Prepare maps for download
In the field, mobile workers often work in areas without a reliable data connection, or with no data connection. In these situations, mobile workers can download maps to make them available offline. Once a map is downloaded, mobile workers can use it the same way they do when connected. While they only receive updates to downloaded maps on request, downloaded maps allow mobile workers to continue working with GIS data you've shared with them without a data connection.
ArcGIS Field Maps supports downloading web maps, mobile map packages (MMPKs), and geospatial PDFs. Web maps can be used while online or they can be downloaded. They can have multiple offline map areas defined as part of the map or on the device, and they must be configured to support offline use. MMPKs are authored in ArcGIS Pro specifically for downloading and viewing assets. A geospatial PDF can be authored in a variety of ways and used as an offline map or an offline basemap. MMPKs and geospatial PDFs cannot be used for data collection.
Your user type determines the maps you can create. Creator and GIS Professional user types can create web maps. Creating MMPKs requires ArcGIS Pro, which is included with the GIS Professional user type.
Decide how to prepare a map for download
Web maps, MMPKs, and geospatial PDFs work offline. Which one you choose, and how you configure it, depends on your project requirements. Choose one of the following ways to prepare a map for download and enable mobile workers to work offline in Field Maps:
Add offline areas to a web map with the Field Maps Designer web app.
Add offline areas to a web map with the Field Maps mobile app.
Add offline areas to a web map with Field Maps Designer
The primary offline workflow is to configure a web map for download and define map areas that mobile workers can take offline. Areas, such as a region of the county or a service area, are defined in Field Maps Designer. Mobile workers can then view and download these map areas in the Field Maps mobile app.
If you know where mobile workers will be working, such as a region of the county or a service area, this is the recommended offline workflow. If you don't know all the areas your mobile workers may need to download, they can define and download additional map areas using the Field Maps mobile app.
Tip:
When possible, define map areas in Field Maps Designer ahead of time. This saves mobile workers from having to define the areas, and it allows map areas to be prepared and packaged once and downloaded by multiple mobile workers. Map areas defined in the Field Maps mobile app are packaged and downloaded for a single use. If they are removed and must be downloaded again, or if they are needed by another mobile worker, they are redefined and regenerated.
If mobile workers need to go offline in a location that wasn't prepared in advance—where there is unplanned work, for example—they can define the area to take offline in Field Maps.
As the map author, you must configure a web map for offline use for mobile workers to create map areas in Field Maps. You can also set the level of detail mobile workers are allowed to use when creating map areas. Mobile workers can then define and download map areas in Field Maps.
If map areas have already been defined using Field Maps Designer, additional map areas can still be created using Field Maps. To prevent mobile workers from creating new map areas in the Field Maps mobile app, see New offline map areas.
Create a mobile map package (MMPK) with ArcGIS Pro
Depending on your offline map requirements, you may want to create and share a mobile map package (MMPK) for offline use instead of a web map. Consider the following benefits of creating a mobile map package for offline workflows:
MMPKs are read-only and cannot be used for data collection.
Copy the map directly to a device—MMPKs can be copied directly to mobile devices before they are given to mobile workers. While mobile workers can also download MMPKs to their device, copying them removes the download time due to file size and takes the responsibility off mobile workers to download the map.
Support additional data and symbology—Some data that doesn't work offline in a web map can be used in an MMPK. For example, if you have layers that aren't sync enabled, or layers that aren't available as feature services that you don't want to publish (file-based data), you can package them in an MMPK. MMPKs also support more advanced symbology than web maps.
Access the map anonymously—You can choose to enable anonymous access when publishing an MMPK, meaning mobile workers won't have to sign in to download the map and take it offline.
Add an expiration date—You can add an expiration date to MMPKs and either warn users when they open an expired map or prevent them from opening it.
Creating MMPKs has additional licensing requirements compared to creating web maps. To create MMPKs, you must have the GIS Professional user type and use ArcGIS Pro.
Create a geospatial PDF item
A geospatial PDF is a standard PDF document enriched with information to reference geospatial data. It can be created or obtained in a variety of ways including the following:
Use Export to PDF in ArcGIS Pro
Use the Print widget in ArcGIS Experience Builder
Use third party technologies, such as TerraGo Technologies GeoPDF® Publisher for ArcGIS Pro.
Download from a website, FTP server, or email.
