ArcGIS for Excel functions
You must sign in to an ArcGIS account to use the ArcGIS for Excel functions. If you are not signed in, a sign in error appears when you hover over the green triangle in the upper left corner of a selected cell. In Microsoft Windows Desktop or macOS, you will also see a yellow warning icon.
Microsoft Excel includes a set of functions or formulas that you can use to calculate information, from simple arithmetic sums to complex population of cells.
ArcGIS for Excel includes similar functions that you can use for geocoding, data enrichment, and performing route operations. Each function starts with an equal sign (=) in a cell followed by the function name and its input parameters, if any, in parentheses.
Tip:
As you write a function in a cell, you can use cell references by selecting a specific cell or cells in a column or row. This ensures data integrity. See the Microsoft Create or change a cell reference article for more information.
The geocoding, GeoEnrichment Service , and routing functions consume credits. Geometry functions do not consume credits. The SUGGESTADDRESS function consumes credits when you request more than 15 suggestions. Helper Functions do not consume credits. Your ArcGIS functions are cached to prevent additional credit consumption if and when the functions are refreshed. This cache increases the size of your Microsoft Excel file. To clear the ArcGIS for Excel functions cache, click the Clear cache button in the Settings pane.
You can copy the examples in this topic into an Excel worksheet to visualize how functions work. You can also use the ArcGIS for Excel functions in the ArcGIS Function Builder tool.
Some ArcGIS functions may fail with an error that the service is not available when running them within a cell in Excel. Contact your organization administrator to enable the service or get more information.
See the ArcGIS Enterprise and ArcGIS Online documentation for more information about services.
The sections below describe the ArcGIS for Excel functions and include the syntax, an example, and descriptions of the parameters.
In the function examples below, the actual result of the functions excludes the header. Run the ADDHEADERS function to request the headers.
GETCOORDINATES
This is a Geocoding function that geocodes a location. This returns possible locations including longitude, latitude, and, optionally, the address matched and the match score.
Syntax
ARCGIS.GETCOORDINATES(address, [spatial_reference], [match_details], [geocode_service}, [country])
Parameters
Parameter |
Description |
Parameter required |
address |
The location to be geocoded. This can be a street address, place-name, postal code, or point of interest (POI). |
Yes |
spatial reference |
The spatial reference for the point location. This can be either a WKID (number) or WKT (text). See the list of valid WKID values. The default is 4326 (WGS84). |
No |
match_details |
If set to |
No |
geocode_service |
Choose a geocoding service from the drop-down menu. The service lists all the locators available to members of your organization. |
No |
country |
When set, the country-specific address is geocoded. Run |
No |
In all the function examples, the actual result of the functions excludes the header. Run the ADDHEADERS function to request the headers.
Function example 1
=ARCGIS.GETCOORDINATES("380 New York Street, Redlands, CA, USA")
Result
Longitude (X) |
Latitude (Y) |
-117.19479 |
34.057265 |
Function example 2
=ARCGIS.GETCOORDINATES("380 New York Street, Redlands, CA, USA", 4326 , TRUE)
Result
Longitude (X) |
Latitude (Y) |
Address |
Match score |
Geolocator |
Address type |
-117.1948 |
34.057265 |
380 New York St, Redlands, CA, 92373, USA |
100 |
World |
PointAddress |
GETADDRESS
This is a Geocoding function that determines the address at a particular longitude-latitude location through reverse geocoding.
Syntax
ARCGIS.GETADDRESS(longitude(X), latitude(Y), [spatial_reference], [all_data], [geocode_service])
Parameters
Parameter |
Description |
longitude(X) |
The longitude of the point from which to search for the closest address. |
Yes |
latitude(Y) |
The latitude of the point from which to search for the closest address. |
Yes |
spatial_reference |
No |
all_data |
If set to |
No |
geocode_service |
No |
Function example 1
=ARCGIS.GETADDRESS(-70.251, 43.65808)
Result
Address |
Standard Baking, 75 Commercial St, Portland, ME, 04101, USA |
Function example 2
=ARCGIS.GETADDRESS(-70.251, 43.65808, 4326, TRUE)
Result
Address matched |
Full address name |
Short address name |
Address type |
Type |
Place name |
Street number |
Street name |
Block |
Sector |
Neighborhood |
District |
City |
Metropolitan area |
Sub-region |
Region |
Region abbreviation |
Territory |
Postal code |
Postal code extension |
Country |
Country code |
Standard Baking |
Standard Baking |
POI |
Bakery |
Standard Baking |
75 |
75 Commercial St. |
Portland |
Cumberland county |
Maine |
ME |
04101 |
United States |
USA |
ENRICHBYPOINT
This is a GeoEnrichment function that returns enriched demographic information about the people, places, and businesses in a specific area or within a certain distance or drive time from a location. The default distance is within a one-mile radius of the point.
