Sign in to an ArcGIS account
To access all of the ArcGIS for Excel features and functions, you must sign in to an ArcGIS Online or ArcGIS Enterprise account.
Contact Esri Customer Service if your subscription has expired and prevents you from signing in.
Learn more about ArcGIS for Microsoft 365
Guest users
You can use ArcGIS for Microsoft 365 as a guest user, but with limited functionality. Click Continue as guest when the Sign in to ArcGIS pane appears.
Organizational users
You can sign in using several options. If you don't have an ArcGIS account, you can sign up for a free ArcGIS trial to get started. Public ArcGIS accounts are not supported. See Accounts for more information. Check with your ArcGIS administrator about your organization's security settings.
Your sign in experience may be different based on your configuration. The ArcGIS sign-in pane may include any of the following options: ArcGIS account or organization login, SAML login, OpenID Connect login, or social media login. For more information about signing in to an ArcGIS account, see Sign in in the ArcGIS Online help.
Sign in with an ArcGIS Online account
To sign in with your ArcGIS Online account, complete the following steps:
  1. To access the sign in pane in ArcGIS for Excel, click Settings from the map tools. On the Login | Settings tab, click Sign In.
    The Sign in to ArcGIS pane appears with ArcGIS Online selected by default on the Choose ArcGIS connection drop-down menu.
  2. Click Sign in.
    The ArcGIS organization sign in pane appears.
  3. Type your ArcGIS username and password.
    The password is case sensitive.
    If you don't know your username or password, click Forgot username or Forgot password, or contact your administrator.
  4. Check Keep me signed in.
    You stay signed in for two weeks, unless you sign out.
  5. Click Sign In.
Sign in with an organization-specific login
For ArcGIS organizational accounts configured for organization-specific logins, sign in with your existing organization-specific login.
If you are an ArcGIS for Excel organization administrator, or a member of an organization in which the administrator has made specific URLs available, follow these steps to sign in after you click Reset Map.
To sign in with an organization-specific login, complete the following steps:
  1. In the Sign in to ArcGIS pane, expand the Choose ArcGIS connection section.
  2. Click Enter URL address.
    The ArcGIS Online or Enterprise text box appears.
  3. Type your ArcGIS organization's URL.
  4. Click Sign in.
  5. Type your ArcGIS username and password.
  6. Click Sign In.
The organization's URL will appear by default in the Sign in to ArcGIS pane, the next time you sign in.
Sign in with a configured ArcGIS account
Organization administrators can configure a list of ArcGIS connections for ArcGIS for Excel members of their enterprise organization. You can choose one when you sign in.
To sign in as an organization member with configured ArcGIS connections, complete the following steps:
  1. In the Sign in to ArcGIS pane, select a connection from the Choose ArcGIS connection drop-down menu.
  2. Click Sign in.
  5. Click Sign In.
    The map loads, and the ArcGIS connection information is visible in the Settings pane .
  6. For protected layers when you are adding data via ArcGIS into Microsoft Excel, you need to sign in with SAML or any options in the ArcGIS login pane.
    If you have multifactor authentication enabled for your account, enter the six-digit code provided by your authenticator app and click Verify. If your organization enforces multifactor authentication, you will first need to set up multifactor authentication.
    Tip:
    If recovery codes are enabled for your organization and you have printed or downloaded a list of recovery codes from your settings page, you can use the Lost access? Use recovery code option to sign in using one of the codes.
Sign in with a social media account
Your account administrator must set up social network sign-in credentials before you can use this workflow.
To sign in with an organizational account created with social network credentials, complete the following steps:
  1. In the Sign in to ArcGIS pane, after you have selected your organization, click Sign In.
  2. Click the appropriate social media button. For example, to sign in using your Google account, click the Google button .
    To join an ArcGIS organization using an Apple login, you must have multifactor authentication enabled on your Apple account.
  3. Provide your social network credentials and sign in.
When you sign out of ArcGIS, you are still signed in to your social network. To sign in to ArcGIS with different login information, you must first sign out of your social network.
Sign out
Complete the following to sign out of ArcGIS for Excel:
  1. From the map tools, click Settings .
    The Login | Settings pane appears.
  2. Click Sign out.
    You are signed out of your ArcGIS account, and the map reverts to the guest user experience. The current ArcGIS connection is visible, and you can continue as a guest user, or click Reset connection.