PDFs can be added as items to your ArcGIS Online organization. When adding a geospatial PDF file as an item, check the box next to This is a Geospatial PDF. See Add files as items for more information. A PDF item that is identified as a geospatial PDF can be viewed and configured in Field Maps Designer and viewed in the Field Maps mobile app for download and use as an offline map. This PDF item can also be used as a referenced basemap.
Prepare a web map for download
Web maps that meet the offline requirements automatically support downloading map areas in Field Maps. Do the following to allow mobile workers to download a web map in Field Maps:
Ensure that the data meets the data requirements.
Create a basemap to copy directly onto devices (optional).
Reference a basemap from your organization (optional).
Create map areas (if defining them as part of the map).
Once your map is configured for offline use, mobile workers can download map areas in Field Maps.
Tip:
To disable downloading a map in Field Maps, uncheck the Enable offline mode check box on the Offline page in Field Maps Designer or in the map's item details. For details, see Configure the map to work offline in Field Maps Designer, Offline options in ArcGIS Online, or Offline options in ArcGIS Enterprise. The offline mode option is not available if your map doesn't meet the offline requirements.
Data requirements
Web maps that are downloaded in Field Maps must meet the data requirements for web maps used in Field Maps in addition to having all items enabled for offline use. To learn about the data requirements for taking layers and maps offline, see Enable the layers and map for offline use in ArcGIS Online or Enable the layers and map for offline use in ArcGIS Enterprise.
Tip:
If your map contains items that aren't enabled for offline use, an error message appears on the Offline page of Field Maps Designer with a description of why your map can't be taken offline. If an item is not sync enabled, an Enable sync option appears. See Enable content for offline use for more information.
You can copy a basemap directly to the mobile worker's device (this process is called sideloading) and reuse it across multiple maps. This has a few advantages over downloading the basemap along with the map area: in most cases, it's faster than downloading the same basemap, and it allows you to prepare basemaps for much larger areas. Additionally, basemaps copied to the device are available to all mobile workers who use Field Maps—each user doesn't need their own copy, saving space on shared devices.
If you want the copied basemap to be the default basemap used when downloading the map (avoiding downloading the basemap along with the rest of the data), the map must reference it and it must be copied to the mobile worker's device.
To copy a basemap directly to devices, prepare your basemap as a map tile package (.tpk or .tpkx file) or vector tile package (.vtpk file). How you create the package depends on where you are creating it and the type of tile package it is.
If you're creating a map tile package in ArcGIS Pro, use the Create Map Tile Package tool.
If you're creating a vector tile package, use ArcGIS Pro and the Create Vector Tile Package tool.
On Android devices, copy the file to the device or SD card. On iOS devices, use the Files app or iTunes. See Copy a basemap to the device for details.
Reference an on-device basemap
You may want mobile workers to download only operational layers and not the basemap of a map, instead using a basemap you created to copy directly to their devices. When you author your map, specify a tile package to use for the offline basemap on the Offline page of Field Maps Designer or in the item details for the map. If that basemap is on the mobile worker's device, only operational layers are downloaded. If the referenced basemap isn't on the device, the mobile worker can continue to download the map's default basemap with the operational layers. See Set the offline basemap for more information.
Use an Esri basemap on ArcGIS Enterprise
You can download an Esri basemap from ArcGIS Online with an ArcGIS Enterprise map. To do so, you must meet the following requirements:
You have an account as a member of an organization in ArcGIS Online.
You are using ArcGIS Enterprise.
For step-by-step instructions, see Use an Esri basemap offline.
To simplify the deployment and sharing of an offline basemap, you can select a tile package or a PDF item from your ArcGIS organization to use when mobile workers download the map. Referencing a tile package or PDF item from your organization allows you to share the basemap with every mobile worker who uses the map. A downloaded tile package item or PDF item can be used across multiple maps, requiring only one download of the basemap.
You can reference a basemap from your organization in the following ways:
Reference a tile package
Reference a geospatial PDF
Reference a tile package as a basemap
To reference a basemap from your organization, prepare it as a map tile package (.tpk or .tpkx file) or vector tile package (.vtpk file). How you create the package depends on where you are creating it and the type of tile package it is.
After creating the basemap, use the Share package tool in ArcGIS Pro to share it with your organization. To learn how to reference the tile package item for use in Field Maps, see Set the offline basemap.