Syntax
ARCGIS.ENRICHBYPOINT(longitude(X), latitude(Y), [spatial_reference], [distance], [unit],[travel_mode],[data_collections],[variables],[include_derivative_variables], [include_studyarea_details], [country])
Parameters
Parameter |
Description |
longitude(X) |
The longitude of the point of interest. |
Yes |
latitude(Y) |
The latitude of the point of interest. |
Yes |
spatial_reference |
No |
distance |
The radius or distance from the point, which is used to compute the ring buffer area for the demographic data. For example, use 3 for a three-mile radius. The default is 1. |
No |
unit |
The unit of measurement for the |
No |
travel_mode |
If this is set, it will compute an area using travel distance from the point of interest. This can be walking, driving, or trucking. If left blank, a ring buffer area will be computed. |
No |
data_collections |
Preassembled lists of attributes that will be used to enrich the input features. Run the |
No |
Hierarchy |
Specify the data hierarchy. Data hierarchy is a grouped collection of related datasets for a country in the GeoEnrichment data model. If not set, the default hierarchy is used. |
Yes |
analysis_variables |
Variables to be returned from the data collections—for example, Run the |
No |
include_derivative_variables |
Derivative variables to include in the output. This can be percent, index, average, or all. If left blank, no derivative variable will be included. |
No |
include_studyarea_details |
If set to |
No |
country |
Limits the results to a particular country. |
No |
Function example 1
=ARCGIS.ENRICHBYPOINT(-90.491, 38.777)
Result
Total population |
Total households |
Average household size |
Male population |
Female population |
11464 |
4860 |
1.98 |
5745 |
5719 |
Function example 2
=ARCGIS.ENRICHBYPOINT(-90.491, 38.777, 4326, 5, "miles", "driving", "health", "X8001_X, X8021_X", "index", TRUE)
Result
Country code |
Area type |
Buffer units alias |
Buffer radii |
2022 Healthcare |
2022 Healthcare: index |
2022 Dental services |
2022 Dental services: index |
US |
NetworkServiceArea |
Drive Distance Miles |
5 |
240971277 |
99 |
15463985 |
99 |
ENRICHBYGEOGRAPHY
This is a GeoEnrichment function that returns information about the people, places, and businesses in specific-named administrative boundaries—or levels of geography—of a map, such as districts, states and postal codes.
Syntax
ARCGIS.ENRICHBYGEOGRAPHY(area_id, geography_level_id, [data_collections], [variables], [include_derivative_variables], [include_geography_details])
Parameters
Parameter |
Description |
area_id |
The Federal Information Processing Series (FIPS) ID of the area where demographic information will be obtained. Run the |
Yes |
Hierarchy |
Yes |
geography_level_id |
The ID of the geography level to which the area ID belongs. Run the |
Yes |
data_collections |
Preassembled lists of attributes that are used to enrich the input features. Run the |
No |
No |
Derivative variables to include in the output. This can be percent, index average, or all. If left blank, no derivative variable will be included. |
No |
include_geography_details |
If set to |
No |
Function example 1
=ARCGIS.ENRICHBYGEOGRAPHY("06","US.States")
Result
Total population |
Total households |
Male population |
Female population |
39770476 |
13570050 |
2.86 |
19767455 |
20003021 |
Function example 2
=ARCGIS.ENRICHBYGEOGRAPHY("08019","ES.Municipalities", "IncomeTotalsAIS")
Result
2020 Total household income per year |
2020 Average household income per year |
2020 Average household income per month |
2020 Average annual income per capita |
2020 Average monthly income per capita |
1.99E + 10 |
29898.9 |
2491.57 |
11938.06 |
994.84 |
Function example 3
=ARCGIS.ENRICHBYGEOGRAPHY("08019","ES.Municipalities", , "KeyGlobalFacts.AVGHHSZ, IncomeTotalsAIS.NINCHA")
Result
2.5 |
29898.9 |
Function example 4
=ARCGIS.ENRICHBYGEOGRAPHY("06","US.States","health", "X8001_X, X8021_X", "index", TRUE)
Result
Standard geography level |
Standard geography name |
Standard geography ID |
Country code |
2022 Health care |
2022 Health care: index |
U.S. States |
California |
06 |
US |
1.08894E+11 |
113 |
7.37E+09 |
119 |
ENRICHBYADDRESS
This is a GeoEnrichment function that returns enriched demographic information about the people, places, and businesses in a specific area or within a certain distance or drive time from an address. The default distance is within a one-mile radius of the point.
Syntax
ARCGIS.ENRICHBYADDRESS(address, [distance], [unit],[travel_mode],[data_collections],[variables],[include_derivative_variables], [include_studyarea_details]), [country])
Parameters
Parameter |
Description |
address |
The location to be geocoded. This can be a street address, place-name, postal code, or POI. |
Yes |
distance |
No |
unit |
No |
travel_mode |
No |
No |
No |
If set to |
No |
country |
No |
Hierarchy |
Yes |
Function example 1
=ARCGIS.ENRICHBYADDRESS("380 New York Street, Redlands, CA, USA")
Result
Total population |
Total households |
Male population |
Female population |
11464 |
4860 |
1.98 |
5745 |
5719 |
Function example 2
=ARCGIS.ENRICHBYADDRESS("380 New York Street, Redlands, CA, USA", 5, "miles", "driving", "health", "X8001_X, X8021_X", "index", TRUE)
Result
Country code |
Area type |
Buffer radii |
2022 Healthcare |
US |
5 |
240971277 |
99 |
15463985 |
99 |
ENRICHBYPOLYGON
This is a GeoEnrichment function that returns information about people, places, and businesses in a specific area.
Syntax
ARCGIS.ENRICHBYPOLYGON(esrijson_polygon, analysis_variables, include_derivative_variables, [country])
Parameters
Parameter |
Description |
esrijson_polygon |
A polygon as an Esri JSON geometry representing the area for which demographic information will be obtained. |
Yes |
Yes |
The output must contain derivative variables. The parameter value can be percentage, index, average, or all. If left blank, no derivative variable is included. |
No |
country |
No |
Hierarchy |
Yes |
Function example
=ARCGIS.ENRICHBYPOLYGON("{""rings"":[[[-87.756423,38.646252],[-84.539489,35.707507],[-90.151958,35.306175],[-87.756423,38.646252]]],""spatialReference"":{""wkid"":4326}}", "TOTPOP_CY", , "US")
Result
2025 Total Population |
4565359 |
FINDROUTE
This is a Routing function that finds the total travel distance (the default measurement unit is miles) and time (in minutes) between two locations using the best route found.
