Configure the map
ArcGIS Field Maps includes two apps: the Field Maps mobile app and the Field Maps Designer web app. Field Maps Designer allows you to configure the maps mobile workers use in Field Maps. Configure the map based on the needs of your mobile workers. You can configure the following:
  • Available maps—Include only the maps mobile workers need in the field.
  • Duplicate a map—Create a copy of an existing map.
  • Delete a map—Delete a map from your organization.
  • Title, summary, and thumbnail—Edit the title, summary, and thumbnail of the map.
  • Manage content— Create layers, search for and add layers to the map, remove layers, and reorder layers.
  • Form—Configure the form mobile workers use to collect data and perform inspections in the field.
  • Feature templates—Reorder, duplicate, format, delete, and set default values for feature templates that are used for data collection.
  • Geofences—Create and manage geofences that send location alerts and automatically trigger location sharing in Field Maps.
  • Offline—Prepare the map for offline use.
  • App settings—Simplify deployment by configuring settings for Field Maps.
  • Sharing—Configure the sharing settings for the map.
  • Edit in Map Viewer—Edit the map in Map Viewer.
For an overview of the Field Maps Designer interface, watch the video below and see the Field Maps Designer quick reference section below.
Caution:
When you're editing the map, layers, and form in Field Maps Designer, do not simultaneously edit them in a separate browser tab. Editing the map, layers, and form across multiple tabs will result in the loss of your data.
View and configure maps
The Maps page in Field Maps Designer allows you to view and configure maps for use in Field Maps. The maps you can configure in Field Maps Designer depend on your role and privileges in your organization. To view and configure maps in Field Maps Designer, complete the following steps:
  1. In a browser, sign in to your organization and open Field Maps Designer from the app launcher in ArcGIS Online.
    The Maps page appears, displaying maps that you own and maps included in any shared update groups of which you're a member.
    Maps on the Maps page are displayed as map cards (grid view) or list items (table view). Field Maps Designer displays actions and capabilities relevant to the map.
    You can complete the following actions for a map: Configure , Duplicate , Sharing , and Delete .
    One or multiple of the following capabilities are displayed on the map depending on how the map was configured: Editable , Read-only Read-only , Mobile Map Package (MMPK) .
    If you're an administrator, you can view and configure any map in your organization. Click Filter and select All maps.
  2. Click Folder to view maps organized in your folders.
    When a folder is chosen, an indicator will show that the list of maps has been filtered by the selected folder. Clicking the Close button will remove the filter and return the author to their default My maps list.
  3. Click any map to configure it.
    The Forms page appears, displaying the contents of the map.
    Tip:
    You can also open a map in Field Maps Designer from the map's item page. Browse to the map's item page and click Open in Field Maps Designer.
Hide available maps
The Field Maps mobile app provides access to maps that are shared with or owned by a mobile worker. You may have maps that you don't want accessed from the mobile app. For example, you may have maps that are made for ArcGIS Dashboards that are for desktop use only. To hide maps you own from Field Maps, complete the following steps:
  2. Select each map you want to hide from Field Maps by checking the map card.
    Tip:
    Search for specific maps using the search bar.
  3. Click Hide from mobile app.
    The selected maps are on the Hidden maps tab of the Maps page and are hidden from Field Maps.
    You can make hidden maps visible in Field Maps at any time. To display maps that have been hidden, click the Hidden maps tab, select the map cards you want to display, and click Show in mobile app.
Duplicate a map
You can create a map based on an existing map in your organization. For example, you can reuse a map from a previous field season. You can create a copy of the map that contains the same layers and basemaps as the original. When duplicating a map, the summary, feature templates, forms, and offline settings are preserved.
Map areas, sharing settings, and the Hide in Field Maps setting are not preserved when duplicating a map.
To duplicate a map that's available through a shared update group, the Save As setting must be enabled in the item details of the web map. If you own the map or if you're an administrator, the Save As setting doesn't have to be enabled to duplicate the map.
To duplicate a map, complete the following steps:
  2. On the map card, click Duplicate .
  3. Provide a title for the new map and click Yes, duplicate.
    The new map is added to the Maps page, and the Forms page appears.
Delete a map
You can delete any map you own and administrators can delete any map in their organization. To delete a map, complete the following steps:
If a map is available to you through a shared update group, you cannot delete the map.
  2. On the map card, click Delete .
    The map is deleted.
Configure the title, summary, and thumbnail
Ensure that mobile workers can find the map they need in Field Maps. To edit the map's title, summary, and thumbnail, complete the following steps:
  2. Click a map card to start configuring the map.
  3. Click Overview .
    The Overview page appears, displaying information about the map and the option to open the map in Map Viewer.
    The Overview page includes a Capabilities section that displays the capabilities supported in the map. One of the following capabilities will show depending on how the map was configured: Editable, Read-only.
    If the map you configured is a mobile map package (MMPK), the Overview page will display the size and number of downloads for the mobile map package. To learn more about MMPKs and their limitations in Field Maps Designer, see Create an MMPK for offline use.
  4. Click Edit to edit the map title and summary.
  5. Provide a title and summary, and click Save.
  6. To use a custom image for the thumbnail, hover over the current thumbnail and click Change thumbnail.
    For best results, add an image that is 600 pixels wide by 400 pixels high or larger with an aspect ratio of 3:2 in a web file image format such as PNG or JPEG.
Manage content
You can add existing layers, create layers, reorder and group layers, and remove layers from the map using Field Maps Designer. To begin managing content, complete the following steps:
  2. Click the map card to configure the map.
  3. From the Forms pane, manage content in the following ways:
Add existing layers
To add existing layers to a map, complete the following steps:
Layers must meet the data requirements for Field Maps to be added to the map.
