Interact with layers in the canvas
Users can easily enhance their analysis by adding layers directly to the canvas or to their project. Layers can be added from their organization’s content or from shared web maps. Once added, these layers become part of the active workspace, allowing users to visualize imagery or video alongside feature layers such as points, lines, and polygons for richer context and analysis.
The Layers list provides a centralized panel for managing and interacting with all layers in the canvas. From this panel, users can toggle layer visibility, adjust transparency, reorder layers, and access layer-specific tools or properties. This makes it easy to control how information is displayed, focus on relevant data, and dynamically refine the visual experience. Additional layer interation options are also available through certain layer popups and tables.
Add layers
Use the Add Layers menu allows to add layers to your map that can be used to provide additional context to the imagery or video you are viewing. The supported layer types that can be added to the map include the following:
  • ArcGIS Feature Layers
  • ArcGIS Imagery Layers
  • ArcGIS Knowledge Graph Spatial Entities (only available in ArcGIS Enterprise)
  • ArcGIS Map Image Layers
  • ArcGIS Tile Layers
  • ArcGIS Tiled Imagery Layers
  • ArcGIS Oriented Imagery Layers
  • ArcGIS Video Layers
  • Web Map Services (WMS)
  • Web Map Tile Services (WMTS)
  • Web Coverage Service (WCS)
  • Markup Layers
  • Media Layers
To add layers to a map using the Add Layer menu, complete the following steps:
  1. Click Add Layers in the canvas.
    The Add Layers window appears.
  2. Filter and sort the layer cards in the list, search layer names, select layer types, or select layers shared with your organization.
  3. Click Add next to the layer cards to add to the map.
  4. Optionally, click View more information about this item to view information about the layer and access the item details.
Change the web map to add layers
Layers can also be added by changing the web map that is being used in the canvas to one that contains additional layers. A web map can be changed in the canvas by using the Web Map button and selecting a web map available to you. This button will not be available if you have already created a project. To change the web map in the canvas, complete the following steps:
  1. Click Web Map in the canvas.
    The Web Maps panel appears.
  2. Filter and sort the web maps in the list, search web map names, or select web maps shared with your organization.
  3. Select a web map and click Done at the bottom of the panel.
    A dialog box appears and notifies you that the canvas will refresh with the layers in the web map you just selected. Any previous layers and work will be removed, and the canvas will update with the new layers.
Add layers from the Job Status panel
After running a tool that creates a feature layer or raster layer, the results can be added to the canvas from the Job Status panel located at the top of the page. Certain tools involve a job being submitted to the server and you can view the progress of these jobs from the Job Status panel. As a job completes, you will see a notification indicating the update and the result layer will be automatically added to the map if you remain in the canvas while the tool runs. If you leave the canvas and come back, the layers will not be automatically added but you will be able to add these layers to the canvas from the Job Status panel. To do this complete the following steps:
  1. Open the canvas or a project that contains an imagery layer.
  2. Open a tool that results in a feature layer or raster layer output, such as Compute Change, NDVI, Raster Templates, Spectral, Deep Learning, or Imagery Clip.
  3. Run the tool. For more information on how to run these tools, see how to use comparison tools, use analysis tools, and use export tools.
    As the tool completes, you will see a notification appear in the Job Status menu at the top of the page. The result layer will automatically be added to the map if you remained in the canvas while the tool ran. If you leave the canvas or project while the tool is running and come back, the layer is not automatically added.
  4. To manually add the layer from the Job Status panel, click the Jobs panel at the top of the page and click Add on the layer you want to add to your map.
    The layer is added to the map. If a job failed or was canceled, you will see more information regarding this and you will not be able to add that result layer to the map. Additionally, you can view the item details of the layer by clicking Details .
Turn layers on and off
Use the Layers list setting to view and interact with layers in the canvas view. Layers could include the analysis layer you are connected to, mark up and measurements, and any additional layers that are added to the canvas.
To turn layers on and off using the Layers list setting, complete the following steps:
  1. Click Layers .
    The Layers list appears with all available layers currently in the canvas. All layers are turned on as visible by default.
  2. Hover over a layer and click the Hide button to turn the layer on or off in the Map Panel and Focus Panel.
Change layer transparency
Sometimes layers are overlaid on top of imagery or the basemap, and important objects are hidden. The Layers list transparency slider allows you to alter the transparency of the layers, so you can control the visibility of each layer.
To change layer transparency using the transparency slider, complete the following steps:
  1. Click Layers .
  2. Click Edit Transparency on a layer in the Layers list.
  3. Adjust the slider to your preference.
Zoom to a layer
Use Zoom to Layer Extent to focus the map on the extent of any given layer.
To zoom to a layer, do the following:
  1. Click Layers .
  2. Click Options .
    Not all layers will have the Options button.
  3. Click Zoom to Layer Extent on the desired layer.
View layer details
You can view the details of layers that have been added to your project.
To view the details of a layer, do the following:
  1. Click Layers .
  2. Click Options Options.
  3. Click View Details .
    The item details page for the selected layer will open in a new tab.