Syntax
ARCGIS.FINDROUTE(from_longitude(X), from_latitude(Y), to_longitude(X), to_latitude(Y), [spatial_reference], [travel_mode], [unit], [include_directions])
Parameters
Parameter |
Description |
from_longitude(X) |
The longitude coordinates of the starting location of the route. |
Yes |
from_latitude(Y) |
The latitude coordinates of the starting location of the route. |
Yes |
to_longitude(X) |
The longitude coordinates of the destination location of the route. |
Yes |
to_latitude(Y) |
The latitude coordinates of the destination location of the route. |
Yes |
spatial_reference |
No |
travel_mode |
The travel mode for the route. Instead of a ring buffer area, compute an area using a travel mode, for example, walking, driving, or trucking. For example, use Driving Distance or Walking Time. Run the |
No |
unit |
The measurement unit for the travel distance. This can be miles, kilometers, meters, feet, points, yards, or nautical miles. The default is miles. |
No |
include_directions |
If set to |
No |
Function example 1
=ARCGIS.FINDROUTE(-77.24488778, 38.92894278, -80.78300851, 35.1001845)
Result
Distance traveled (miles) |
Time traveled (minutes) |
Route shape |
391.3764 |
401.6001295 |
{"spatialReference":{"latestWkid":4326,"wkid":4326},"paths":[[[-77.244918653,38.92906864],[-77.2443203,38.9292242], ... |
Function example 2
=ARCGIS.FINDROUTE(-77.24488778, 38.92894278, -80.78300851, 35.1001845, 4326, "Driving Distance", "miles", TRUE)
Result
Description |
Route shape |
Total Distance/Time Traveled |
382.7767 |
408.1581 |
Start at Location 1 |
0 |
0 |
{"spatialReference":{"wkid":4326},"paths":[[[-77.24491862136172,38.92906862347136],[-77.24491862136172,38.92906862347136]]]} |
Go East |
0.03108 |
0.300162 |
{"spatialReference":{"wkid":4326},"paths":[[[-77.24491862136172,38.92906862347136],[-77.24432026092327,38.92922419358836],[-77.2431644738714,38.92953551367221],[-77.24291516601454,38.92957141170151],[-77.24263625487299,38.92926048728733]]]} |
Turn left, then turn right on Leesburg Pike |
0.422316089 |
1.215881348 |
{"spatialReference":{"wkid":4326},"paths":[[[-77.24263627476374,38.929260492606396],[-77.24232884852634,38.92937681604757], ... |
Finish at Location 2, on the left |
0 |
0 |
{"spatialReference":{"wkid":4326},"paths":[[[-80.78293244317324,35.10024066538108],[-80.78293244317324,35.10024066538108]]]} |
FINDROUTEBYADDRESS
This is a Routing function that finds the total travel distance (the default measurement unit is miles) and time (in minutes) between two addresses using the best route found.
Syntax
ARCGIS.FINDROUTEBYADDRESS(from_address, to_address, [travel_mode], [unit], [include_directions])
Parameters
Parameter |
Description |
from_address |
The address of the starting location of the route. |
Yes |
to_address |
The address of the destination location of the route. |
Yes |
travel_mode |
No |
unit |
The measurement unit for the travel distance. This can be miles, kilometers, meters, feet, yards, or nautical miles. The default is miles. |
No |
If set to |
No |
Function example 1
=ARCGIS.FINDROUTEBYADDRESS("380 New York Street Redlands CA", "Downtown Riverside")
Result
Route shape |
14.32662 |
20.73435 |
{"spatialReference":{"latestWkid":4326,"wkid":4326},"paths":[[[-117.194789317,34.057516991],[-117.1940741,34.057515], ... |
Function example 2
=ARCGIS.FINDROUTEBYADDRESS("380 New York Street Redlands CA", "Downtown Riverside", "Driving Distance", "kilometers", TRUE)
Result
Description |
Distance traveled (kilometers) |
Route shape |
22.9899 |
22.40177 |
0 |
0 |
{"spatialReference":{"wkid":4326},"paths":[[[-117.19478927505831,34.057516969635486],[-117.19478927505831,34.057516969635486]]]} |
Go East |
0.0660270315239986 |
0.396162189143992 |
{"spatialReference":{"wkid":4326},"paths":[[[-117.19478927505831,34.057516969635486],[-117.19407404027919,34.057515005004625]]]} |
Turn left |
0.0665435791015625 |
0.3992919921875 |
{"spatialReference":{"wkid":4326},"paths":[[[-117.19407405467044,34.057514980900905],[-117.19406685106797,34.05811489909636]]]} |
0 |
0 |
{"spatialReference":{"wkid":4326},"paths":[[[-117.37829693421398,33.97863201286705],[-117.37829693421398,33.97863201286705]]]} |
VERTICESTOESRIJSON
This is a Geometry function that creates an Esri JSON polyline, or polygon geometry from a list of its vertices' coordinates.
Syntax
ARCGIS.VERTICESTOESRIJSON (xy_vertices, [spatial_reference], [geometry_type], [y_then_x])
Parameters
Parameter |
Description |
xy_vertices |
A cell range containing the vertices' coordinates. The vertices can be specified in either row or column format. |
Yes |
spatial_reference |
No |
geometry_type |
The geometry type. The parameters value can be polyline or polygon. The default is polygon. |
No |
y_then_x |
If set to |
No |
Function example
=ARCGIS.VERTICESTOESRIJSON(A2:B4) where cells A1:B4 contain the following table:
X |
Y |
-87.756423 |
38.646252 |
-84.539489 |
35.707507 |
-90.151958 |
35.306175 |
Result
{"rings":[[[-87.756423,38.646252],[-84.539489,35.707507],[-90.151958,35.306175],[-87.756423,38.646252]]],"spatialReference":{"wkid":4326}}
CONVERTTOESRIJSON
This is a Geometry function that converts a geometry from a non-Esri format to an Esri JSON geometry.