Reference a geospatial PDF as a basemap
To reference a geospatial PDF as a basemap from your organization, see Create a geospatial PDF item.
Create a map area as part of the map (optional)
Creating map areas as part of your map allows you, as the map author, to prepackage one or more areas of a map so that mobile workers in Field Maps can download them without having to configure the extent or level of detail. To create a map area as part of the map, see Create and manage map areas.
If mobile workers are using the map for data collection, their captured assets, observations, and inspection information is only available on their device until the map is synced. Updates from other workers are not available without syncing.
There is a limit of 16 offline map areas that can be created in a single web map.
Optimize download and sync
By default, all features and attachments for both editable and read-only layers are downloaded and synced by mobile workers. However, mobile workers don't always need all of this information to complete their work. Your organization may also want to limit the size and amount of data that mobile workers retrieve from the server during initial download as well as subsequent sync operations. This can make it faster for mobile workers to share changes, and it minimizes data transfer costs. This is especially true when mobile workers are in areas with low bandwidth. You can limit the types of data mobile workers retrieve from the server by adjusting the offline options of your map. The options don't affect edits made by the mobile worker; those are always sent to the server. This section provides examples of when you may not want mobile workers to retrieve features or attachments. For details on how to change these settings, see Deliver features and attachments.
If mobile workers are capturing new assets or observations and do not need knowledge of existing assets and observations, you may not want them to retrieve features and attachments. Mobile workers receive less context, but the time and cost for them to share edits is minimized. Mobile workers will see the assets and observations they have added since downloading the map area. They won't see assets and observations added by others or those they added if they worked with the map before the download.
If mobile workers are inspecting existing assets or observations, you may want them to retrieve only features. You may not want them to retrieve attachments, because they can be large. Mobile workers do not see attachments of existing assets, but they do see their locations and attributes, which may be all that is necessary to complete their jobs. Preventing the retrieval of attachments may also decrease the time and cost to share edits.
There are settings for editable and read-only layers in the advanced offline options. However, if you have multiple layers from the same service and at least one of those layers is editable, all the layers from that service honor the settings of the editable layer. For example, if you configure your map so that you get attachments on editable layers but not read-only layers, but one of the read-only layers is from the same service as an editable layer, that read-only layer's attachments are retrieved.
Use dynamic choice offline
Mobile workers can take forms that contain expressions referencing layers or tables that are not included in the offline map. Make sure all referenced layers and tables are included in the map and support offline use.
To include standalone tables in offline areas, complete the following instructions:
In the actions panel in Field Maps Designer, click Offline.
Click Tables.
Select Include all table rows - this may increase offline map size.
Click Save. Click Cancel to revert your changes.
Create an MMPK for offline use
MMPKs created in ArcGIS Pro and shared with mobile workers can be downloaded or sideloaded in Field Maps.
Data requirements
The following types of data can be included in your map:
Local, file-based feature data—Geodatabase feature classes and shapefiles
Feature layers and feature services hosted on ArcGIS Online, ArcGIS Enterprise, or ArcGIS Server
Tile packages (TPK and TPKX)
Vector tile packages (VTPK)
Rasters—Generally includes any type, including PNG, TIF, JPG, JP2, and others
Locators—Locators
Network datasets
Annotation created in ArcGIS Pro
Create and share an MMPK
Create MMPKs in ArcGIS Pro that can be downloaded in or copied to Field Maps by completing the following steps:
Create a project in ArcGIS Pro.
Add your supported data, including a basemap, to the map.
Configure pop-ups for your features if your map users need details about the features. Add labels if your users will need them in the map.
Optionally, configure feature search by adding a locate provider or creating a locator.
See the Support feature search tip.
Package and share the data using the Package Mobile Map tool.
Share your MMPK in one of the following ways to make it accessible in Field Maps:
Share it through your ArcGIS organization and download it through Field Maps.
Offline maps shared through your organization can be kept private, shared among your groups or with your organization, or made public. You can share the offline map through ArcGIS Pro using the Package Mobile Map or Share Package tools. Alternatively, you can sign in to your ArcGIS organization's portal and upload the
.mmpkfile. (See Share items in the ArcGIS Online or ArcGIS Enterprise help.)Copy (sideload) your
.mmpkfile from your computer to the Field Maps app on your device.Once the file is copied to your device, the map is designated as an On Device map the next time the app is launched or when the list of available maps is refreshed.