  1. Begin managing content for the map.
  2. Click the Add layers button.
    The Add layers panel appears.
  3. Use the Search bar to find layers you want to add to the map.
    You can search in My Content, My Favorites, My Groups, and My Organization.
  4. Click the Add button next to each layer you want to add to the map.
    Caution:
    If you add the same layer to the map more than once, the map cannot be taken offline. Field Maps does not support offline use for maps with duplicate layers.
  5. Click Save.
    The selected layers are added to the map.
Create new layers
To create and add new layers to a map, complete the following steps:
  2. Click the drop-down menu next to the Add layers button and click Create layers.
    The Create layers page appears.
  3. On the Define layers tab, define the layers that will be used for data collection.
    1. In the Layer name text box, enter a name for the layer.
    2. Click the Layer type drop-down menu and select Point layer, Line layer, or Polygon layer.
      The type of layer you select depends on the type of information being captured:
      • Point—Use a point layer when collecting individual assets or observations such as fire hydrants, trees, or storm debris.
      • Line—Use a line layer to collect linear features, such as roads, sidewalks, or pipelines.
      • Polygon—Use a polygon layer when collecting features with area, such as land parcels, boundaries, or small bodies of water.
    3. Add more layers by clicking the Add button .
    4. Once you've finished adding layers, click Next.
  4. On the Configure settings tab, provide information about the layer and map settings.
    1. Answer the following questions:
      • Will tasks be created and assigned to mobile workers?
        If enabled, a to-do list will be added to the layer.
      • Will high-accuracy GPS receivers be used to collect data?
        If enabled, GPS metadata fields will be added to the layer. For more information, see Prepare for high-accuracy data collection.
      • Will 3D spaces be modeled or analyzed?
        If enabled, z-values will be collected.
      • Will relative locations be used for linear referencing?
        If enabled, m-values can be stored in the layer.
    2. Optionally, change the coordinate system by clicking the Advanced settings drop-down arrow and selecting a coordinate system from the Set coordinate system drop-down menu.
      The map's coordinate system is used by default. You can also use the coordinate system being used by another layer in the map, or you can browse and select from a list of coordinate systems.
    Once the layers are created, layer settings cannot be changed.
  5. After you've set the layer settings, click Next.
  6. On the Save layers tab, provide the following information:
    1. In the Feature layer title text box, enter a name for the feature layer.
      The feature layer contains the layers defined on the Define layers tab and is stored as an item in your organization.
    2. Click the Folder drop-down menu and select the folder in which to save your map or create a new folder.
  7. Click the Save button to create and save the new layers.
    Tip:
    Before you click the Save button, you can review the information on the previous tabs by clicking Back.
Reorder and group layers
To reorder and group layers in the map, complete the following steps:
  2. Click the drop-down menu next to the Add layers button and click Manage content.
    If you have not saved changes, a Layers have unsaved changes message appears. You must save or discard changes before managing content.
  3. To reorder layers, use the Rearrange buttons to drag and rearrange layers in the list.
  4. To group layers together, click the More Options button next to the layer name and click Create group.
    You can use the Rearrange buttons to drag layers in and out of groups.
  5. Click Save when finished.
Remove layers and groups
To remove a layer or group layer from the map, complete the following steps:
  3. Click the More Options button next to the layer or group and click Remove.
Form configuration
Mobile workers read, enter, and update forms to collect data and perform inspections. To learn how to configure the form in Field Maps Designer, see Build the form.
Manage feature templates
Feature templates categorize assets and observations in a layer and are based on a specific combination of attributes. For example, feature templates for a damage assessment layer allow editors to categorize a new feature by the degree of damage to the building: Affected, Minor, Major, or Destroyed. The feature layer owner can preset the damage assessment attribute for these four options. This ensures that mobile workers enter a valid value for this attribute. In Field Maps, the templates display as types of assets and observations mobile workers can collect.
To edit a layer's feature templates, you must be the owner of the layer or an administrator. The layer must also be a hosted feature layer.
Managing templates on subtype group layers and subtype group tables are not supported.
Field Maps Designer allows you to manage feature templates in the following ways:
Learn how to create feature templates in ArcGIS Pro.
Configure feature templates
To configure feature templates, complete the following steps:
  3. Click an editable layer under Layers or a table under Tables and click the Templates tab to configure its feature templates.
    The Templates tab appears, displaying the feature templates for the item.
    Managing templates that subtype group layers and subtype group tables are not supported
As you configure the feature templates for a layer, you can use the Undo and Redo buttons to undo or redo changes you've made. Undo and redo actions are specific to each layer.
Update the name and description
Change the name and description of the feature templates to provide meaningful information to mobile workers. Mobile workers see this information when selecting a feature template in Field Maps.
  1. Click a feature template.
    The Formatting settings for the feature template appear in the Properties pane.
  2. Provide the name and description of the feature template by editing the Display name and Description settings.
  3. Click Save.
Reorder feature templates
The order of the feature templates on the Templates tab is how they appear in Field Maps. You can reorder feature templates so mobile workers see the most commonly used templates at the top of the list.
  1. Drag the feature templates to reorder them.
    If the layer contains feature types, you can only reorder feature templates within their type. Feature types can also be reordered.
  2. Click Save.
Set default values
Set default values for feature templates so relevant information is available when mobile workers create a feature.
    The Default values settings for the feature template appear in the Properties pane.
  2. Edit the default value for each relevant attribute.
    To filter by fields used in the form, check the Only show fields in the form check box.
    If a field has a range or coded value domain, the default value must honor it. If you set a default value outside the allowable range, an error message appears.