Syntax
ARCGIS.CONVERTTOESRIJSON (geometry_to_convert)
Parameters
Parameter |
Description |
geometry_to_convert |
The geometry to be converted into Esri JSON. This can be a WKT or GeoJSON geometry. |
Yes |
Function example 1
GeoJSON to EsriJSON conversion
=ARCGIS.CONVERTTOESRIJSON("{""type"":""Polygon"",""coordinates"":[[[-77.834931,37.636121],[-77.918397,37.691673],[-77.953895,37.667683],[-77.943633,37.639076],[-77.956951,37.624938],[-78.075329,37.657254],[-78.132048,37.454686],[-78.098749,37.440575],[-78.092291,37.455818],[-78.065882,37.452059],[-78.049325,37.472261],[-78.017204,37.47149],[-78.015448,37.491179],[-77.999575,37.498052],[-77.899007,37.475272],[-77.894465,37.449578],[-77.866126,37.456521],[-77.846726,37.415121],[-77.80857,37.426561],[-77.79784,37.458961],[-77.656244,37.56085],[-77.76327,37.612059],[-77.819611,37.608498],[-77.834931,37.636121]]]}")
Result
{"rings":[[[-77.834931,37.636121],[-77.819611,37.608498],[-77.76327,37.612059],[-77.656244,37.56085],[-77.79784,37.458961],[-77.80857,37.426561],[-77.846726,37.415121],[-77.866126,37.456521],[-77.894465,37.449578],[-77.899007,37.475272],[-77.999575,37.498052],[-78.015448,37.491179],[-78.017204,37.47149],[-78.049325,37.472261],[-78.065882,37.452059],[-78.092291,37.455818],[-78.098749,37.440575],[-78.132048,37.454686],[-78.075329,37.657254],[-77.956951,37.624938],[-77.943633,37.639076],[-77.953895,37.667683],[-77.918397,37.691673],[-77.834931,37.636121]]]}
Function example 2
WKT to EsriJSON conversion
=ARCGIS.CONVERTTOESRIJSON(POLYGON((30 10, 40 40, 20 40, 10 20, 30 10)))
Result
{"rings":[[[30,10],[10,20],[20,40],[40,40],[30,10]]]}
GETPOLYGONAREA
This is a Geometry function that calculates the area of a polygon.
Syntax
ARCGIS.GETPOLYGONAREA(esrijson_polygon, [unit], [measurement_type])
Parameters
Parameter |
Description |
esrijson_geometry |
An Esri JSON geometry. |
Yes |
unit |
No |
measurement_type |
The measurement type used to determine the distance. The parameter values can be the following:
The default is Geodesic. |
No |
Function example
=ARCGIS.GETPOLYGONAREA("{""rings"":[[[-87.756423,38.646252],[-84.539489,35.707507],[-90.151958,35.306175],[-87.756423,38.646252]]],""spatialReference"":{""wkid"":4326}}")
Result
34208.983
GETGEOMETRYLENGTH
This is a Geometry function that calculates the length of the geometry.
Syntax
=ARCGIS.GETGEOMETRYLENGTH(esrijson_geometry, [unit], [measurement_type])
Parameters
Parameter |
Description |
esrijson_geometry |
Yes |
unit |
No |
measurement_type |
No |
Function example
=ARCGIS.GETGEOMETRYLENGTH("{""rings"":[[[-87.756423,38.646252],[-84.539489,35.707507],[-90.151958,35.306175],[-87.756423,38.646252]]],""spatialReference"":{""wkid"":4326}}")
Result
852.6254813
GETGEOMETRYDISTANCE
This is a Geometry function that calculates the distance between two geometries.
Syntax
=ARCGIS.GETGEOMETRYDISTANCE(esrijson_geometry1, esrijson_geometry2, [unit], [measurement_type])
Parameters
Parameter |
Description |
esrijson_geometry1 |
The first Esri JSON geometry. |
Yes |
esrijson_geometry2 |
The second Esri JSON geometry. |
Yes |
unit |
No |
measurement_type |
No |
Function example 1
Points distance.
=ARCGIS.GETGEOMETRYDISTANCE(A2:B2, A3:B3) where A1:B3 are cells containing the following:
X |
Y |
-87.756423 |
38.646252 |
-84.539489 |
35.707507 |
Result
269.3677755
Function example 2
Polygons distance.
=ARCGIS.GETGEOMETRYDISTANCE("{""rings"":[[[-77.834931,37.636121],[-77.819611,37.608498],[-77.76327,37.612059],[-77.656244,37.56085],[-77.79784,37.458961],[-77.80857,37.426561],[-77.846726,37.415121],[-77.866126,37.456521],[-77.894465,37.449578],[-77.899007,37.475272],[-77.999575,37.498052],[-78.015448,37.491179],[-78.017204,37.47149],[-78.049325,37.472261],[-78.065882,37.452059],[-78.092291,37.455818],[-78.098749,37.440575],[-78.132048,37.454686],[-78.075329,37.657254],[-77.956951,37.624938],[-77.943633,37.639076],[-77.953895,37.667683],[-77.918397,37.691673],[-77.834931,37.636121]]]}", "{""rings"":[[[-84.791008,36.058531],[-84.80546,36.090501],[-84.832377,36.08401],[-84.870888,36.136925],[-84.905735,36.153537],[-84.914155,36.20829],[-84.883891,36.239039],[-84.875631,36.285323],[-84.795822,36.297602],[-84.774063,36.334639],[-84.74001,36.336551],[-84.745473,36.35147],[-84.727126,36.352449],[-84.722993,36.376626],[-84.700753,36.370795],[-84.611042,36.270377],[-84.573041,36.266577],[-84.573741,36.229977],[-84.471037,36.203778],[-84.441034,36.163478],[-84.448934,36.139377],[-84.420432,36.108377],[-84.37903,36.095377],[-84.341812,36.048977],[-84.446054,35.985984],[-84.541719,35.970425],[-84.554969,35.950361],[-84.60346,35.954125],[-84.620047,35.93232],[-84.680633,35.908454],[-84.720727,35.994914],[-84.791008,36.058531]]]}")
Result
357.8645062
GETCENTROID
This is a Geometry function that calculates the centroid for a geometry.