To access an MMPK from your computer, you must either save the package to a file in ArcGIS Pro when you create it or download the
.mmpkfile from your ArcGIS Online content.
In Field Maps, download the map, open it, and work with it offline in the same way as any other map.
Tips
The following tips will help you make better MMPKs for offline use:
Support feature search—By default, you can search for places, addresses, and coordinates on maps. Often, map users want to search for particular features they see on the map. When you create the map, there are two ways you can support feature search, depending on the requirements of your map.
Add a locate provider.
Using the Locate tool in ArcGIS Pro, you can add a locate provider so your users can search for features. Add one for each searchable layer. A locate provider can search multiple fields in a layer, and you provide a search mode for each searchable field. Search suggestions are not supported with locate providers. They don't increase the file size of your offline map. See Find places on the map in the ArcGIS Pro help.
Create a locator.
You can create a locator in ArcGIS Pro that allows users to search for features. Create one for each searchable layer. Each locator searches a single field. Locators can include search suggestions. Locators increase the file size of your offline map. See Create a locator in the ArcGIS Pro help.
Provide useful pop-ups—When users view information about features on the map, they are viewing the pop-up you created for that feature. When creating your map, configure a pop-up with information users need. See Configure pop-ups in the ArcGIS Pro help.
If features don't have pop-ups, users can't interact with them on the map.
Include labels—Your users may need to see labels on the map. You can make these available by configuring labels for the feature layers. See Labeling basics in the ArcGIS Pro help.
Use a vector tile package for the basemap—Vector tile packages use tiles of the data instead of raw data. To create a vector tile package, all the layers of your map are turned into a single, optimized layer that looks the same but displays faster. A vector tile package doesn't include attributes, you can't create pop-ups, and users can't search the contained data. However, if you don't regularly update the basemap data in your map, vector tile packages allow you to process the data into a basemap once and reuse it each time you update the MMPK. Consequently, you can create an MMPK faster and update your operational data regularly without reprocessing your basemap layers each time the MMPK is generated.
Use the same name for the title of your map and the
.mmpkfile—Before an offline map is downloaded, the title in Field Maps originates from the item details, which uses the name of the.mmpkfile. Once downloaded, the name of the map is the title. To help your users understand the relationship between the map they downloaded and the map on their device, use the same name for the map in ArcGIS Pro and the.mmpkfile.Use the default thumbnail for the item in your portal so it doesn't change when the offline map is downloaded.
Set an expiration date if you want the availability of your MMPK to end at a certain time. After this date, mobile workers won't be able to open it.
Limitations
The following are limitations when creating MMPKs for offline use in Field Maps:
The coordinate systems of the TPK and map must match or the TPK doesn't display.
If you're using a version of ArcGIS Pro earlier than 2.1, all basemap data must be contained in a single geodatabase.
Tip:
If your basemap contains data from multiple geodatabases and you don't want to restructure it, consider creating a vector tile package and using it as the basemap of your offline map.
Use a geospatial PDF as an offline map
A geospatial PDF can be used as a read-only offline map in Field Maps. When browsing and downloading a shared PDF item to your mobile device, you can open a geospatial PDF as a new on-device map. The geospatial PDF is displayed as a raster layer in the map using the coordinate system stored in the PDF document.
Geospatial PDFs are supported in the following ways when signed in to ArcGIS Field Maps and as an anonymous user:
You can tap on a link or scan a QR code to download a shared PDF item.
You can open geospatial PDFs with Field Maps from a folder on your mobile device.
You can browse and download geospatial PDF items that have been shared with you as a signed in user.
Using the map, you can:
Search for coordinate locations or addresses.
Drop a pin to access coordinates and address information, use the Compass and Directions tools to navigate to a location, and mark pin locations as favorites.
Measure distances and areas.
Use personal markup tools to create markup on top of the map.
View your current location.
As with a web map or mobile map package, the spatial reference provides the unit of measure. You can change the unit settings and display coordinates or measurements accordingly.
As you pan and zoom on the map, Field Maps dynamically caches raster tile information. Depending on the DPI, complexity, and size of the PDF document, it may take some time to cache this information.
Next steps
Now that you have a map ready for offline use in Field Maps, download it and work offline. If you are collecting data or performing inspections offline, learn how to sync your work.