  3. Click Save.
Duplicate and delete feature templates
To duplicate a feature template, select it and click Duplicate. To delete a feature template, select it and click Delete.
Update feature templates
If you make changes to your layer that cause the feature templates to be out of sync with the layer's style, Field Maps will prompt you to update your feature templates to align with the layer. To learn more about changes to consider when configuring feature templates, see Considerations for feature templates.
Configure the map to work offline
Ensure that mobile workers can take web maps offline if they'll be working in areas without a reliable internet connection. Use Field Maps Designer to configure the following offline settings:
Field Maps Designer allows you to review and configure the offline status of the web map. To learn how to create web maps and mobile map packages (MMPKs) for offline use, see Prepare maps for download.
Enable offline mode
For mobile workers to take a web map offline, offline mode must be enabled. To enable offline mode, complete the following steps:
  2. Click the map card.
  3. Click Offline.
    The Offline page appears, displaying information about the map's offline status.
  4. Turn on the Offline toggle button.
    If an item in the map is not enabled for offline use, an error message appears next to the toggle button and the item.
    You can enable or disable offline mode as needed.
Enable content for offline use
Each layer, table, and basemap is listed in the Content section and must be enabled for offline use to take the map offline. If content is unsupported for offline use, an error or warning message will appear along with an action you can take to resolve the issue.
The following warnings appear when content in the map may impact offline workflows:
Warning
The layer or basemap is deprecated.
The item is an Esri layer or basemap that is no longer supported or is in mature support. If a vector tile replacement is available, you'll be prompted to replace it. For a list of deprecated basemaps, see ArcGIS Online basemaps (deprecated).
The following errors appear when content in your map is preventing your map from being taken offline:
Error
Sync is not enabled.
Sync must be enabled.
Layer type is not supported.
The layer type is not supported.
The layer is a duplicate.
The layer is duplicated in the map. If it's a hosted feature layer, you can create views for each layer to take them offline.
The layer contains unsupported field types.
The layer contains field types that aren't currently supported in Field Maps.
The layer contains field names longer than 31 characters or that have SQL key words.
These properties are not supported in Field Maps. To resolve this, create a new field in the layer, copy the attribute information from the invalid field, and remove it.
The tile layer is not enabled for export tiles.
Tile layers must be enabled for export tiles.
The layer references tiles stored in a user-managed data store and export is disabled which prevents offline use.
Layer tiles cannot be exported because the user managed data store has not been enabled for export.
Map notes layers from a feature collection are not supported offline.
The map notes layer is saved as a feature collection item.
The layer contains multiple vector tile sources.
The vector tile layer is made from multiple vector tile sources.
The hosted feature layer view does not include all editor tracking fields.
All editor tracking fields must be included in a hosted feature layer.
Location sharing layers are not supported offline.
Location sharing layers (tracks, track lines, and last known locations) cannot be taken offline; however, you can view your own tracks from the Layers tool in Field Maps.
Joined hosted feature layer views are not supported offline.
The layer is a joined hosted feature layer view.
The layer contains attribute indexes with unsupported characters.
The layer's attribute index contains an unsupported character, such as a dash or hyphen. To resolve this, delete the index and re-add it.
The layer is missing the subtype field, the global ID field, or relationship key fields.
The layer is missing a required field that must be included when the layer is published.
Indoor positioning data failed to load: Check map configuration and item access privileges.
The indoor positioning item referenced by the map no longer exists or cannot be accessed.
The IPS layer is not sync enabled and cannot be taken offline.
The indoor positioning system layer must be sync enable to take the layer offline.
If a different error is preventing the item from being taken offline, click the View item details button to view additional information. You can click the Refresh button at the top of the Content section to update changes you make to the map's content outside of Field Maps Designer.
For more information about offline data requirements, see Enabling layers and maps for offline use.
Create and manage map areas
Creating map areas as part of the map allows you to prepackage one or more areas so that mobile workers can download them without having to configure the extent or level of detail. To create a map area using Field Maps Designer, complete the following steps:
  1. On the Offline page, click the Map areas section to expand it, and click Manage areas.
    The Manage areas window appears.
  2. Create map areas for mobile workers the same way you create map areas in ArcGIS Online.
    For step-by-step instructions, see Take web maps offline in ArcGIS Online.
Once map areas are created as part of the map, mobile workers can download them in Field Maps. An online version of the map remains available. If mobile workers are using the map for data collection, their captured assets, observations, and inspection information are only available on their device until the map is synced. Updates from other workers are not available without syncing.
There is a limit of 16 offline map areas that can be created in a single web map.
Manage features and attachments
You can manage features and attachments from the Offline page in Field Maps Designerr, including delivery and attachment fields.
Deliver features and attachments
By default, all features and attachments are downloaded and synced by mobile workers. However, mobile workers may not need all of this information to complete their work. You can limit the size and amount of data retrieved from the server during initial download as well as subsequent sync operations. This makes it faster for mobile workers to share changes and it minimizes data transfer costs. You can limit the types of data mobile workers retrieve from the server by adjusting the feature and attachment delivery settings in Field Maps Designer.
  1. On the Offline page, click the Features and attachment delivery section to expand it.
    A list of options appears for editable and read-only features.
  2. Select the delivery option for each type of feature.
Attachment fields
To support attachment form elements, you must configure the attachment so attachment elements can be used offline by mobile workers.
If attachment settings are not configured correctly, mobile workers will not be able to edit layers with forms that have attachment elements. Check the box to include attachment fields, such as keywords in offline areas.
To configure the attachment field settings, complete the following steps:
  1. On the Offline page, click Features and attachments to expand the section.
  2. Under Attachment fields, locate the Additional information about attachments option.
  3. Check the box to include attachment fields in offline replicas, such as keywords and EXIF data.
    Checking this option is required for pop-up attachment elements that use keywords to filter attachment form elements.