Syntax
=ARCGIS.GETCENTROID(esrijson_geometry)
Parameters
Parameter |
Description |
esrijson_geometry |
This is an Esri JSON geometry. |
Yes |
Function example
=ARCGIS.GETCENTROID("{""rings"":[[[-84.791008,36.058531],[-84.80546,36.090501],[-84.832377,36.08401],[-84.870888,36.136925],[-84.905735,36.153537],[-84.914155,36.20829],[-84.883891,36.239039],[-84.875631,36.285323],[-84.795822,36.297602],[-84.774063,36.334639],[-84.74001,36.336551],[-84.745473,36.35147],[-84.727126,36.352449],[-84.722993,36.376626],[-84.700753,36.370795],[-84.611042,36.270377],[-84.573041,36.266577],[-84.573741,36.229977],[-84.471037,36.203778],[-84.441034,36.163478],[-84.448934,36.139377],[-84.420432,36.108377],[-84.37903,36.095377],[-84.341812,36.048977],[-84.446054,35.985984],[-84.541719,35.970425],[-84.554969,35.950361],[-84.60346,35.954125],[-84.620047,35.93232],[-84.680633,35.908454],[-84.720727,35.994914],[-84.791008,36.058531]]]}")
Result
-84.649205 |
36.1338336 |
RELATEGEOMETRIES
This is a Geometry function that compares a geometry to another geometry by performing a spatial relationship operation.
Syntax
=ARCGIS.RELATEGEOMETRIES(esrijson_geometry_or_XY1, topological_operation, esrijson_geometry_or_XY2)
Parameters
Name |
Description |
esrijson_geometry_or_XY1 |
The Esri JSON geometry or coordinates of a point to compare. |
Yes |
topological_operation |
The topological spatial relationship operator to be used to compare the geometries. This parameter's value can be the following:
Yes |
esrijson_geometry_or_XY2 |
The Esri JSON geometry or coordinates of a point to be compared with. |
Yes |
Function example 1
Check if geometry1 touches geometry2.
=ARCGIS.RELATEGEOMETRIES("{""rings"":[[[-87.756423,38.646252],[-84.539489,35.707507],[-90.151958,35.306175],[-87.756423,38.646252]]],""spatialReference"":{""wkid"":4326}}", "touches", "{""rings"":[[[-87.358341,37.397929],[-86.651954,36.229542],[-88.135108,36.219225],[-87.358341,37.397929]]],""spatialReference"":{""wkid"":4326}}")
Result
FALSE
Function example 2
Check if geometry1 contains geometry2.
=ARCGIS.RELATEGEOMETRIES("{""rings"":[[[-87.756423,38.646252],[-84.539489,35.707507],[-90.151958,35.306175],[-87.756423,38.646252]]],""spatialReference"":{""wkid"":4326}}", "contains", "{""rings"":[[[-87.358341,37.397929],[-86.651954,36.229542],[-88.135108,36.219225],[-87.358341,37.397929]]],""spatialReference"":{""wkid"":4326}}")
Result
TRUE
GENERALIZEGEOMETRY
This is a Geometry function that generalizes a geometry using the Douglas-Peuker algorithm.
