Add a data layer to a map
Use your Microsoft Excel data to add a data layer to an ArcGIS for Excel map.
When you begin this workflow, ArcGIS for Excel reads the open Microsoft Excel workbook and attempts to find location-based information. The data must contain at least one location-based attribute, such as an address or longitude and latitude values. ArcGIS for Excel analyzes the data in the workbook and presents formatting options to represent it on a map.
Although it's possible to embed and work with a Microsoft Excel worksheet in a Microsoft Word document, this is not supported by ArcGIS for Excel and is not recommended.
Tip:
When you open a map-enabled worksheet that contains multiple maps or point layers created from Excel data, points on the map may not render immediately because the data is being loaded directly from Excel. Performance quality depends on your system's capabilities and the size of the dataset and maps.
Update records in Excel
When you add a new record or modify fields in an existing record, all maps created using the modified layer automatically update to reflect the changes.
Modify a record
To modify an existing record in the worksheet, complete the following steps:
  1. Click the cell that you want to modify and update the value.
  2. Optionally, modify other values.
  3. On the map, view the pop-up for the modified record.
    The values are automatically updated.
Add a record
To add a record to the worksheet, complete the following steps:
On the Location types drop-down menu, when adding data from Excel, the Coordinates and EsriJSON Geometry options are available. To access the GeoJSON, Address, and Geographic data options, you must be signed in to an ArcGIS account.
  1. Insert a new record in the worksheet by doing one of the following:
    • If you created the layer from data formatted as an Excel table, right-click in the table, and click Insert > Table rows above or Table rows below. To add a new row to the bottom of the table, move the pointer to the last cell of the table, and press Tab. Drag the resize handle in the lower right corner of the table to include new rows in the table if necessary.
    • If you created the layer from a range of cells in a worksheet, right-click a cell within the range, and click Insert to open the Insert window, click Entire row, and click OK. A new row is inserted within the range.
    The map layer updates to add the new feature.
    As you add information to the worksheet, the map refreshes to load the new data.
  2. In the worksheet, populate the cells with the appropriate values.
    Include the same type of location information used in the other records, such as latitude and longitude coordinates.
    The map refreshes with the new feature added to the layer.
Add a JSON file
When adding data from Excel, you can add a GeoJSON or JSON file from your local machine. The Location type drop-down menu automatically includes EsriJSON Geometry or GeoJSON geometry depending on the file type you added. The Geometry column drop-down menu displays the geometry type. It can be a single geometry type or multiple geometry types such as points, lines, and polygons, depending on the data in the Excel worksheet.
Learn more about specifying a location type
Add a custom spatial reference
After selecting the Coordinates location type, you can add a custom spatial reference when your longitude (X) and latitude (Y) coordinate values are not available in the spatial reference drop-down menu. A mis-match between your custom spatial reference and the spatial reference of your coordinate values may result in features being drawn in the wrong location on the map.
To add a custom spatial reference, complete the following steps:
  1. Add data in the Excel worksheet with x, y coordinates.
  2. In the Add layer pane, click the Spatial reference drop-down menu.
  3. Click +Add custom.
    The Custom spatial reference pane appears.
  4. Specify the spatial reference in well known text (WKT).
    A description field is available in read-only mode for custom spatial reference. This description also appears as a tooltip next to the custom spatial reference name in the dropdown list. Optionally, you can either provide a WKID, or upload a projection file, for example a .prj file from your local machine.
  5. Provide a valid Name value.
  6. Optionally, check the Share with your organization check box.
    When checked, the spatial reference is available to members of your organization. Until then, it remains private to your account.
  7. Click Add.
    Features are drawn in the correct location on the map when the appropriate custom spatial reference is applied.
Delete a feature
If you created the layer from data formatted as an Excel table, right-click in the row or column to be removed, and click Delete. The feature is removed from the map.
The map updates to remove any points from the deleted data. See the Microsoft Insert or delete rows and columns article for more information.