  4. Click Save to save your changes.
Include standalone table rows
By default, standalone table rows are not included in the offline area, which minimizes both initial download size and data transferred during sync operations. However, some offline workflows may require standalone table rows such as when table information is needed for Arcade expressions in the form or pop-up. Rows from related tables are not affected by this setting, and are always returned for features within the offline area's extent.
  1. On the Offline page, click the Tables section to expand it.
    A list of options appears for table rows in offline areas.
  2. Select an option to include or exclude table rows.
  3. Click Save to save your preference or Cancel to revert your changes.
Set the offline basemap
Set the basemap used when the map is taken offline. You can use the basemap defined by the web map or a tile package as the offline basemap. Using a tile package allows you to download a larger and more detailed basemap for offline use. The web map can reference a tile package on the device or from your organization. Set the offline basemap by completing the following steps:
  1. On the Offline page, click the Basemap and tile package section to expand it.
    The Basemap defined by the web map option is selected by default.
  2. Select the basemap to use offline from one of the following options:
    • Basemap defined by the web map—Reference the basemap defined by the web map. If you select this option, the basemap will download with the web map in Field Maps.
    • Tile package on the device—Reference a tile package that's been copied (sideloaded) to the device. If you select this option, enter the file name of the tile package in the Package filename text box. Referencing a copied tile package reduces the time it takes to download a map, as the basemap is already available on the device. Only operational layers are downloaded. For more information, see Create a basemap to copy directly onto devices.
    • Tile package from my organization—Reference a tile package from your organization. If you select this option, click Browse to select a tile package. Referencing a tile package from your organization allows you to share the basemap with every mobile worker who uses the map. A downloaded tile package item can be used across multiple maps and map areas, requiring only one download of the basemap.
  3. Click Save.
If you are replacing a tile package currently being referenced, mobile workers must redownload the map on their device to access the updated basemap.
Advanced offline settings
If you have configured true curves for your map and want to retain them when taking your map offline, you can enable Field Maps to maintain and download these true curves using the True curves settings. Enable the True curves setting by completing the following steps:
  1. On the Offline page, click the Advanced offline settings section to expand it.
  2. Check the box next to Maintain and download true curves.
  3. Click Save.
Features with true curves cannot be edited in the Field Maps mobile app. Enabling true curves in Field Maps Designer allows you to edit features with true curves in ArcGIS Pro and other apps that support true curve editing. To learn more, see Allow or prevent editing of true curve features.
Add geofences
Adding geofences to the map allows you to define areas that, when entered or exited, trigger one of the following actions in Field Maps:
  • Location alert—Send a custom message to mobile workers when they enter or exit an area. For example, you may want to automatically warn mobile workers if they enter private property or a hazardous location.
  • Location sharing—Enable or disable location sharing when mobile workers enter or exit an area. For example, you may only want location sharing enabled when mobile workers are on company property.
To enable or disable location sharing with geofences, users must have an eligible user type and the appropriate location sharing privileges enabled through their role. For more information, see Share location requirements.
Geofences work online or offline and in the foreground or background of the mobile device. They also work indoors if indoor positioning systems (IPS) have been set up. Geofences can be added to any web map by completing the following steps:
  3. Click Geofences .
    The Geofences page appears, displaying the map and any geofences that have already been added.
  4. Click Add geofence.
    The New geofence pane appears. This is where you configure the properties of the geofence and the actions it triggers in Field Maps when entered or exited.
  5. In the Name text box, enter a name for the geofence.
  6. On the Layers drop-down menu, select the layer used to define the geofence.
    The map pans and zooms to the selected layer and symbology is added to represent the new geofence.
    Subtype group layers are not supported.
  7. Optionally, add a filter.
    Filters allow you to limit the features used as the geofence based on attribute values. For example, a filter is added to a park boundaries layer so only hazardous boundaries are used to create the geofence. Add a filter to a geofence by completing the following steps:
    1. Click Filter.
      The Filter pane appears.
    2. In the Filter pane, click Add new.
      Filters are written using a field in the layer, an operator, and a value. For example, an expression used to filter only hazardous park boundaries would look like the following:
      • Field—hazardous
      • Operator—is
      • Value—yes
    3. Click the field selector, select a field to use for the expression.
    4. Click the operator selector and select an operator.
    5. In the value text box, enter a value to use in the expression.
    6. Click Done to apply the filter to the geofence.
    To learn more about filters, such as adding additional expressions and creating expression sets, see Apply filters.
  8. Define a buffer for the geofence.
    Buffers allow you to set a geofence boundary for point, line, and polygon features. For example, a 10-foot buffer is added to a pipeline layer to use as the geofence. Add a buffer to the geofence by completing the following steps:
    If you're using a point or line layer, a buffer is required.
    1. Enter the buffer value in the Buffer text box.
    2. Set the units from the Units drop-down menu.
      The choices depend on the unit settings from your ArcGIS organizational account, either US Standard or Metric.
  9. On the Type drop-down menu, select the type of action triggered by the geofence. Choose either Location alert or Location sharing.
    If you select Location alert, check the On enter or On exit check box (or both) to send the alert to mobile workers when they enter or exit the geofence. Additionally, in the Message text box, provide the message that appears when mobile workers are alerted in Field Maps.
    Tip:
    You can click Add field next to the Message text box to include field values in your messages.
    If you select Location sharing, choose whether location sharing is enabled when mobile workers enter a geofence (Start on enter, stop on exit) or whether it's enabled when they exit a geofence (Stop on enter, start on exit).
    You can only add one Location sharing geofence per map.
