Fill out forms
When working with a map that has been enabled for editing and set up for data collection, mobile workers can fill out the form for each asset, observation, and inspection done in the field. In addition to manual entry of values, mobile workers can do the following to simplify data entry:
Attach photos, videos, audio, and documents to provide visual, text, and auditory information.
Scan barcodes and QR codes to simplify data entry and avoid typos.
Use default values that are prepopulated in the form. Review these before submission.
Reuse values they've used recently for the same entry in other assets or observations.
If making the same change to entries in multiple forms, update multiple forms at the same time.
Select contingent values to ensure valid value combinations.
When filling out the form, mobile workers must provide required information and resolve any validation errors before they can submit the form. An error message displays if the required fields aren't populated or if validation errors exist.
Mobile workers can attach photos, videos, audio, and documents to provide additional information for assets, observations, and inspections. Depending on how the form was configured, attachments may be displayed at the top of the form that allow photos, videos, audio, or files to be captured or uploaded.
Alternatively, the form author may have included one or more attachment elements, which can be placed anywhere in a form and allow mobile workers to capture or attach files as part of a guided workflow. Depending on how an attachment element is configured, it can be shown or hidden based on form values and can require a minimum or maximum number of attachments before the form can be submitted. Some forms may have no attachment elements and other forms may use attachment elements depending on the version of ArcGIS Enterprise they were created with.
For mobile workers to attach files, attachments must be allowed in the layer. See Build the form to learn more about how to configure a layer to allow attachments.
Attachment elements are only supported for feature layers from ArcGIS Online or ArcGIS Enterprise 12.1 or later. Maps may contain layers from older Enterprise versions that do not support attachment elements for offline workflows.
You can download attachments from a feature layer using ArcGIS API for Python and the download_attachments Python script.
Depending on how the form was configured, you can attach photos, videos, audio recordings, or documents to the form in the following ways:
Photos—Tap Take Photo to take a new photo or tap Attach or Choose Photo to attach an existing photo.
Videos—Tap Take Video to take a new video or tap Attach or Choose Video to attach an existing video.
Audio—Tap Record Audio to record a new audio message or tap Attach or Choose Audio to attach an existing audio file.
Documents—Tap Choose File to attach an existing document.
After adding an attachment, it appears in the form and can be reviewed before you submit your edits. You can also rename the attachment before submitting your edits if the form is configured to permit it.
Using the in-app camera is recommended when capturing photo attachments.
If the form does not contain attachment elements, by default, photos taken in Field Maps are large (1280 pixels on the longest edge). You can specify that the app instead use small (320), medium (640), extra large (1500), or actual size photos. Mobile workers can specify the photo size in the app settings.
If your assets include barcodes or QR codes, you can scan the barcode or QR code with Field Maps and populate one or more entries based on the scan. In Field Maps, text and numeric entries with the Barcode scanner input type contain an option for scanning a barcode or QR code. When a mobile worker chooses Scan barcode or QR code
, the device's camera app opens and reads the barcode or QR code. The information it contains populates the selected entry when the scan is complete.
The Barcode scanner input type is supported on ArcGIS Enterprise 10.9.1 and later.
Field Maps supports the barcode and QR code formats supported by the operating system. For Android support, see Scan Barcodes with ML Kit on Android. For iOS support, see Machine-Readable Object Types.
Reuse recent values
You can reuse field entries between forms to minimize repetitive data entry tasks. When mobile workers open another form after completing one, they can select from their recent entries to populate the new form. To use a recent value, select the entry where you want to use it, and choose the value from your available recent values.
Recent values are retained for text, numeric, and coded value domain entries on successful submission of an asset or observation. Up to three values are stored for each entry in the form. The recent values can be applied to other assets and observations in the same layer.
Update multiple forms at the same time
You can update a form entry for multiple assets or observations at the same time. For example, if mobile workers are performing inspections and need to mark multiple hydrants as having passed inspection, they can select all of them and update all their form entries tracking inspection at once. For details, see Update the forms of multiple existing assets.
Contingent values are created in ArcGIS Pro and allow you to define valid field values that are dependent on values in other fields. Fields that are contingent to one another are referred to as a field group. When a field group is added to the form in Field Maps, mobile workers are presented with a list of valid values for each field that are contingent to a field they previously filled out.
For example, a tree inventory form contains a field group with three fields that contain contingent values: common_tree_name, tree_genus, and tree_species. After the common tree name is selected, the tree_genus field automatically filters the list of values that are valid for the selected tree name. After the tree genus is selected, the tree_species field automatically filters as well.
To learn more about contingent values and how to create and manage field groups, see Create and manage contingent values in ArcGIS Pro.
When you select a field with contingent values in Field Maps, the list of valid options is automatically populated and listed under the Recommended section. All other values are listed in the Other drop-down menu.
Caution:
If you select a value from the Other drop-down menu, the value combination within the field group may become invalid. If the field group is restrictive and becomes invalid, you cannot submit the form.
If you select one or more values in a field group, and the remaining fields in the group contain only one Recommended value, those remaining fields will be filled in automatically.
