Filters panel. The ability to search by the map extent or an area of interest will always be available regardless of your active search service.
Apply an area of interest filter
Use the map extent, point, rectangle, or area geometry to discover imagery or video on the map.
To apply an area of interest filter, complete the following steps:
  1. Click one of the map tools available:.
    • Search current map extent—Zoom or pan to a specific area on the map, and that extent will define your area of interest. This is the default.
    • Point—Click the map to drop a point.
    • Polygon—Click the map to define a side. Double-click to complete the polygon.
    • Rectangle—Click and drag the map to draw a rectangle.
  2. Click Search area to perform the search.
  3. Optionally, click to remove the geometry graphic from the map and redraw the area or choose a different tool for the search.
When using an area of interest filter against a video layer, a list of markers is returned that identifies the number of times the specified location intersects with the video coverage and the duration of each marker. Learn more about timeline markers.
Use the Name filter
The Name filter allows you to limit search results to imagery or video layers that match text you enter.
To use the name filter, complete the following steps:
  1. Run a search on a layer to populate the Search Results list.
  2. Click the Filters button.
  3. Type one or more keywords to use to search.
  4. click Run Search.
Resulting items appear in the Search Results list. The results are empty if no layers match the search keywords.
Use the Date Range Filter
The Date Range filter allows you to narrow your search results based on a preferred date range. When a start date or end date is specified, all images after the start date and before the end date are returned respectively.
To use the date range filter, complete the following steps:
  3. Choose your desired start date or end date from the calendar pickers in the Date Range filter.
    By default, the Date Range Filter is set to the oldest image (Start Date) and the newest image (End Date) in the collection. You cannot pick a date beyond this date range threshold.
  4. Click Run Search to complete your search.
Use the Cloud Cover filter
Filter your search result by a maximum cloud cover percentage with the Cloud Cover filter. Set the desired percentage and only those images whose cloud cover metadata does not exceed the specified value are returned. This filter is only available for imagery layers.
To use the Cloud Cover Filter:
  3. Move the slider to your desired maximum cloud coverage percentage in the Cloud Cover filter.
    The chosen percentage appears above the slider and changes dynamically.
Use the Predicted NIIRS Filter
Refine search results based on National Image Interpretability Rating Scales (NIIRS) to find imagery that meets your desired image quality with the Predicted NIIRS Filter. With this filter you narrow the search results based on the minimum amount of detail you want to see in your imagery. The NIIRS value ranges from 0.1 to 9.0 increasing by 0.1. The filter returns only those images whose predicted NIIRS values are greater than or equal to your set value. This filter is only available for imagery layers.
To use the Predicted NIIRS Filter, complete the following steps:
  3. Move the slider to your desired Predicted NIIRS value in the Predicted NIIRS ftiler.
    The chosen value appears beside the slider and changes dynamically.
Use the Obliquity filter
Set the maximum camera angle tilt from nadir (vertical) of searched imagery with the Obliquity Filter. Use this filter to return only those images whose camera angle is greater than or equal to your specified value. This filter is only available for imagery layers.
To use the Obliquity Filter, complete the following steps:
  3. Move the slider to your desired maximum angle in the Obliquity filter.
    The chosen oblique angle appears on the top of the slider and changes dynamically.