  10. Optionally, add an Arcade expression.
    Arcade and the Geotrigger Notification profile allow you to customize the geofence action based on feature attributes. For example, you can customize a geofence to send location alerts during a specific time range. Add Arcade expressions to geofences by completing the following substeps:
    1. Next to the Type drop-down menu, click Edit Arcade .
      The New expression window appears, displaying the current Arcade expression that defines the geofence.
    2. Write the Arcade expression.
      The following example is for a location alert action. It defines a variable for the message that should be sent to mobile workers and states that it should only be sent during a specific time range. Two fields within the geofence layer, StartHour and EndHour, are used to define the time range.
      var d = Dictionary('message', `Site blasting occurs between the hours of ${$fencefeature['StartHour']} and ${$fencefeature['EndHour']}`,
                         'actions', []);
      if (($fencenotificationtype == 'entered') &&
          (Hour(Now()) >= $fencefeature.StartHour) &&
          (Hour(Now()) < $fencefeature.EndHour)
        d.actions = [ 'showMessage' ]
      return d
    3. Click Run to test the expression and ensure it doesn't result in an error.
    4. Click Done to close the New expression window and apply the expression to the geofence.
  11. Click Save to save and add the new geofence to the map.
    The geofence is added to the Geofences pane. You can edit a geofence at any time by selecting it, and you can zoom to or remove the geofence from its overflow menu.
    If you edit geofences, mobile workers must reload the map in Field Maps for the changes to update on their device.
When mobile workers open a map with geofences, they'll be prompted to enable location alerts or location sharing depending on the action you configured. If they don't enable these settings, they cannot use the map.
Mobile workers must allow Field Maps access to their location and physical activity, or the app cannot record their location or send location alerts.
If geofences are configured to send location alerts, notifications must be enabled for Field Maps on the mobile device.
App settings
Simplify deployment by configuring the Field Maps settings to meet the project requirements. You can configure the following settings:
To configure these settings, click App settings after you begin to configure a map.
Specify the required accuracy and confidence
Your organization may require that all data that is collected meet a specific minimum accuracy and confidence interval. In Field Maps, you can set the required accuracy of GPS positions and whether the positions must meet a 95 percent confidence level. This ensures that data you collect meets your organization's data collection standards.
The default required accuracy is 30 feet. A 95 percent confidence level is unavailable by default, and root mean square (RMS) is used, with 63 to 68 percent confidence. These values can be changed on the Field Maps App settings page .
  1. On the App settings page , click the Collection section.
  2. Under Accuracy, set the accuracy distance and units.
  3. If your organization requires a 95 percent confidence level in the collected data, enable 95% confidence.
    When this setting is enabled, the horizontal accuracy required for data collection is calculated with a 95 percent confidence level instead of the 63 to 68 percent provided by the default calculation using root mean square (RMS).
  4. Click Save.
Enable GPS averaging
Your organization may require that you collect a number of points for a single location and average their information to get a final location and accuracy. In Field Maps, you can set the required number of points to be averaged to get a single location. Any time you use GPS location when collecting data, the required number of points is collected and averaged. When enabled, averaging is done for point features as well as for the individual vertices of lines and polygons.
Streaming to collect lengths and areas and GPS Averaging are mutually exclusive: you can't average values and stream at the same time.
To use GPS averaging, enable it from the Settings page . All data collection performed using the GPS without streaming uses averaging if it is enabled.
  2. Enable GPS Averaging.
  3. In the Points to Average text box, provide the number of GPS positions you want to average to determine the location and accuracy for the collection.
    The default is 5 points.
  4. Click Save.
Once GPS averaging is enabled, the data collection using the GPS performs averaging on each point that is collected. When you start collecting data in Field Maps, a banner appears showing the number of points that have been averaged so far, along with the current GPS accuracy.
Configure capturing locations automatically while traveling (streaming)
If your mobile workers are capturing assets or observations that have smooth curves or a smooth boundary, such as a path or a flower bed, they can use their location and capture them while traveling the length or boundary. You can configure whether the points are added based on a time or distance interval, and you can specify the interval used. Capture points more frequently for smoother locations, or less frequently for simpler locations.
  2. Enable Streaming.
  3. Under Streaming, choose whether you want a distance-based or time-based interval.
  4. Specify the interval.
    For time, you can choose one of the predefined intervals from 1 second up to 1 minute. For distance, enter an interval distance in feet or meters. The choices depend on the unit settings from your ArcGIS organizational account, either US Standard or Metric.
  5. Click Save.
You can also configure streaming in Field Maps.
Set the fix type threshold for GPS location
To ensure a GPS location being used for data collection meets project requirements, you can set the fix type threshold for the GPS location. When a GPS location does not meet the threshold selected, a warning is displayed to the user in the mobile app. This setting is only applied when one or more GPS metadata fields are present in the layer’s attributes. If the location being recorded does not include a fix type, this setting will not apply. Follow these steps to set the fix type threshold:
  2. Under Fix type, select the fix type mobile workers must use when collecting data. Select one of the following options:
    • RTK-Fixed
    • RTK-Float
    • Differential
    • Any
  3. Click Save.
GPS locations that don’t meet the fix type threshold are not used for GPS averaging or streaming.
Set map behavior when collecting new features
You can decide whether the map centers on your location when collecting new features. For example, if mobile workers are walking up to assets to collect data, their location can automatically be used as the location of the new feature. If mobile workers are collecting data from a distance (offset from their location), you may not want their location used automatically. To configure the Collecting new features setting, complete the following steps:
  2. Under Collecting new features, select one of the following options:
    • Center the map and add a point at your location—When collecting a new feature, the map centers at your location and a point is automatically added if it is within location accuracy.