Syntax
=ArcGIS.GENERALIZEGEOMETRY(esrijson_geometry, max_deviation, [max_deviation_unit], [remove_degenerate_parts])
Parameters
Parameter |
Description |
esrijson_geometry |
Yes |
max_deviation |
The maximum allowed deviation from the generalized geometry, to the original geometry. If |
Yes |
max_deviation_unit |
The length unit of the maximum allowed deviation. An error occurs if this value is set for geographic coordinate systems. When the value is not set, the spatial reference unit of geometry is used. |
No |
remove_degenerate_parts |
When set to |
No |
Function example
=ARCGIS.GENERALIZEGEOMETRY("{""spatialReference"":{""latestWkid"":3857,""wkid"":102100},""rings"":[[[11558327.921,163395.83350000158],[11561926.114400003,159769.09980000183],[11558107.089500003,156139.4177000001],[11559326.3132,155633.68090000004],[11562466.999200001,158634.2138000019],[11565455.501200002,157344.55380000174],[11564601.7819,156099.18340000138],[11567396.9886,158289.79590000212],[11567945.119000003,154867.3452000022],[11569573.294100001,155823.4766000025],[11572956.2694,153793.5818000026],[11577256.117700003,154825.46499999985],[11578026.672200002,152459.13220000267],[11581836.381100003,150852.98320000246],[11577793.6585,147202.1187000014],[11580832.056900002,147488.96680000052],[11580839.4219,145777.50620000064],[11580424.286700003,146984.0957000032],[11580200.297000002,145941.7693000026],[11574233.842800003,146546.63010000065],[11563429.23,142584.2501000017],[11562559.7322,145193.3276000023],[11561725.095600002,140790.8153000027],[11554406.980100002,141436.5080000013],[11553351.114,139671.16690000147],[11553430.842,141699.03290000185],[11549380.197100002,142566.92810000107],[11551848.383200001,142923.52440000325],[11549845.5872,145537.98090000078],[11550013.138,144434.1361999996],[11547127.8792,144922.27770000324],[11547428.1864,147220.48970000073],[11546806.724200003,144798.79200000316],[11542000.401,144650.96240000054],[11541776.9952,145754.80800000206],[11540094.955900002,143504.4065000005],[11538214.830700003,144893.11510000005],[11539076.525400002,145876.35610000044],[11536865.5447,146553.12100000307],[11538276.8827,142847.6656000018],[11537505.651700001,140301.92440000176],[11534533.445600003,140397.49380000308],[11535833.193500001,138581.6801000014],[11533864.4888,136001.3328000009],[11537645.693300001,134948.89190000296],[11533530.315700002,135771.96970000118],[11533453.5205,140808.44260000065],[11536494.785300002,150285.7314000018],[11538871.074300002,148788.0963000022],[11537285.3909,150933.0122999996],[11541310.238400001,153472.33360000327],[11539029.1107,153859.1163999997],[11540983.165000003,158658.37330000103],[11547204.1039,161399.9017000012],[11547787.798700001,158158.25989999995],[11544261.5172,157094.58460000157],[11546650.638700001,156923.10670000315],[11546073.326700002,154927.14570000023],[11547068.030100003,156261.010300003],[11547710.4727,154945.33140000328],[11548621.838200003,160284.53510000184],[11550692.7907,160161.05570000038],[11555689.1448,163732.1476000026],[11558327.921,163395.83350000158]]]}", 5000)
Result
{"spatialReference":{"latestWkid":3857,"wkid":102100},"rings":[[[11558327.921,163395.83350000158],[11558107.089500003,156139.4177000001],[11577256.117700003,154825.46499999985],[11580839.4219,145777.50620000064],[11553351.114,139671.16690000147],[11536865.5447,146553.12100000307],[11533530.315700002,135771.96970000118],[11540983.165000003,158658.37330000103],[11547204.1039,161399.9017000012],[11547710.4727,154945.33140000328],[11558327.921,163395.83350000158]]]}
COORDINATETONOTATION
This is a Geometry function that converts x, y coordinates into well-known strings based on the conversion type and spatial reference supplied.
Syntax
=ArcGIS.COORDINATETONOTATION(longitude(X), latitude(Y), conversion_type, [spatial reference])
Parameters
Parameter |
Description |
longitude (X) |
The longitude of the point. |
Yes |
latitude (Y) |
The latitude of the point. |
Yes |
conversion_type |
The conversion type of the input coordinates. |
Yes |
spatial_reference |
The spatial reference for the point location. This can be either a WKID (number) or WKT (text). The default is 4326 (WGS84). |
No |
Function example
=ARCGIS.COORDINATETONOTATION(-87.358341, 37.397929, "dms")
Result
37 23 52.54N 087 21 30.03W
COORDINATEFROMNOTATION
This is a Geometry function that converts well-known strings into x, y coordinates based on the conversion type and spatial reference supplied.
Syntax
=ArcGIS.COORDINATEFROMNOTATION(coordinate_string, conversion_type, [spatial_reference])
Parameters
Parameter |
Description |
coordinate_string |
The string to be converted into coordinates. |
Yes |
conversion_type |
Yes |
spatial_reference |
Yes |
Function example
=ARCGIS.COORDINATEFROMNOTATION("18S UJ 23371 06519", "usng")
Result
-77.0365429 |
38.8898005 |
PROJECTPOINT
This is a Geometry function that converts x, y from one spatial reference to another.
Syntax
=ArcGIS.PROJECTPOINT(longitude(X), latitude(Y), in_spatial_reference, out_spatial_reference)
Parameters
Parameter |
Description |
longitude (X) |
The longitude of the point to be projected. |
Yes |
latitude (Y) |
The latitude of the point to be projected. |
Yes |
in_spatial_reference |
The spatial reference for the input geometry. This can be either a WKID (number) or WKT (text). |
Yes |
out_spatial_reference |
The spatial reference for the output geometry. This can be either a WKID (number) or WKT (text). |
Yes |
Function example
=ARCGIS.PROJECTPOINT(-87.358341, 37.397929, 4326, 4269)
Result
-87.358336 |
37.3979219 |
PROJECTGEOMETRY
This is a Geometry function that converts a geometry from one spatial reference to another.