Change the layer styling
Users can enhance visualization and analysis by styling imagery layers and video layers directly within the canvas. Excalibur provides dynamic rendering options that allow users to adjust band combinations, apply different renderers, and fine-tune display settings. These tools help bring out specific features in the imagery and video whether you are highlighting vegetation health, identifying change over time, or improving visual clarity. The option to style a layer will only be available on ArcGIS Imagery Layers, ArcGIS Tiled Imagery Layers, ArcGIS Video Layers, and ArcGIS Feature Layers. Learn how to style layers.
Change the appearance of a layer
You can change the appearance of a layer to better support your analysis and visualization needs. Through the layers list options, users can modify resampling methods, compression, gamma, and dynamic range adjustment for visual customization on imagery layers. Users can also adjust settings like brightness, contrast, and saturation on video layers. The option to change the layer appearance will only be available on ArcGIS Imagery Layers, ArcGIS Tiled Imagery Layers, and ArcGIS Video Layers. Learn how to change layer appearance.
Change the image order of an imagery layer
Image services contain one or more images that are mosaicked on the fly and behave like a single image when you browse the service. The Image Order panel can help determine the image order and how to resolve overlapping areas. This specifically becomes useful when there are multiple images over the same area. Learn how to change the image order of an imagery layer.
Open Video Layers and Oriented Imagery Layers from the Layers List
Users can quickly access content such as oriented imagery layers and video layers directly from the layers list. Once these layers are added to the canvas, users can launch the oriented imagery viewer to explore images or open video layers to review video feeds in the video player.
To open a Video Layer or Oriented Imagery Layer from the Layers List, do the following:
  1. Click Layers .
  3. Click Open Video to open the video player or Open Viewer to open the oriented imagery viewer.
The Focus Panel populates with the video player or oriented imagery viewer. The Video Frame and Video Clip tools are updated to use the video layer in the player. The Oriented Imagery Metadata table populates with information related to the layer set in the viewer.
  1. Click to close the Focus Panel to remove the layer from the Focus Panel.
Reorder layers
Layers that are part of the project web map can be reordered to adjust the layer ordering and visibility in the map.
To reorder layers in the map, do the following:
  1. Click Layers .
  2. Hover over the Reposition button and drag the layers.
Trace an Observation
Users can trace an observation to review the source imagery or video associated with that observation. Tracing an observation allows you to examine the source data used during collection, view related metadata, and access the original source layer for additional context.
You can trace an observation from the observation popup or from the Feature Table.
  1. Select a feature on the map from a Feature Layer to open the popup. Alternatively, open the Feature Table in the canvas footer.
  2. Click Trace Observation .
The Trace Observation panel opens and the source imagery or video used during the collection of the observation is displayed with the observation.
In this panel, you can view the following:
  • The source layer—This could be a single image, an image service, or a video service depending on how the observation was collected. If the observation is collected on an image collection layer and the metadata for the raster ID or image ID populates the observation, then just the single image for that respective ID will appear. If that information doesn't exist, then the full service will be displayed.
  • The observation—You can use the zoom controls in the map to zoom and pan around where the observation was collected or what it was collected on in the imagery. You can hide the observation using the Hide Observation for a better view of the imagery.
  • Source layer and observation metadata—You can view the metadata for both the source layer (if the layer supports popups) and for the observation by using the View Metadata widget.
  • Video player controls—This will be availble if the source layer is a video layer. You can use the Open Video widget to open and close the video player. The video player will also have controls available for playing to video, changing the video telemetry on the map and how it is followed during video play, and additional settings.
In addition to these functions, you can also add the source layer to the current map or open the project the observation was originally collected in:
  • If the source layer is not already available in the current map, you can add it directly from the Trace Observation panel. Click Add Source to Map to add the layer. Once added, the source layer becomes available for use within the current map.
  • If the observation is created as part of an Excalibur project and the project is accessible, you can open the observation in the Trace Observation panel. Click Open Original Project to open the project in a new tab. Opening the original project gives you access to the broader collection workflow and supporting project content.
Open a Link Chart
A link chart contains point features that represent entities and line features that represent relationships in a knowledge graph. Link charts allow you to explore relationships between entities while maintaining geographic context.
To open a link chart from the Layers List, do the following:
  1. Click Layers .
  2. Click Options Options on a knowledge graph layer.
  3. Click Open Link Chart to open the link chart.
    The link chart opens in the Focus Panel. Alternatively, open a link chart by clicking the Knowledge entity in the map to open the pop-up, then click View Link Chart .
In this panel, you can do the following:
  • Select entities—Select individual entities or use the draw tool to select multiple entities in the link chart. The selected entities focus your analysis and explore relationships. Selections made in the link chart are synchronized with the map, automatically highlighting the corresponding spatial entities so you can analyze relationship connections and map context together.
  • Change the display of the link chart—Apply different chart layouts to organize and visualize connected entities based on relationship structure, geographic location, community grouping, or timeline.
  • Navigate around the link chart—Use pan and zoom controls to magnify areas of interest, explore adjacent areas, and examine entity relationships in greater detail.
  • View the legend—Opens the link chart legend to see the entity types, relationship types, and symbology used in the link chart.