    • Center the map at your location—When collecting a new feature, the map centers at your location without adding a point.
    • No changes to the map—When collecting a new feature, the map does not center on your location and no point is added.
  3. Click Save.
Determine whether manual location can be used for feature collection
To ensure location accuracy, you may want to prevent mobile workers from using a manual location when collecting data so they use a GPS receiver or snapping instead. In Field Maps Designer, you can configure whether mobile workers are allowed to use a manual location when collecting data. If manual location is allowed, you can decide whether mobile workers should be warned when it is being used. This setting is only applied when one or more GPS metadata fields are present in the layer’s attributes.
  2. Under Manual location, determine whether and how manual locations are used in the mobile app. Select one of the following options:
    • Allow manual location
    • Warn when manual location is used
    • Block manual location
  3. Click Save.
Specify photo size
If photos are large, they can quickly increase the size of the database. Attaching smaller photos means less data to store and faster sync times when working offline. When a photo is taken in Field Maps, it is taken at the size specified in the map's settings. When an existing photo is attached in Field Maps, it is resized before it is attached. It is recommended that you consider limiting the size for data collection projects that include many photos.
  2. Under Photo Upload Size, set the photo attachment size.
    By default, photos taken in Field Maps are large (960x1280). You can specify that the app instead use small (240x320), medium (480x640), extra large (1125x1500), or actual size images. The actual size depends on the device with which the photo is taken.
    If you're attaching a photo that is already smaller than the requested size, the photo's actual size is used. If you're attaching a photo with a different aspect ratio, it is resized to fit within the bounds of the requested size but maintains its aspect ratio.
  3. Click Save.
You can also specify photo size in Field Maps.
Show related types
If you have assets or observations that must be related to one another, you may not want mobile workers capturing them directly. For example, if you are capturing streetlights, each pole might be an asset and each light on the pole might also be an asset. The pole and lights are related—each pole has one or more lights, and each light must be related to a pole. If mobile workers capture lights directly, you must relate them to the pole they're on back in the office. If you require mobile workers to specify which pole the light they are collecting is on first, the relationship is created during capture.
To require that the related assets and observations be captured with the relationship in place, assets and observations that must be related to one another are excluded from the list of features that the mobile worker can capture when adding a new asset or observation (this is the default in Field Maps). To capture a related asset or observation, mobile workers must capture them related to another asset or observation.
If instead you want mobile workers to capture all features, turn on Show Related Types by completing the following steps:
  2. Turn on Show related types.
    When this is turned off (which is the default), related assets and observations must be captured through the asset or observation to which they are related. Adding related assets or observations requires the mobile worker to first select the asset or observation they are related to, then add them through it.
  3. Click Save.
Enable snapping to existing locations
When using the map to provide the location of an asset during data collection, mobile workers can snap to existing points—either single places or a point that is part of a line or polygon. This ensures that assets and observations that share locations are correctly captured. To enable snapping, complete the following steps:
  2. Enable Snapping.
  3. Click Save.
You can also enable snapping in Field Maps.
Allow mobile workers to delete all points
You can allow mobile workers to delete all points in a line or polygon during collection or editing. To enable Delete All Points, complete the following steps:
  2. Enable Delete All Points.
  3. Click Save.
Enable Collect Here
Mobile workers can collect new features based on the location of an existing feature, place, or dropped pin. For example, if a mobile worker can't get to the location of an asset or observation, they can drop a pin on their map to collect data. To enable the Collect Here setting, complete the following steps:
  1. On the App settings page , click the Feature Actions section.
  2. Enable Collect Here.
  3. Click Save.
Collect Here is enabled by default.
Enable copying attributes and shape to a new feature
Mobile workers can copy a feature's attributes and shape to create a new feature. This allows mobile workers to create a copy of a feature with a different type or in a different layer, but retain the location, shape, and matching attributes. You can allow mobile workers to copy a feature's attributes, shape, or both. To enable the Copy setting, complete the following steps:
  1. On the App settings page , click the Feature actions section.
  2. Select what mobile workers can copy when creating a new attribute from an existing feature:
    • Copy Attributes—Allows attributes to be copied to a new feature.
    • Copy Shape—Allows shape to be copied to a new feature.
    • Copy All—Allows attributes and shape to be copied to a new feature.
  3. Click Save.
Copy Attributes is enabled by default.
Add layer filters
Layer filters allow mobile workers to filter features on the map based on attribute values within a field. For example, a tree layer filter can allow mobile workers to limit the features on the map based on a specific tree species. You can add and configure layer filters by completing the following steps:
  1. On the App settings page , click the Layer filters section.
  2. Select one of the following options:
    • Off—Disable layer filters on the map. This is the default option.
    • Selected layers and fields—Enable layer filters on select layers and fields. After clicking this option, a list of layers in the map appears. You can expand each layer and select the fields that mobile workers can use as filters in the map.
    • All feature layers and fields—Enable layer filters for all layers and fields in the map.
    Layer filters can be added to text (string) fields and fields with coded value domains (text and numeric).
    Layer filters are combined with any filters defined in the web map for the layer. Features in the layer must meet the criteria for both map and layer filters to display on the map in Field Maps.
    Subtype group layers and geofencing layers are not supported.
  3. Click Save.
After you add layer filters, mobile workers can filter features on the map when viewing layers in Field Maps.
Require location sharing
If location sharing is enabled for your organization, you can require that mobile workers track their location when using the map. When this setting is enabled, mobile workers are prompted to enable location sharing before accessing the map in Field Maps. If mobile workers turn location sharing off, they are no longer able to access a map that requires location sharing. To require location sharing for a map, complete the following steps:
  1. On the App settings page , click the Location sharing section.
  2. Enable the Required toggle button.
  3. Click Save.
For more information, see Share location.