Syntax
=ArcGIS.PROJECTGEOMETRY(esrijson_geometry, in_spatial_reference, out_spatial_reference)
Parameters
Parameter |
Description |
esrijson_geometry |
Yes |
Yes |
Yes |
Function example
=ARCGIS.PROJECTGEOMETRY("{""rings"":[[[-77.834931,37.636121],[-77.819611,37.608498],[-77.76327,37.612059],[-77.656244,37.56085],[-77.79784,37.458961],[-77.80857,37.426561],[-77.846726,37.415121],[-77.866126,37.456521],[-77.894465,37.449578],[-77.899007,37.475272],[-77.999575,37.498052],[-78.015448,37.491179],[-78.017204,37.47149],[-78.049325,37.472261],[-78.065882,37.452059],[-78.092291,37.455818],[-78.098749,37.440575],[-78.132048,37.454686],[-78.075329,37.657254],[-77.956951,37.624938],[-77.943633,37.639076],[-77.953895,37.667683],[-77.918397,37.691673],[-77.834931,37.636121]]]}", 4326, 4269)
Result
{"spatialReference":{"wkid":4269},"rings":[[[-77.8349285333758,37.6361135016974],[-77.81960853969096,37.60849050684496],[-77.76326755681416,37.612051504042306],[-77.65624159269949,37.56084251073259],[-77.79783755501326,37.45895353702605],[-77.80856755357546,37.42655354414337],[-77.84672354251077,37.41511354791091],[-77.86612353417347,37.45651354002679],[-77.89446252586886,37.449570542503686],[-77.89900452299348,37.475264537341495],[-77.99957249079387,37.498044536312186],[-78.01544548631904,37.49117153831928],[-78.01720148691993,37.4714825424623],[-78.04932247701693,37.47225354348388],[-78.06587947310611,37.4520515482785],[-78.09228846478611,37.45581054847166],[-78.09874646368793,37.440567551867765],[-78.13204545265646,37.45467855017099],[-78.07532645825233,37.657246506206654],[-77.95694849651309,37.62493050850026],[-77.94363049978192,37.63906850508927],[-77.95389249495726,37.66767549956278],[-77.91839450446906,37.69166549330246],[-77.8349285333758,37.6361135016974]]]}
SUGGESTADDRESS
This is a Helper function that suggests addresses based on a text input. This can be used as an interactive autocomplete address search.
Syntax
ARCGIS.SUGGESTADDRESS(search_term, [max_suggestions], [country], [geocode_service])
Parameters
Parameter |
Description |
search_term |
The input text provided by a user, which is used to generate a list of possible matches. |
Yes |
max_suggestions |
The maximum number of suggestions to be returned. If this number is greater than 15, the suggestions will be made by the geocoding operation, which may consume additional credits and may lead to unexpected results. The default is 5. The maximum is 50. |
No |
country |
Limits the results to a particular country. For example, use United Kingdom. Run |
No |
geocode_service |
The maximum number of suggestions to be returned. If this number is greater than 15, the suggestions will be made by the geocoding operation, which may consume more credits and may lead to different results. The default is 5 and the maximum is 50. |
No |
Function example
=ARCGIS.SUGGESTADDRESS("Orange county",10, "USA")
Result
Orange County, CA, USA |
Orange County, FL, USA |
Orange County, IN, USA |
Orange County, NC, USA |
Orange County, NY, USA |
Orange County, TX, USA |
Orange County, VA, USA |
Orange County, VT, USA |
Orange County Great Park, Irvine, CA, USA |
Orange County Airport, 500 Dunn Rd, Montgomery, NY, 12549, USA |
GETGEOMETRY
This is a Helper function that returns a specific geography including its area ID and its geometry.
Syntax
ARCGIS.GETGEOMETRY (country, geography_level_id, search_term, exact_match, show_all_matches)
Parameters
Parameter |
Description |
country |
The source country of the data collections. For example, use United States. Run the |
Yes |
Yes |
search_term |
The name of the geography, used as a search term. For example, use California, San Diego, CA. |
Yes |
exact_match |
Only return results matching the exact search term. |
No |
show_all_matches |
Return all results of the search term, even if there are matches with multiple geographies. |
No |
Function example
=ARCGIS.GETGEOMETRY("US", "US.ZIP5", "92373")
Result
{"rings":[[[-117.12524300001411,34.02798699990267],[-117.12036700034746,34.02720199979613],[-117.11946069993878,34.02691230002605],[-117.11706400015063,34.02586400027873],[-117.11542800003329,34.02535400026468],[-117.11394199970378,34.024991000148155],[-117.10813200007668,34.02381200014015],[-117.10687099987805,34.023412999790644],[-117.10522200024025,34.022608000011026], ...
LISTGEOGRAPHIES
This is a Helper function. Depending on the input parameters, a list of countries, a list of geography levels (for example, districts or provinces) of a country, or a list of the area IDs for a geography level is returned. The maximum list item limit is 5,000.
Syntax
ARCGIS.LISTGEOGRAPHIES([country], [geography_level_id], [search_term], [exact_match])
Parameters
Parameter |
Description |
country |
The source country of the data collections. For example, use United Kingdom. If a value is specified, all geography levels for that country are listed. If left blank, all countries and territories are listed. |
No |
The ID of a geography level. For example, use US.States for the states in the United States. If a value is specified, all areas of a geography level, such as California, and their FIPS IDs are listed. If left blank, the results are dependent on the |
No |
search_term |
A search term that narrows the results by matching the search term with the geography names. |
No |
exact_match |
No |
Function example
=ARCGIS.LISTGEOGRAPHIES()
Result
Country |
Country code |
Albania |
AL |
Algeria |
DZ |
Andorra |
AD |
Angola |
AO |
Anguilla |
AI |
=ARCGIS.LISTGEOGRAPHIES("USA")
Result
ID |
Name |
US.WholeUSA |
Entire Country |
US.States |
States |
US.DMA |
DMAs |
US.CD |
Congressional Districts |
US.CBSA |
CBSAs |
US.Counties |
Counties |
US.CSD |
County Subdivisions |
US.ZIP5 |
Zip Codes |
US.Places |
Cities and Towns (Places) |
US.Tracts |
Census Tracts |
US.BlockGroups |
Block Groups |
=ARCGIS.LISTGEOGRAPHIES("Spain","ES.Municipalities")
Result
ID |
Name |
Major geography subdivision |
01001 |
Alegría-Dulantzi |
País Vasco |
01002 |
Amurrio |
País Vasco |
01003 |
Aramaio |
País Vasco |
01004 |
Artziniega |
País Vasco |
01006 |
Armiñón |
País Vasco |
=ARCGIS.LISTGEOGRAPHIES("Spain","ES.Municipalities","Barcelona")
ID |
Name |
08019 |
Barcelona |
Cataluña |
LISTDATACOLLECTIONS
This is a Helper function that lists the data collections available for a country.
