Save a project
After working with imagery or video in the canvas, you can save your work to an Excalibur project. Click Save to save your progress on imagery or video you reviewed and analyzed. You must have the appropriate privileges to save. Save is visible in the toolbar header in the canvas view if you own the project or are an administrator.
Save to an Excalibur project
To save your work to a project, complete the following steps:
  1. Click Save on the canvas toolbar.
    The Create an Excalibur Project panel appears.
  2. Provide information for the following parameters:
    • Project Title (required)
      This name should be unique. If the same name as an existing folder in your content is detected, a new folder is created with the same name and the word copy appended to it.
    • Folder name (required)
    • Web Map (required)
      This option will only be available if you changed the web map in the canvas before clicking Save. If you changed the web map using the Web Map option in the canvas to one that you own, you will have the option to update the current web map in the canvas and save the project with the web map you selected or the option to create a copy of the web map you have selected and use this copy as the project web map instead. If you changed the web map to one that you do not own, you will only have the option to enter a Web Map Title and this will create a copy of the web map you have selected and will use this copy as the project web map.
    • Project Instructions (required)
  3. If you have records selected in the Image Metadata Table, use the full layer to define the project analysis layer and not limit the layer to the selected records from the metadata table, or use the selected records in the metadata table to define the project analysis layer.
  4. Optionally, add a summary and tags for the Summary and Tags parameters, respectively.
  5. Choose to share the project publicly, with your organization, or keep it private.
    Optionally, you can share the project with a group. The default is Owner.
  6. Click Create to create a project.
    A loader appears and you are notified once the project is created successfully.
    The title of the project also appears and reflects your changes, and a folder for the project is created in your content. A web map is created with the Excalibur project and set as the project web map. This can be changed on the Web Map tab in Project Details. The web map is added to the folder created with the project in your content.
  7. Continue working on the project and click Save to update your progress.
    You must be the owner of the project to save and update your progress. If you are the owner of the project but do not own the web map being used in the project, you will not be able to save changes to the web map unless you have permissions to the project web map or if you create your own web map.
You can continue working with your project or make additional changes on the Project Details page.
Save markup to a project
You can save markup that you created as a feature collection that is stored with your Excalibur project. See Markup tools to learn how to use these tools. Once you finish marking up your imagery, click Save to update the project.
Add an observation layer to an Excalibur project
You can add an existing observation layer to an Excalibur project to collect observations from your imagery or video, or you can create an observation layer to fit your project needs through the project details. To add an observation layer, see Choose an existing observation layer and Create an observation layer.
Add layers to an Excalibur project
You can add layers to your project for additional context using the Add Layers menu. Once these layers are added, they are added to the project web map and can be saved to the web map if you have the appropriate permissions. Any added feature layers are automatically added as observation layers in your project. If you do not have permissions to the project web map, you can create your own or save a copy of the current web map by clicking Save in the canvas.