If the map contains a geofence that triggers location sharing, it takes precedent over the require location sharing setting. While location sharing is still required for the map, location will only be shared when they enter or exit the geofence.
Add track categories
Track categories allow you to symbolize and filter tracks in maps, dashboards, and other apps. When you add track categories to the map, they are combined into a single comma-separated value. This value is uploaded with each track point and last known location feature recorded when using the map in Field Maps. You can add one or more track categories to the map by completing the following steps:
  2. Add one or more categories under Track categories.
    Consider how you want to filter and symbolize tracks when adding track categories. For example, you may want to add the type of work being done or the name of the project that's being worked on. As you add track categories, the item ID of the map and a list of existing tags are presented as additional options.
  3. Click Save.
When track categories are uploaded with location sharing data, they are added to the category field of the location sharing schema. You can use this field to filter and symbolize tracks in apps such as Map Viewer and ArcGIS Dashboards.
Define the level of detail for map areas created in Field Maps
You can set the level of detail mobile workers are allowed to use when they create map areas in Field Maps. This ensures that mobile workers download the level of detail needed when working offline. To set the level of detail for map areas created in Field Maps, complete the following steps:
  1. On the App settings page , click the Map area level of detail section.
  2. Select the level of detail mobile workers can use when adding a new offline map area.
    You can either set a range for them to select from or a specific level that is used automatically.
    • Set a range—You can set a range of levels for mobile workers to select from using the Lowest level of detail and Highest level of detail drop-down menus.
    • Set a specific level—You can set a specific level to be used automatically by providing the same value for both drop-down menus.
  3. Click Save.
For more information, see Download maps.
Set default map extent
You can set the default map extent that appears when mobile workers open a map in Field Maps.
  1. On the App settings page , click the Map section.
  2. Under the Default extent setting, click Set extent.
    The Map Extent window appears.
  3. Choose from the following options:
    • To create an extent based on the default extent specified for the organization, click Organization's extent.
    • To create an extent based on the region specified for the organization, click Organization's region.
    • To navigate to a place or address, under Use location search, type keywords in the search box. Keywords can include addresses, street intersections, places, points of interest, and longitude and latitude coordinates. The extent centers on the place or address you specify.
    • To draw a shape representing the extent, click Draw Extent and drag a box on the map. Make changes to the extent as needed by dragging any of the vertices of the extent box or clicking inside the box and dragging it to a new location.
    • To create an extent by specifying coordinate values (in decimal degrees) for the extent boundaries, click Coordinates and type the coordinates in the Top, Bottom, Left, and Right boxes.
  4. Once you've set the default extent, click Save.
Allow editing multiple features at once
Mobile workers can update a form entry for multiple assets or observations at the same time. For example, if mobile workers are performing inspections and need to mark multiple hydrants as having passed inspection, they can select all the hydrants and update all their form entries tracking inspection at once. To allow mobile workers to edit multiple features at once, complete the following steps:
  2. Enable Edit Multiple.
  3. Click Save.
Edit Multiple is enabled by default.
Configure web map search settings
Map authors and administrators can configure web map search settings to make it easier for mobile workers to find features in a map. You can enable searching by address or by specific layers and tables directly within Field Maps Designer. This is supported for all layers, tables, and subtype group layers. To enable search and configure settings, complete the following steps:
While you can configure feature search on a table in Field Maps Designer, table search is not supported in the Field Maps Designer mobile app.
  2. Turn on the Enable search toggle button.
  3. Optionally, provide the Hint text you want to appear in the search bar.
  4. Do the following to enable and configure feature search on a layer or on a table:
    1. Turn on the By layer or By table toggle button.
      The first layer or table in the map is automatically listed.
    2. If necessary, choose a layer or table from the drop-down menu.
    3. Choose an attribute field in the layer or table.
      For a field to be searchable and, therefore, appear in the drop-down menu, it must contain strings or integers and not use a coded domain. Integer fields only support the Equals condition. For the best search results, choose a field with unique values.
    4. Choose whether the result should contain or be equal to the search terms.
    5. To enable search on additional layers or tables or to specify additional search fields for the same layer or table, click Add layer or Add table and repeat steps b – d above.
      You can specify multiple search fields per layer or table.
  5. Click Save.
Disable personal markup
You can prevent mobile workers from creating personal markup when using a map in the Field Maps mobile app.
To disable the Personal markup tool, complete the following steps:
  2. Disable Personal markup.
  3. Click Save.
The Personal markup tool is enabled by default.
Online map
You can prevent mobile workers from using the online version of a map that contains offline map areas.
To disable the Online map setting, complete the following steps:
  2. Disable the Online map setting.
  3. Click Save.
New offline map areas
You can prevent mobile workers from creating new offline map areas in the Field Maps mobile app.
To disable the New offline map areas setting, complete the following steps:
  2. Disable the New offline map areas setting.
  3. Click Save.
Versioning
Branch versioning is a type of geodatabase versioning that works with the ArcGIS Enterprise Web GIS model using a services-based architecture to allow multi-user editing workflows and long transaction scenarios through web feature layers.  Branch versioning is often used with advanced datasets, like the utility network and parcel fabric. In an Enterprise deployment, branch versioning is a requirement for these types of datasets. Branch versioning can also be used for non-specialized Enterprise geodatabase services and datasets.
In ArcGIS Online, branch versioned services must be published to your ArcGIS Enterprise organization as a web feature layer that references registered data. You can add branch versioned services to your ArcGIS Online organization. To work with branch versioned data in a named version, users must sign in with both their ArcGIS Online and ArcGIS Enterprise credentials.