Syntax
ARCGIS.LISTDATACOLLECTIONS(country, [data_collection_id], [search_term])
Parameters
Parameter |
Description |
country |
The source country of the data collections. For example, use United Kingdom. Run the |
Yes |
data_collection_id |
The ID of a data collection. For example, use KeyFacts. If a value is specified, all variables of the data collection are listed. If left blank, all data collections for the specified country are listed. |
No |
search_term |
A search term that narrows the results by matching the search term with the data collection names and descriptions or variable names and descriptions. For example, use fast food. |
No |
Function example
=ARCGIS.LISTDATACOLLECTIONS("USA")
Result
ID |
Description |
Example data |
1yearincrements |
The 1 Year Increments data collection includes population counts by 1-year age breaks up to age 84 for 2023 and 2028. The collection also includes 2010 population by single year increments up to age 21. The data tables include age for total population and age by gender. This collection contains data from the Esri 2023/2028 Updated Demographic database and Esri Census 2010 database. |
5yearincrements |
The 5 Year Increments data collection includes population counts by 5-year age breaks for 2023, 2028, and 2010. The data tables include age for the total population and age by gender. This collection contains data from the Esri 2023/2028 Updated Demographic database, American Community Survey (ACS) database, and Census 2010 database. |
Age |
This data collection includes age range data for males and females used for data pyramid infographics. This collection contains Esri 2023 Updated Demographic data. |
=ARCGIS.LISTDATACOLLECTIONS("USA","health")
Result
ID |
Name |
Description |
REL65HI2OC |
2023 Pop 65+: Other Health Ins Combos REL (ACS 5-Yr) |
2023 Population 65+: Other Health Ins Combinations REL (ACS 5-Yr) |
ACSCIVNINS |
2023 Civ Noninstitutionalized Population (ACS 5-Yr) |
2023 Civilian Noninstitutionalized Population (ACS 5-Yr) |
MOECIVNINS |
2023 Civ Noninstitutionalized Population MOE (ACS 5-Yr) |
2023 Civilian Noninstitutionalized Population MOE (ACS 5-Yr) |
=ARCGIS.LISTDATACOLLECTIONS("USA", "health", "<19")
Result
ID |
Name |
Description |
ACSCIVNI0 |
2023 Civ Noninstitutionalized Pop <19 (ACS 5-Yr) |
2023 Civilian Noninstitutionalized Pop <19 (ACS 5-Yr) |
ACS0ONEHI |
2023 Pop <19: 1 Type of Health Ins (ACS 5-Yr) |
2023 Population <19: One Type of Health Insurance (ACS 5-Yr) |
MOE0ONEHI |
2023 Pop <19: 1 Type of Health Ins MOE (ACS 5-Yr) |
2023 Population <19: One Type of Health Insurance MOE (ACS 5-Yr) |
LISTTRAVELMODES
This is a Helper function that lists all travel modes of the route service supported by ArcGIS Online or configured for your organization.
This function requires no parameters. For a similar example, see the Microsoft RAND function article.
Syntax
ARCGIS.LISTTRAVELMODES()
Function example
=ARCGIS.LISTTRAVELMODES()
Name |
Description |
Details |
Driving Time |
Models the movement of cars and other similar small automobiles, such as pickup trucks, and finds solutions that optimize travel time. Travel obeys one-way roads, avoids illegal turns, and follows other rules that are specific to cars. When you specify a start time, dynamic travel speeds based on traffic are used where it is available. |
Avoid Carpool Roads; Avoid Express Lanes; Avoid Gates; Avoid Private Roads; Avoid Unpaved Roads; Driving an Automobile; Roads Under Construction Prohibited; Through Traffic Prohibited; Vehicle Maximum Speed (km/h): TravelTime 0 |
Walking Time |
Follows paths and roads that allow pedestrian traffic and finds solutions that optimize travel time. The walking speed is set to 5 kilometers per hour. |
Avoid Private Roads; Avoid Roads Unsuitable for Pedestrians; Preferred for Pedestrians; Walking Speed (km/h): WalkTime 5; Walking |
Walking Distance |
Follows paths and roads that allow pedestrian traffic and finds solutions that optimize travel distance. |
ADDHEADERS
This creates a header row for the output for ArcGIS for Excel functions. This function is not applicable for some functions, such as some under the Helper functions category.
This function requires only one parameter.
Syntax
ARCGIS.ADDHEADERS(ARCGIS_function)
Parameters
Parameter |
Description |
ARCGIS_function |
Input a cell reference to another ArcGIS for Excel function where you want to add headers. |
Yes |
Function example
=ARCGIS.ADDHEADERS(A2)
This example will work if you have another function in cell A2—for example, if cell A2 contains the =ARCGIS.GETCOORDINATES("380 New York Street, Redlands, CA, USA") function.
Result
Longitude (X) |
Latitude (Y) |
Comma, decimal point, and semicolon separators
If you are using a German, Dutch, Spanish, French, or Italian-language operating system, numbers written in decimal form may be formatted differently than for those using English-language operating systems. For some languages, numbers containing decimals are written or separated using a comma (,) instead of a decimal point (.).
Depending on the decimal separator, functions in Excel should be formatted differently.
When a decimal point (.) separator is used, you must separate function parameter inputs using a comma (,), for example,
=ARCGIS.GETADDRESS(-70.251, 43.65808).When a comma (,) decimal separator is used, you must separate function parameter inputs using a semicolon (;), for example,
=ARCGIS.GETADDRESS(-70,251; 43,65808).
In Excel, the default decimal separator is the same as that of your operating system. When using Excel, you can also customize this setting.