If your map contains branch versioned layers and tables, you can select the version of each feature service that the mobile app should connect to when it is opened in the Field Maps mobile app. To select a version, complete the following steps:
  1. On the App settings page , click the Versioning section.
  2. Under the Versioning setting, select the version of each feature service from the associated feature service drop-down menu.
    Ensure mobile workers have access to the selected versions. If mobile workers don't have access to the selected version, they will not be allowed to open the map.
  3. Optionally, you can also define a subset of versions of the maps that mobile workers can access in the Field Maps mobile app. By default, mobile workers are limited to viewing a single version.
    1. Click Set version(s) only to allow mobile workers to view additional versions.
      A drop-down menu appears.
    2. Select the versions you want mobile workers to have access to.
  4. Click Save.
This setting only applies to the online version of a map. For information on offline workflows, see Work with offline maps and branch versioned data.
Share the map
Share the map so testers and mobile workers can access it in Field Maps. You can set the sharing level and share the map through a link or QR code.
If a map is available to you through a shared update group, you cannot set the sharing level of the map.
To share the map, complete the following steps:
  3. Click Sharing.
    The Sharing page appears.
  4. Click Set sharing level.
    The Share dialog box appears. You can share the map with your organization, specific groups, or the public.
    The Share dialog box displays the language set in the browser’s language setting. If the dialog box does not display in your language, adjust the setting for your browser.
  5. Optionally, once the sharing level is set, share the map in the following ways:
    • Share via link—You can open the link on a mobile device to access the map. Copy the link to share the map with mobile workers.
    • Share via QR code—You can scan the QR code with a mobile device to access the map. Download the QR code to share the map with mobile workers.
    If a map is hidden from Field Maps, it cannot be accessed from the link or QR code. You can configure the Hide in Field Maps setting from the Sharing page or the Maps page.
For more information, see Share your map for use in Field Maps.
Open and edit a map in Map Viewer
When configuring a map, you can use the Open button to make changes to the map and view details about the map beyond what is available in Field Maps Designer. The Open button allows you to make changes to the map in Map Viewer and open the map item details page in ArcGIS Online.
  • Open in Map Viewer—Open the map in Map Viewer. A Map Viewer pop-up window will open in Field Maps Designer that allows you to edit and save changes to the map.
  • View details—Open the item details of the map.
Use Field Maps Designer to configure the content, offline settings, and mobile app settings for the map. You can configure the maps using the following pages:
  • Maps page—Find the maps you want to configure and determine which maps should be hidden from Field Maps.
  • Forms page—View the content in the map and configure the form and feature templates used for data collection.
Maps page
The Maps page shows maps you own. Find the maps you want to configure through browsing and searching, and determine which maps should be hidden from Field Maps.
Maps page
  1. Maps—Return to the Maps page.
  2. Resources—View tutorials, documentation, videos, and more.
  3. Profile—View your currently signed-in account and sign out.
  4. Search—Search for maps you have privileges to edit.
  5. New map—Create a new map for data collection.
  6. My maps tab—Maps you own that appear in Field Maps.
  7. Hidden maps tab—Maps that are hidden from Field Maps.
  8. Select all maps—Check the box to select all of the maps on the My maps or Hidden maps tabs.
  9. Sort—Sort the maps by date modified or title.
  10. View—View the maps in a grid or listed in a table.
  11. Filter—If you're an administrator, filter by My maps or All maps within your organization.
  12. Folder—Filter by folders in your ArcGIS organization.
  13. Map card—Configure , duplicate , share , or delete the map. Check the check box in the upper corner to hide or display the map in Field Maps.
Forms page
The Forms page displays the items in the web map and allows you to configure the form and feature templates for editable layers and tables.
Configure the form
The Form builder pane allows you to configure the form mobile workers use for data collection. See Configure the form for more information.
Forms page showing the form builder.
  4. Forms pane—Find the layers, tables, and basemaps included in the map.
  5. Undo, Redo, and Save—Undo, redo, and save changes made to the form.
  6. Discard changes—Click the drop-down menu to discard changes or clear the form.
  7. Add layers—Add layers to the map.
  8. More options—Remove a layer from the map.
  9. Open—Open the map in Map Viewer and open the item details page.
  10. Form title—Edit the title of the form.
  11. Group—Groups contain form elements. The number of form elements in the group is displayed next to the group title. Select a group to edit its properties or add an Arcade expression.
  12. Form element—Form elements appear as entries on the form in Field Maps. Select a form element to edit its properties or add an Arcade expression.
  13. Form elements—Click or drag elements to add them to the form.
  14. Fields list—Lists the fields in the layer you can add to the form canvas. When fields are added to the form, they become form elements.
  15. Form settings—Configure what happens to field values that have been conditionally hidden.
  16. Form canvas—Drag form elements and fields onto the form canvas to create the form.
The Templates tab allows you to configure the feature templates mobile workers use for data collection. See the Manage feature templates section above for more information.
Forms page showing feature templates.
  4. Forms pane—Find the layers, tables, and basemaps included in the map and select the editable layer or table to configure its form.
  5. Undo, Redo, and Save—Undo, redo, and save your changes.
  6. Discard changes—Click the drop-down menu to discard your changes.
  10. Feature type—A type of feature within the layer. Feature types contain feature templates.
  11. Feature template—Mobile workers use feature templates to collect a specific type of feature in Field Maps.
  12. Duplicate and Delete—Duplicate or delete the selected feature template.
  13. Properties pane—Displays the properties of the selected feature template.
  14. Formatting—Edit the display name and description of the selected feature template.
  15. Default Values—Edit the default values for feature templates.
Sign out
Sign out of Field Maps Designer by signing out of your ArcGIS Online account. For more information, see Sign out.
